Shein Taxonomy
| v1.0 | Hristiyan | First publish | |
| v1.1 | 06/08/2024 | Hristiyan | Added name logic for taxonomy export file |
| v1.2 | 07/08/2024 | Hristiyan | Added navigation path header for the exported file |
| v1.3 | 08.08.2024 | Bogomil | Include attribute_mode logic |
| v1.4 | 14.08.2024 | Bogomil | Taxonomy Required attribute |
The purpose of this page is to give detailed explanations of how we will download the taxonomy for Shein.
The taxonomy must be stored in classes, which should be available for exports from the UI in Export Taxonomy table. The taxonomy is used for internal validation and we will need to map the values and push the codes to Shein.
Note: Every time we send products for creation we have to do internal check if all required attributes are part of the the product as Item Specifics according to their taxonomy which we download and store on the instance,
Please note that the request headers are the same for every call.
Request Parameters (Request Header)
| Parameter Name | Data Type | Default Values | Required' TRUE | Description |
| language | string | Yes | language |
We should pick the language based on the Shein territory that is selected on the account. The language should be in an lowercase iso2 country code.
We always want to use English for the taxonomy however if for some reason we receive category or attribute name in different language or not starting with character we want to skip them. | | Content-Type | string | application/json | Yes | | | x-lt-openKeyId | string | | Yes | Unique permission identifier openKeyId when accessing user private data | | x-lt-timestamp | string | | Yes | Request timestamp, the format is the value of time converted to milliseconds, that is, the time from January 1, 1970 to the present is converted to milliseconds, such as: 1583398764000 | | x-lt-signature | string | | Yes | Interface signature |
Get the final category
API Call : POST /open-api/goods/query-category-tree
API Docs: https://open.sheincorp.com/documents/apidoc/detail/3000178-1000001
Example response :
"code": "0",
"msg": "OK",
"info": {
"data": [
"category_id": 2024,
"product_type_id": 0,
"parent_category_id": 0,
"category_name": "Men",
"last_category": false,
"children": [
"category_id": 1967,
"parent_category_id": 2024,
"category_name": "Men Clothing",
"children": [
"category_id": 2045,
"parent_category_id": 1967,
"category_name": "cccc",
"children": [
"category_id": 1972,
"product_type_id": 85,
"parent_category_id": 2045,
"category_name": "Men Sweatshirts",
"last_category": true,
"children": [],
"is_clothing": null
"is_clothing": null
"category_id": 2043,
"children": [
"category_id": 1974,
"product_type_id": 75,
"parent_category_id": 2043,
"category_name": "Men Shorts",
"children": [],
"is_clothing": null
"category_id": 1976,
"category_name": "Men Pants",
"children": [],
"is_clothing": null
"category_id": 2707,
"product_type_id": 569,
"category_name": "Men Sweatpants",
"children": [],
"is_clothing": null
"is_clothing": null
"category_id": 2044,
"children": [
"category_id": 1975,
"product_type_id": 68,
"parent_category_id": 2044,
"category_name": "Men Cardigans & Jumpers",
"children": [],
"is_clothing": null
"is_clothing": null
"is_clothing": null
"meta": {
"count": 1,
"customObj": null
"bbl": null
Once we have the categories, we need to get the attributes per each category product_type_id. We need to keep this product_type_id which is related to the category. Then when we are creating the products we need to submit the product_type_id based on the category
Get the attributes
API Call : POST /open-api/goods/query-attribute-template
API Docs : https://open.sheincorp.com/documents/apidoc/detail/3000091-1000001
Example request body :
{"product_type_id_list":[1967]}
Example response :
"code": "0",
"msg": "OK",
"info": {
"data": [
"product_type_id": 1967,
"business_mode": 13,
"attribute_infos": [
"attribute_id": 87,
"attribute_name": "Size",
"attribute_name_en": "",
"attribute_is_show": 1,
"attribute_source": 1,
"attribute_label": 1,
"attribute_mode": 2,
"data_dimension": 1,
"attribute_status": 3,
"attribute_type": 1,
"is_sample": 0,
"supplier_id": 0,
"attribute_doc": null,
"attribute_doc_image_list": null,
"attribute_value_info_list": [
"attribute_value_id": 474,
"attribute_value": "one-size",
"attribute_value_en": "",
"is_custom_attribute_value": false,
"is_show": 1,
"supplier_id": 0,
"attribute_value_doc": null,
"attribute_value_doc_image_list": null,
"attribute_value_group_list": null
"attribute_id": 27,
"attribute_name": "color",
"is_sample": 0,
"supplier_id": 0,
"attribute_value_id": 78,
"attribute_value": "Apricot",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 81,
"attribute_value": "Army Green",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000112,
"attribute_value": "DYJ_新款",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000123,
"attribute_value": "DYJ_H_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 103,
"attribute_value": "Beige",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 112,
"attribute_value": "Black",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 113,
"attribute_value": "Black and White",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 118,
"attribute_value": "blackk",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000135,
"attribute_value": "DYJ_常规款",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 137,
"attribute_value": "Bronze",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 140,
"attribute_value": "Brown",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 144,
"attribute_value": "Burgundy",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000109,
"attribute_value": "DYJ_流行款_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000114,
"attribute_value": "DYJ_针织",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 152,
"attribute_value": "Camel",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 171,
"attribute_value": "Champagne",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000130,
"attribute_value": "DYJ_踩脚裤_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 182,
"attribute_value": "Clear",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000121,
"attribute_value": "DYJ_紧身_en",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000110,
"attribute_value": "DYJ_时尚款_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 2427,
"attribute_value": "",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 2566,
"attribute_value": "frankie_test",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 2493,
"attribute_value": "Dark Grey",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000116,
"attribute_value": "DYJ_毛织_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000115,
"attribute_value": "DYJ_梭织_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000129,
"attribute_value": "DYJ_蝙蝠袖_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 322,
"attribute_value": "Ginger",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 330,
"attribute_value": "Gold",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 334,
"attribute_value": "Green",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 336,
"attribute_value": "Grey",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 364,
"attribute_value": "Hot Pink",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 379,
"attribute_value": "Khaki",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 2486,
"attribute_value": "Light Grey",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000117,
"attribute_value": "pink",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000132,
"attribute_value": "DYJ_泡泡裙_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 421,
"attribute_value": "Maroon",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000127,
"attribute_value": "DYJ_翻领_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000118,
"attribute_value": "BLUE",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 2436,
"attribute_value": "Mint Green",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000131,
"attribute_value": "DYJ_阔腿裤_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 447,
"attribute_value": "Multicolor",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000111,
"attribute_value": "DYJ_复色款_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000134,
"attribute_value": "DYJ_超短款_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000133,
"attribute_value": "DYJ_鱼尾裙_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 475,
"attribute_value": "Orange",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 513,
"attribute_value": "Pink",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 536,
"attribute_value": "Purple",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 544,
"attribute_value": "Red",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000136,
"attribute_value": "DYJ_超长袖_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000126,
"attribute_value": "DYJ_棒球领_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000113,
"attribute_value": "DYJ_套用版型款",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1705,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000108,
"attribute_value": "冬",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 562,
"attribute_value": "Royal Blue",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000119,
"attribute_value": "DYJ_修身_en",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000107,
"attribute_value": "秋",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 601,
"attribute_value": "Silver",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000120,
"attribute_value": "DYJ_宽松_en",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 2431,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000128,
"attribute_value": "DYJ_泡泡袖_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 739,
"attribute_value": "Whiteen",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 762,
"attribute_value": "Yellow",
"is_show": 1,
"supplier_id": 0,
"attribute_id": 1000624,
"attribute_name": "cyq-属性名",
"attribute_label": 0,
"attribute_mode": 1,
"data_dimension": 2,
"attribute_status": 2,
"attribute_type": 4,
"is_sample": 0,
"supplier_id": 0,
"attribute_value_id": 1007917,
"attribute_value": "Battery Powered",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000583,
"attribute_value": "en402",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000364,
"attribute_value": "en183",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000584,
"attribute_value": "en403",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000585,
"attribute_value": "en404",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1049,
"attribute_value": "USB Charger",
"is_show": 1,
"supplier_id": 0,
"attribute_id": 160,
"attribute_name": "girs like",
"is_sample": 0,
"supplier_id": 0,
"attribute_value_id": 62,
"attribute_value": "ABS",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 63,
"attribute_value": "Acrylic",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006486,
"attribute_value": "Agate",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 865,
"attribute_value": "Aluminum",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1318,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006507,
"attribute_value": "Amazonite",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006496,
"attribute_value": "Apatite",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006497,
"attribute_value": "Aquamarine",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006913,
"attribute_value": "Artificial Crystal",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006492,
"attribute_value": "Aventurine",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 91,
"attribute_value_en": null,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1007848,
"attribute_value": "Bovine Leather",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1679,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1005708,
"attribute_value": "Carborundum",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1685,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006488,
"attribute_value": "Chalcedony",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004818,
"attribute_value": "Coconut Shell",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 875,
"attribute_value": "Copper",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1005911,
"attribute_value": "Copper Alloy",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006583,
"attribute_value": "CR39",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1698,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006521,
"attribute_value": "Diamond",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 2265,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 255,
"attribute_value": "Elastane",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1103,
"attribute_value": "Elastic",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006502,
"attribute_value": "Emerald",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 963,
"attribute_value": "EVA",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 278,
"attribute_value": "Fabric",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 290,
"attribute_value": "Feather",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 859,
"attribute_value": "Fiber",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006509,
"attribute_value": "Fluorite",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006508,
"attribute_value": "Garnet",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 325,
"attribute_value": "Glass",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 327,
"attribute_value": "Glitter",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1005884,
"attribute_value": "Hadfield Steel",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006487,
"attribute_value": "Hematite",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006506,
"attribute_value": "Howlite",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1315,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 874,
"attribute_value": "Iron",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1005910,
"attribute_value": "Iron Alloy",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006489,
"attribute_value": "Jasper",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 372,
"attribute_value": "Jelly",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006510,
"attribute_value": "Labradorite",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006511,
"attribute_value": "Lapis Lazuli",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1365,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006504,
"attribute_value": "Lava",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1001031,
"attribute_value": "en850",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1005909,
"attribute_value": "Lead Alloy",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006794,
"attribute_value": "Magnesium Alloy",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1142,
"attribute_value": "38.5",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1005705,
"attribute_value": "Maize-shuck",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006490,
"attribute_value": "Malachite",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006133,
"attribute_value": "Marble Stone",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 870,
"attribute_value": "MDF",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004748,
"attribute_value": "Melamine",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000660,
"attribute_value": "en479",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006499,
"attribute_value": "Moonstone",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006512,
"attribute_value": "Morganite",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 876,
"attribute_value": "Non-woven Fabric",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006494,
"attribute_value": "Obsidian",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006495,
"attribute_value": "Onyx",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1005704,
"attribute_value": "Osier",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 867,
"attribute_value": "Paper",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 498,
"attribute_value": "PC",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 904,
"attribute_value": "PE",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006503,
"attribute_value": "Peridot",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1115,
"attribute_value": "PET",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1026,
"attribute_value": "PEVA",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1001972,
"attribute_value": "中台test317",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1005883,
"attribute_value": "PMMA",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 525,
"attribute_value": "Polyamide",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 526,
"attribute_value": "Polyester",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1007850,
"attribute_value": "Polyethylene Fibre",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000897,
"attribute_value": "en716",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004747,
"attribute_value": "Polypropylene",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1007849,
"attribute_value": "polyvinyl Chloride Fibre",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1321,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 855,
"attribute_value": "PP",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1005315,
"attribute_value": "PPSU",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006493,
"attribute_value": "Prehnite",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 856,
"attribute_value": "PS",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000145,
"attribute_value": "DYJ_欧美_EN",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 532,
"attribute_value": "PU Leather",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 538,
"attribute_value": "PVC",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1007845,
"attribute_value": "PVC Leather",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1780,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006498,
"attribute_value": "Rhodochrosite",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 563,
"attribute_value": "Rubber",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006500,
"attribute_value": "Ruby",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1005696,
"attribute_value": "San",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006501,
"attribute_value": "Sapphire",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 587,
"attribute_value": "Shell",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 599,
"attribute_value": "Silicone",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 868,
"attribute_value": "Stainless Steel",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 640,
"attribute_value": "Stone",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 647,
"attribute_value": "Straw",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1001654,
"attribute_value": "lzp111001",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1003448,
"attribute_value": "Synthetic Rubber",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006582,
"attribute_value": "TAC",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1384,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1057,
"attribute_value": "Tempered Glass",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006505,
"attribute_value": "Tiger Eye",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006565,
"attribute_value": "Titanium",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1007851,
"attribute_value": "Titanium Alloy",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006491,
"attribute_value": "Tourmaline",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1058,
"attribute_value": "TPE",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1025,
"attribute_value": "TPR",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 689,
"attribute_value": "TPU",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000676,
"attribute_value": "en495",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006485,
"attribute_value": "Tungsten Steel",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1820,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1005709,
"attribute_value": "White Corundum",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 746,
"attribute_value": "Wood",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 869,
"attribute_value": "WPC",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1005318,
"attribute_value": "Zinc",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1420,
"is_show": 1,
"supplier_id": 0,
"attribute_id": 1000547,
"attribute_name": "Other Material(不对前台展示)",
"is_sample": 0,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1380,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 404,
"attribute_value": "Linen",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006169,
"attribute_value": "No Other Material",
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 466,
"attribute_value": "Nylon",
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 517,
"attribute_value": "Plastic",
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 873,
"attribute_value": "Resin",
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 573,
"attribute_value": "Satin",
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 727,
"attribute_value": "Velvet",
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"is_show": 1,
"supplier_id": 0,
"attribute_id": 1000100,
"attribute_name": "DYJ_袖型_公_普_下单_EN",
"attribute_mode": 3,
"is_sample": 0,
"supplier_id": 0,
"attribute_value_id": 1001856,
"attribute_value": "中台test201",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1001855,
"attribute_value": "中台test200",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1001857,
"attribute_value": "伸縮性ウェスト",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1625,
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1001854,
"attribute_value": "中台test199",
"is_show": 1,
"supplier_id": 0,
"attribute_id": 1000099,
"attribute_name": "DYJ_领型_公_普_下多_EN",
"is_sample": 0,
"supplier_id": 0,
"attribute_value_id": 1001851,
"attribute_value": "Ivory",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1001250,
"attribute_value": "en1069",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1001852,
"attribute_value": "中台test197",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1001853,
"is_show": 1,
"supplier_id": 0,
"attribute_id": 1000088,
"attribute_name": "DYJ_002_公共_颜色属性_下拉单选_颜色1",
"is_sample": 0,
"supplier_id": 0,
"attribute_value_id": 1001532,
"attribute_value": "Mini",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1001531,
"attribute_value": "170",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000507,
"attribute_value": "en326",
"is_show": 1,
"supplier_id": 0,
"attribute_id": 8,
"attribute_name": "Battery",
"is_sample": 0,
"supplier_id": 0,
"attribute_value_id": 459,
"attribute_value": "No",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 763,
"attribute_value": "Yes",
"is_show": 1,
"supplier_id": 0,
"attribute_id": 167,
"attribute_name": "ceishi1111",
"attribute_mode": 0,
"attribute_type": 2,
"is_sample": 0,
"supplier_id": 0,
"attribute_value_info_list": []
"attribute_id": 1000411,
"attribute_name": "Quantity",
"attribute_source": 2,
"attribute_mode": 4,
"is_sample": 0,
"supplier_id": 0,
"attribute_value_id": 1002333,
"attribute_value": "棉布网眼刺绣",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1002451,
"attribute_value": "Flax",
"is_show": 1,
"supplier_id": 0,
"attribute_id": 1000101,
"attribute_name": "DYJ_裤型_公_普_下单_EN",
"is_sample": 0,
"supplier_id": 0,
"attribute_value_id": 1001858,
"attribute_value": "中台test203",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1001860,
"attribute_value": "中台test205",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1001859,
"attribute_value": "中台test204",
"is_show": 1,
"supplier_id": 0,
"attribute_id": 55,
"attribute_name": "Length (cm)",
"is_sample": 0,
"supplier_id": 0,
"attribute_id": 118,
"attribute_name": "Width (cm)",
"is_sample": 0,
"supplier_id": 0,
"attribute_id": 48,
"attribute_name": "Height (cm) 哦哦",
"is_sample": 0,
"supplier_id": 0,
"attribute_id": 164,
"attribute_name": "Functiontest3311",
"is_sample": 0,
"supplier_id": 0,
"attribute_value_id": 0,
"is_show": 1,
"supplier_id": 0,
"attribute_id": 32,
"attribute_name": "Diameter (cm)",
"is_sample": 0,
"supplier_id": 0,
"attribute_id": 1000407,
"attribute_name": "关税种类",
"is_sample": 0,
"supplier_id": 0,
"attribute_value_id": 1005244,
"attribute_value": "Unspecified Tariff Type",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004236,
"attribute_value": "Earplugs",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1003736,
"attribute_value": "Headphone Protective Cover",
"is_show": 1,
"supplier_id": 0,
"attribute_id": 1000062,
"attribute_name": "织造方式",
"is_sample": 0,
"supplier_id": 0,
"attribute_value_id": 1000915,
"attribute_value": "en734",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000916,
"attribute_value": "en735",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000918,
"attribute_value": "en737",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1000919,
"attribute_value": "en738",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004567,
"attribute_value": "Nonwoven",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004569,
"attribute_value": "Felt",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004572,
"attribute_value": "Mesh Knitting",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1007840,
"attribute_value": "Knitwear",
"is_show": 1,
"supplier_id": 0,
"attribute_id": 1000616,
"attribute_name": "cheney测试",
"is_sample": 0,
"supplier_id": 0,
"attribute_value_id": 1006920,
"attribute_value": "Wi-Fi(No Wi-Fi Alliance Certified)",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006919,
"attribute_value": "Wi-Fi(Wi-Fi Alliance Certified)",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006926,
"attribute_value": "Includes Built-In Laser",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006928,
"attribute_value": "Includes Wireless Charging Capabilities",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006927,
"attribute_value": "Includes Wired Charging Capabilities",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006923,
"attribute_value": "Cellular Network",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006922,
"attribute_value": "Bluetooth (No Bqb Certified)",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006921,
"attribute_value": "Bluetooth (Bqb Certified)",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006925,
"attribute_value": "Antibacterial (kills bacteria through chemical means)",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006924,
"attribute_value": "Antibacterial (Kills Bacteria Through Physical Means)",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004580,
"attribute_value": "None",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1706728,
"attribute_value": "AC Output Function",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1010539,
"attribute_value": "Fast Charging",
"is_show": 1,
"supplier_id": 0,
"attribute_id": 1000462,
"attribute_name": "敏感类别",
"is_sample": 0,
"supplier_id": 0,
"attribute_value_id": 1006206,
"attribute_value": "Others (Non-Transport Sensitive Items)",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004811,
"attribute_value": "Magnetic",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004804,
"attribute_value": "Contains Dry Batteries",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004803,
"attribute_value": "Contains Lithium-Ion Battery",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004805,
"attribute_value": "Containing Nickel Metal Hydride Battery",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1015686,
"attribute_value": "Lithium Metal Batteries",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1015687,
"attribute_value": "Sodium-Ion Batteries",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1006828,
"attribute_value": "Lead-Acid Batteries",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004812,
"attribute_value": "Contains Gas",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004807,
"attribute_value": "Contains Liquid",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004808,
"attribute_value": "Containing Paste",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004809,
"attribute_value": "Contains Powder",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1004810,
"attribute_value": "Contains Particles",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1087445,
"attribute_value": "Contains Flammable Solids",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1202192,
"attribute_value": "Knives (Unregulated)",
"is_show": 1,
"supplier_id": 0,
"attribute_value_id": 1405557,
"attribute_value": "Nickel-Cadmium Battery",
"is_show": 1,
"supplier_id": 0,
"attribute_id": 1000546,
"attribute_name": "型号(关务)",
"is_sample": 0,
"supplier_id": 0,
"attribute_id": 1000186,
"attribute_name": "前台尺寸-回推1必-私1",
"is_sample": 0,
"supplier_id": 0,
"attribute_id": [
87,
27,
1000624,
160,
1000547,
1000100,
1000099,
1000088,
8,
167,
1000411,
1000101,
55,
118,
48,
164,
32,
1000407,
1000062,
1000616,
1000462,
1000546,
1000186
"meta": {
"count": 1,
"customObj": null
"bbl": null
From the response we can see that we have some common information about an attribute and that is :
| attribute_id | long | attribute id |
| attribute_is_show | int64 | 1: Display; 0: Do not display |
| attribute_label | int64 | Property ID. 1: Main sales logo 0: No |
| attribute_mode | int64 | Attribute entry method. 0: Manually fill in parameters; 1: Drop-down list selection (multiple selections possible); 2: Sales attribute exclusive (only for sales attributes, drop-down list selection); 3: Drop-down list selection (single selection); 4: Drop-down list + manual parameters /Attribute entry method. 0: fill in the parameters manually; 1: drop-down list selection (multiple selections); 2: Exclusive to sales attributes (only for sales attributes, select from the drop-down list); 3: drop- down list selection (single selection); 4: drop-down list + manual parameters |
| attribute_name | string | Property name |
| attribute_source | int64 | Property source. 1: Public attributes 2: Private attributes |
| attribute_status | int64 | Peripheral input method 1: Peripheral blank; 2: Peripheral optional; 3: Peripheral required |
This indicates wether the attribute is requried - 3 means required 1 and 2 means not required | | attribute_type | int64 | Attribute type 1-sales attribute, 2-front-end size attribute, 3-ingredient attribute, 4-common attribute, 5-color attribute, 6-back-end size information |
<v1.3>When creating products in Shein, we need to submit two types of attributes : Main, SubMain and primary sale attributes. We can differentiate them by the different attribute_type values.
For example:
"attribute_label": 1 + "attribute_mode": 2 - Main attributes (sale_attribute)
"attribute_mode": 2 - SubMain Attribute (sale_attribute_list)
"attribute_mode" different from 2 - Secondary attributes (product_attribute_list)
We want to make sure we are validating and pushing in the correct order the attributes so we have to add extra check and if we have a variation specifics for a product added as color and size but only size is ("attribute_label": 1 + "attribute_mode": 2) we want to push it as sale_attribute and the color ("attribute_label": 0 + "attribute_mode": 2) to be pushed as sale_attribute_list.
In case of more than one variation specifics but both attributes are ("attribute_label": 1 + "attribute_mode": 2) we want the first one to be pushed as sale_attribute and the second as sale_attribute_list.
All item specifics should be pushed as product_attribute_list.
</v1.3>
We want to store both the attribute_name and attribute_id and then when sending products for create, we need to map the IS/VS attribute_name in Hemi but send the attribute_id when creating the product(s).
