TikTok End Listing
| v1.0 | 20.06.2024 | Hristiyan Georgiev | TikTok has new API version and updates. The scope was also updated to the latest changes |
End Listing (Delete Product)
This API supports deletion of a single product or multiple products (up to 20 at a time so we need to set a limit of maximum 20 products per call)
Delete product call shouldn’t remove images. And if we re create a product, using ““Recover“ API, we do not need to upload again the images.
API Call: DELETE /product/202309/products
All triggers, validations etc are as per the abstraction -
Product Listing general requirements
Example Call:
"product_ids": [
"1749456684124612452",
"1742456684124612451"
Call Mapping:
product_id |
string | Yes | Product Account > Channel Item ID |
"code": 0,
"data": {
"errors": [
"code": 12052003,
"detail": {
"product_id": "1729382588639839583"
"message": "The current product status can not be actiavted"
"message": "Success",
Under errors we will receive list of products that failed to update(delete). We want to store the message in Product Account > End Listing Error
Note: As we push product_ids in order to delete a product, this means the product and all its variant will be deleted too! If we would want to stop selling a variant, we need to push 0 stock to the variant we would want to stop sell.
Possible Error codes & Messages:
| Code | Message |
| 12019120 | product ids exceed limit |
| 12052048 | You can't edit other sellers' products. |
| 12052700 | seller is inactived |
| 12052703 | Invalid seller tax number |
| 12052705 | seller can not manage local product. |
