Fuse5 Get Stock
| v1.0 | 03.04.2025 | Bogomil Pavlov | First publish |
The get stock simply is a request which generate a URL to a csv file which we need to import in MCP. File should be processed automatically by this functionality following standard Stock concepts in MCP - if SKU doesn’t exist don’t import in Product Location Quantities, If quantity value is changed and we update the record - date_created should be updated for sure, If quantity hasn’t changed don’t update the record. More on the flow and details below
Get Stock
The first run of the cron should get all stock levels and we do not want to specify changedsince identifier in MM-DD-YYYY HH:MM:SS format.
If we have a record in last_date_run for the cron we want to overlap with 30mins.
API Docs : https://greenteam.fuse5live.com/f5apidoc/standalone/#api-Product-Export_All_Products
API Call : product/export
Sample Request:
"authenticate":{
"apikey":"API KEY"
"services":[
"call":"product/export",
"params": ["line_code","product_number","unit_barcode","location_name","all_location_total_available"],
"identifier":{"location_name":"Fiji","changedsince":"09-30-2015 16:20:59"}
Request Mapping:
identifier > location_name - This will be a list of our Fuse5 Connector > Fuse5 Locations. We need to make a call per each mapped Location in the Connector
identifier > changedsince - This will be picked from last_date_run
params - we want to always use the parameters from the sample request
Sample Response:
authenticate: {
"apikey":"API KEY",
status: "success"
services: [
request: {
call: "product/export",
params: null,
identifier: null
response: {
status: true,
msg: {
code: "M003",
msg: "Data retrieved successfully"
data: "https://test.test.com/properties/dev/exports/files/products_20150225_104658am.csv"
From the response we want to use the generated .csv file form the data and import it in MCP.
Sample File:
products_20250427_020536pm.csv
Sample File Mapping (please note not all columns from the CSV are mapped):
| File Header | Hemi Field | Comment |
| line_code | Products Location Quantities > Product Identifier | Based on the Fuse5 Connector > SKU Delimiter we will generate the SKU like line_code[delimeter]product_number |
| product_number | Products Location Quantities > Product Identifier | Based on the Fuse5 Connector > SKU Delimiter we will generate the SKU like line_code[delimeter]product_number |
| unit_barcode | N/A | |
| location_name | N/A | |
| all_location_total_available | Products Location Quantity > Quantity |
Please note when we are importing the quantities in Hemi we want to have the following logic for picking the Location.
- We should pick each Fuse5 connector location separately and pull down the information and import in the mapped MCP location
- It should have nothing to do with Channel, everything should go through the Connector only itself. If no Location is set script should log an error and stop. Script should run through every mapped location. If a location is a problem then we should finish with it and move to the next location
We want to update the quantity only if there is a difference.