Also we can understand by the attribute_status whether an attribute is required or not. If it is on status 1 or 2 it is NOT required, but if it is status = 3 then it is required. <v1.4>Also all attributes which are with "attribute_label": 1 + "attribute_mode": 2 we treat them as required. </v1.4>
<v1.3>Also all attributes with attribute_mode= 2 should have in the export file Is Variation Specific? = Yes all the rest are with No this way we will know which attributes can be used for variations.</v1.3>
We can understand if a category is leaf or not if there is a children object or not. If there is no children option then it is a leaf category.
Get Brand list
Use this API to retrieve all product brands. We will be storing brands as a part of the taxonomy (as attributes, applicable for each category)
API Call: POST /open-api/goods/query-brand-list
API Docs: https://open.sheincorp.com/documents/apidoc/detail/3000092-1000001
Example response :
"code": "0",
"msg": "OK",
"info": {
"data": [
"brand_code": "254p8",
"brand_name": "Disney",
"brand_name_en": "Disney"
"brand_code": "2xbdr",
"brand_name": "Star Wars",
"brand_name_en": "Star Wars"
"brand_code": "2za5c",
"brand_name": "Marvel",
"brand_name_en": "Marvel"
"brand_code": "29li5",
"brand_name": "Paw Patrol",
"brand_name_en": "Paw Patrol"
"brand_code": "2j4gl",
"brand_name": "West Ham F.C.",
"brand_name_en": "West Ham F.C."
"brand_code": "29izm",
"brand_name": "Wednesday",
"brand_name_en": "Wednesday"
"brand_code": "2400i",
"brand_name": "Wakanda",
"brand_name_en": "Wakanda"
"brand_code": "28k9p",
"brand_name": "Tottenham Hotspur F.C.",
"brand_name_en": "Tottenham Hotspur F.C."
"brand_code": "2o7dn",
"brand_name": "Rick & Morty",
"brand_name_en": "Rick & Morty"
"brand_code": "23vr6",
"brand_name": "Liverpool F.C.",
"brand_name_en": "Liverpool F.C."
"brand_code": "2ntu7",
"brand_name": "KreativeKraft",
"brand_name_en": "KreativeKraft"
"brand_code": "26mly",
"brand_name": "England F.C.",
"brand_name_en": "England F.C."
"brand_code": "27xv8",
"brand_name": "Derma Medico",
"brand_name_en": "Derma Medico"
"brand_code": "2ut69",
"brand_name": "Deco Express",
"brand_name_en": "Deco Express"
"brand_code": "2m5o2",
"brand_name": "City Comfort",
"brand_name_en": "City Comfort"
"brand_code": "2fcqd",
"brand_name": "Chelsea F.C.",
"brand_name_en": "Chelsea F.C."
"brand_code": "2ycnl",
"brand_name": "Celtic F.C.",
"brand_name_en": "Celtic F.C."
"brand_code": "28gmd",
"brand_name": "Arsenal F.C.",
"brand_name_en": "Arsenal F.C."
