BestBuy Authentication & Database structure & Limits
Authentication:
- Log into your Mirakl shop; ( Please contact Bogomil Pavlov or Hristiyan Georgiev )
End point: https://marketplace.bestbuy.ca/
Limits
GET OR11 - List orders
CALL FREQUENCIES
Recommended:
Maximum:
