Debenhams Taxonomy
| 12/07/2023 | 1.0 | Hristiyan | First publish |
API Call:/api/hierarchies
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#H11
"hierarchies": [
"code": "5911111",
"label": "Suncare",
"label_translations": [
"locale": "en",
"value": "Suncare"
"locale": "fr",
"value": "Protection solaire"
"level": 2,
"parent_code": "59"
"code": "5911112",
"label": "Toiletries",
"locale": "en",
"value": "Toiletries"
"locale": "fr",
"value": "Articles de toilette"
"level": 2,
"parent_code": "59"
"code": "5911113",
"label": "Womens Hair Removal",
"locale": "en",
"value": "Womens Hair Removal"
"locale": "fr",
"value": "Épilation Femmes"
"level": 2,
"parent_code": "59"
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#PM11
"attributes": [
"channels": [
"code": "WEBSITE_EN"
"code": "washingInstructions3",
"default_value": null,
"description": "How do you wash the product",
"description_translations": [
"locale": "en",
"value": "How do you wash the product"
"example": null,
"hierarchy_code": "3012",
"label": "Washing Instructions",
"locale": "en",
"value": "Washing Instructions"
"locale": "en_US",
"requirement_level": "OPTIONAL",
"roles": [],
"transformations": "CAMEL_CASE",
"type": "TEXT",
"type_parameter": null,
"validations": "MIN_LENGTH|10",
"variant": false
"channels": [
"code": "WEBSITE_FR"
"code": "toolsIncluded3",
"description": "Are tools included for the assembly of this product",
"locale": "en",
"value": "Are tools included for the assembly of this product"
"example": null,
"hierarchy_code": "5610102",
"label": "Tools Included",
"locale": "en",
"value": "Tools Included"
"roles": [],
"type": "LIST",
"type_parameter": "Boolean",
"variant": false
API Call: /api/values_lists
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#VL11
"values_lists": [
"code": "Jewellery",
"label": "Bijoux",
"locale": "en",
"value": "Jewellery"
"locale": "fr",
"value": "Bijoux"
"values": [
"code": "Accessories",
"label": "Accessoires",
"locale": "en",
"value": "Accessories"
"locale": "fr",
"value": "Accessoires"
"code": "Bracelets",
"label": "Bracelets",
"locale": "en",
"value": "Bracelets"
"locale": "fr",
"code": "Necklaces",
"label": "Colliers",
"locale": "en",
"value": "Necklaces"
"locale": "fr",
"value": "Colliers"
"code": "Rings",
"label": "Anneaux",
"locale": "en",
"value": "Rings"
"locale": "fr",
"value": "Anneaux"
Taxonomy export file
In order to generate the taxonomy file we will need to create a new record in Taxonomy export with: Marketplace = Debenhams Status = pending Category for Export = all (or we can specify which exact categories) Email = email to which the file will be send
Please find more details on the file structure how it should look like after exported here - Taxonomy General requirements .
There are some root attributes which we would like to include in the taxonomy export for every category.
| Attribute Name | Attribute Code | Comment |
swatch |
Swatch - required size 120 x 120 pixels (this is like a thumbnail photo) | |
returns |
gender |
collection |
details_and_care |
colour |
colourfacet |
fabrication_type |
