ASOS - Create Product
| Date | Version | Applied changes |
| 28/09/2022 | 1.1 | Statuses changed based on a comment |
| 30/09/2022 | 1.2 | Complete flow described |
| 26/10/2022 | 1.3 | Include Variation Groups in MIRAL |
The purpose of this document is to describe in details the process of creating products on MIRAKL.
The specifics on MIRAKL are we must create a product first, and then we must create/send an offer for the already created product.
Please note we do not need to select all variants if only one them is set for revision or creation because they goes as separate products on MIRAKL and the only thing which associate them is the supplier-ref.
So we can add variants to a variation group only by specifying the correct supplier-ref.
If we want to remove a product from a variation we need to push the product for update again without the supplier-ref.
Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#P41
Yes |
| operator_format | Force the use of the operator product format | No |
Note: Every time we send products for creation we have to do internal check if all required attributes are part of the the product as Item Specifics according to their taxonomy which we download and store on the instance. Please note that for the ASOS we will have only 5 categories that we will use! Also, there are no required attributes and values
Complete flow:
Product status -Awaiting Creation ; Listing Status - Inactive; List/Update the whole Item = Sent (in order to be picked by Offer creation)
If we receive success after performing P44 (when we send product to MIRAKL & When both "has_error_report" and "has_transformation_error_report" are equal to “false“ ) we can proceed to following:
Аfter successful product creation we need to fill the Channel Item ID, which for MIRAKL integration is the SKU!
If we receive an error (any of "has_error_report" and "has_transformation_error_report" are equal to “true“):
<?xml version='1.0' encoding='UTF-8'?><import><products>
<product>
<attribute>
<code>product-category</code>
<value>clothing</value>
</attribute>
<attribute>
<code>seller-sku</code>
<value>4063699279412</value>
</attribute>
<attribute>
<code>name</code>
<value>PUMA Mens BMW M Motorsport Sweatpants Track Bottoms Sports Pants - Medium Gray H</value>
</attribute>
<attribute>
<code>description</code>
</attribute>
<attribute>
<code>brand</code>
<value>PUMA</value>
</attribute>
<attribute>
<code>ean</code>
</attribute>
<attribute>
<code>image-1</code>
<value>https://images.puma.net/images/193148/01/sv01/fnd/GBR/</value>
</attribute>
<attribute>
<code>color</code>
<value/>
</attribute>
<attribute>
<code>supplier-ref</code>
<value/>
</attribute>
</product>
</products></import>
product-category |
Yes | Product Account > Primary Category ID | ||
seller-sku |
Yes | Product > SKU | ||
name |
Yes | Product Account > Title | ||
description |
Yes | Product Account > Description | ||
brand |
Yes | Product Account> Item specifics |
Product > Brand | |
| ean | | Yes | Product Account > MP EAN
Product > EAN | If we do not have EAN filled, we should display an error ( EAN is required and we could not proceed to product creation without EAN) |
| image-1 | | Yes | Product > Main Image or Product Account Asos > Main Image | |
| color | | No | Product Account> Item specifics | Per category |
| supplier-ref | | No | Product Account > Variation Group | Please refer to “How to handle variations section“ |
"import_id": 2035
| N/A | N/A |
Please note we will add all successfully sent products as feed objects which after processing need to be removed from the object table.
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#P42
Example response:
"date_created": "2019-04-05T12:56:21Z",
"has_error_report": false,
"has_new_product_report": false,
"has_transformation_error_report": false,
"has_transformed_file": true,
"import_id": 2005,
"import_status": "SENT",
"shop_id": 2000,
"transform_lines_in_error": 0,
"transform_lines_in_success": 1,
"transform_lines_read": 1,
"transform_lines_with_warning": 0
Depends on the response of:"has_error_report" and "has_transformation_error_report" we will need to call each of the error reports if we receive "true".
When both "has_error_report" and "has_transformation_error_report" are equal to “false“ is the success case (Import status = Completed) and we could proceed to creating and offer to all products inside the feed.
If we receive success (When both "has_error_report" and "has_transformation_error_report" are equal to “false“ ) we can proceed to following:
Product status -Product Created ; Listing Status - Inactive; List/Update the whole Item = Not Needed
Note: See below detailed information for mentioned API calls ("has_error_report" and "has_transformation_error_report" )
We need to perform this call if we receive has_error_report = true, into the response from P42;
Basically, we rad the report and we extract the SKU column. After that we compare the Errors or Warninngs columns and we need to store them.
We will consider Warning=Success in the ASOS integration (it is kind of standard on every MIRAKL)
API Call: /api/products/imports/{import}/error_report
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#P44
Sample file - To be added
This call returns if the import is successful and how may warnings and errors we have in the file. We need to call this if we receive has_transformation_error_report = true
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#P47
