Offer Price Update
| 22/11/2022 | 1.0 | Bogomil Pavlov | Initial Version |
Submits an offer package
After we have successfully created an offer we can start updating the Price by Submits an offer package request.
API Call: POST https://api.octopia-io.net/seller/v2/offer-integration-packages
API Docs:https://developer.octopia-io.net/api-details#api=api-rest-seller-v2&operation=post-offer-integration-packages
Body: We specify the zip file url.
The name given to the Zip package has no importance. There is no specific norm.
The structure of the package must contain this tree structure necessarily.
- Folder _rels containing the file .rels
- Folder Content containing the file Offers.xml
- File [Content_Types].xml
Download examples of package Light
Feed Mapping:
| Cdiscount Field | Integration Required | Hemi Field | Comment | ||
Offer |
SellerProductId |
Yes | Product > SKU | |||
ProductEan |
Yes | Product Account Cdiscount > EAN |
Product Account > Marketplace EAN
Product > EAN | First priority is Product Account Cdiscount > EAN
then Product Account > Marketplace EAN then Product > EAN |
| | Price | | Yes | Product Account > Price | |
| OfferPackage.OfferPublicationList | | | | | |
| | | Id | No | Account Cdiscount > Country | If nothing is selected by default we pick France |
Sample Request:
Body:
"http://arcade.myhemisphere.com/.temp/cdiscount/upload/products/Products_2022-11-17_19-00-36.zip"
Sample Response:
424325363619
Response Mapping:
After each successfully send feed for creation we will receive the packageId from the response and need to store it in Marketplace Feeds table.
| Cdiscount Field | Hemi Field | Comment |
packageId |
| Marketplace Feed > Type | Hardcoded as “Price Update“ | |
| Marketplace Feed >ZIP Path | The url of the zip | |
| Marketplace Feed >Completed Date | When we process the feed | |
| Marketplace Feed >External Status | External Feed status |
Read Offer Package
API Call: GET https://api.octopia-io.net/seller/v2/offer-integration-packages[?packageId][>in][&pageIndex][&pageSize][&fields][&sort][&desc]
API Doc: https://developer.octopia-io.net/api-details#api=api-rest-seller-v2&operation=get-product-integration-reports
Request parameters
| Name | Required | Type | Description |
packageId |
true | string |
Format - int64. Package identifier. |
limit |
false | integer |
Format - int32. Must be written as follows $limit |
page |
false | integer |
Format - int32. Must be written as follows $page |
Sample Request: GET https://api.octopia-io.net/seller/v2/products-integration-reports?packageId=309592003&page=1&limit=50
Sample Response:
"package_id": 309592003,
"integration_state": "Integrated",
"number_of_errors": 1,
"offer_log_paged_list": [
"log_date": "2022-11-22T00:31:04.75+00:00",
"offer_integration_status": "Integrated",
"product_ean": "5056553233698",
"seller_product_id": "96581",
"property_list": [
"log_message": "96581|5056553233698|MP60297644-0004|OK|9000|Offer updated|Cdiscount",
"property_code": "0",
"property_error": "90"
"log_date": "2022-11-22T08:57:08.12+00:00",
"offer_integration_status": "Rejected",
"product_ean": "5054697499253",
"seller_product_id": "11806603270",
"property_list": [
"log_message": "11806603270|5054697499253||KO|3893|Données manquantes|Cdiscount",
"property_code": "93",
"property_error": "38"
"seller_id": 51102,
"page": 0,
"count_by_page": 50,
"total_logs_count": 2
Request Mapping:
| Cdiscount Field | Hemi Field | Comment | ||
package_id |
N/A | |||
integration_state |
Marketplace Feed >External Status | |||
number_of_errors |
N/A | |||
offer_log_paged_list |
log_date |
N/A | |||
offer_integration_status |
N/A | Based on this status we will know if the update of the SKU is successful or not | ||
product_ean |
N/A | |||
seller_product_id |
N/A | This is our SKU which we will be using to map the response | ||
property_list |
log_message |
Product Account > Update Item Error |
Product Account >Update Quantity Error
Product Account >Update Price Error
Product Account >End Item Error | Depends on the feed type we have pushed we will have to store the relevant message in the relevant field. |
| | | property_code | N/A | |
| | | property_error | N/A | |
| seller_id | | | N/A | |
| page | | | N/A | |
| count_by_page | | | N/A | |
| total_logs_count | | | N/A | |
In order to pick a product for stock and price update we must HAVE Product Account > Channel Item ID populated, the relevant flags set and Product Account > Listing Status = Active/Inactive Product Account > Product Status =Product published Product Account > Update Price = Pending
Once the product is picked for offer creation we will have: Product Account > Listing Status = Active/Inactive Product Account > Product Status =Product published Product Account > Update Price = Sent
When we read the response if successful we will update the product: Product Account > Listing Status = Active/Inactive Product Account > Product Status =Product published Product Account > Update Price = Not Needed
When we read the response if error we will update the product: Product Account > Listing Status = Active/Inactive Product Account > Product Status =Product published Product Account > Update Price = Error
And store the relevant error message in Product Account > Update Price Error
Limits:
There is a a limit of 200 000 offers in a package but I think in order to have better performance we can set a limit of 50 000 or 100 000 offers per package.
Protect Quantity - We can exclude the quantity from the payload when we are doing updates so we do not add the quantity in the payload when have Protect Quantity raised
Protect Price - We can exclude the price from the payload when we are doing updates so we do not add the price in the payload when have Protect Price raised.
Protect the whole item - We update the quantity only.
