Marketplaces / ZZZ Obsolete ones / Newegg / Newegg info / Newegg Registration process
Please find attached your detail instructions on how to proceed and get set-up
Your key reference document
  1. Official Seller invitation instructions. This document works through the entire process from getting your account set-up through to creating your listings and it also references exactly who you need to speak to if you get stuck along the way.
Additional files that you may need are also included:
  1. W-8 Form – blank
  2. W-8 Form – marked up example
  3. Shipped By Newegg Quick start guide
  4. International Inbound Shipment guidelines – on what is required if you are going to send stock to be held in the Newegg DC’s
  5. Newegg Premier Program – details on this service
  6. Newegg return Service – additional detail on how it works
  7. Manufacturer request form – if you are selling products from a manufacturer not currently listed on Newegg.
International Inbound Shipment Guideline.pdf
Newegg Premier Seller Program_Final.pdf
Newegg Return Service.pdf
NeweggSBNQuickStartGuide.pdf
Manufacturer Request Form.xls
W-8BEN-E_markedup.pdf
W-8BEN-E_blank.pdf
Official Seller invitation Instructions.docx