"brand_code": "2mvu4",
"brand_name": "ABYstyle Studio",
"brand_name_en": "ABYstyle Studio"
"brand_code": "2omsn",
"brand_name": "Manchester City FC",
"brand_name_en": "Manchester City FC"
"brand_code": "2xfe8",
"brand_name": "Pokemon(宝可梦)",
"brand_name_en": "Pokemon"
"brand_code": "22unx",
"brand_name": "SONIC THE HEDGEHOG",
"brand_name_en": "SONIC THE HEDGEHOG"
"brand_code": "2rumx",
"brand_name": "Harry Potter/哈利波特",
"brand_name_en": "Harry Potter"
"brand_code": "22kpp",
"brand_name": "L.O.L. SURPRISE!",
"brand_name_en": "MGA"
"brand_code": "2bamm",
"brand_name": "乐高/Lego",
"brand_name_en": "LEGO"
"brand_code": "24pd1",
"brand_name": "GB Eye",
"brand_name_en": "GB Eye"
"brand_code": "2cyb2",
"brand_name": "ABYstyle",
"brand_name_en": "ABYstyle"
"brand_code": "2t0eh",
"brand_name": "Stranger Things",
"brand_name_en": "Stranger Things"
"brand_code": "2tbs1",
"brand_name": "Gabby's Dollhouse",
"brand_name_en": "Gabby's Dollhouse"
"brand_code": "2zwmw",
"brand_name": "SpongeBob SquarePants",
"brand_name_en": "SpongeBob SquarePants"
"brand_code": "2caaq",
"brand_name": "Barbie",
"brand_name_en": "Barbie"
"brand_code": "23ugb",
"brand_name": "PlayStation",
"brand_name_en": "PlayStation"
"brand_code": "2356h",
"brand_name": "Jurassic World",
"brand_name_en": "Jurassic World"
"brand_code": "269yd",
"brand_name": "CoComelon",
"brand_name_en": "CoComelon"
"brand_code": "24qzt",
"brand_name": "Super Mario",
"brand_name_en": "Super Mario"
"brand_code": "27ww6",
"brand_name": "Minecraft",
"brand_name_en": "Minecraft"
"brand_code": "2a3qi",
"brand_name": "Naruto",
"brand_name_en": "Naruto"
"brand_code": "2aq6e",
"brand_name": "Bluey",
"brand_name_en": "Bluey"
"brand_code": "2b91e",
"brand_name": "Rainbow High",
"brand_name_en": "Rainbow High"
"brand_code": "2hy6x",
"brand_name": "Peppa Pig",
"brand_name_en": "Peppa Pig"
"brand_code": "2ra0v",
"brand_name": "Fortnite",
"brand_name_en": "Fortnite"
"meta": {
"count": 41,
"customObj": null
"bbl": null
We want to store both the brand_name_en and brand_code and then when sending products for create, we need to map the brand in Hemi but send the brand_code when creating the product(s)
Taxonomy export file
In order to generate the taxonomy file we will need to create a new record in Taxonomy export with: Marketplace = Shein Status = pending Category for Export = “all” (or we can specify which exact categories) or “brands” so we can export brands. Email = email to which the file will be send
We want to have a logic and if the user has selected 5 or more categories for export, we want to export them in a single zip file. This will be valid also if all categories are being exported.
<v1.1> We want the name of the file to consist of CategoryID+Category name and it should be in a format SheinCategoryID_CategoryName.csv </v1.1>
Please find example file structure how it should look like after exported.
| CategoryID | Category Name | Is Leaf | <v1.2> Navigation Path </v1.2> | Item Specifics | <v1.3>Is Variation Specific?</v1.3> | Required | Enumeration | Values | |||||
| 1967 | Men Clothing | No | Ropa de Mujer > Ropa Premamá > Monos y Bodys de Premamá > Bodys premamá | Size | Yes | Yes | Yes | one-size | |||||
| 1967 | Men Clothing | No | Ropa de Mujer > Ropa Premamá > Monos y Bodys de Premamá > Bodys premamá | Color | Yes | Yes | Yes | Apricot | Army Green | DYJ_新款 | DYJ_H_EN | Beige | Black |
| 1967 | Men Clothing | No | Other Material(不对前台展示) | No | No | Yes | ABS | Acrylic | Aluminum | Copper | Glass | ||
| 2707 | Men Sweatpants | Yes | 其他材料 | No | No | Yes | Animal | Argyle | Bat | caoyang_val_en | Car | ||
| 2707 | Men Sweatpants | Yes | spmp66 | No | No | No |
Brands file format
| Shein Brand | Brand code | |
| 1 | Fortnite | 2u1ys |
| 2 | Bluey | 24rjv |
| 3 | Naruto | 2nz97 |
Please note that these examples are from the sandbox enviroment and we strongly hope that there will be no chinese words when this is done in a proper live environment, however it will be nice if the Dev team can advise if we can use some kind of translator so to have us covered just incase and translate any chinese to english if needed.
