Debenhams Refund Order
| 03/08/2023 | 1.0 | Hristiyan | First Publish |
| 13.02.2024 | 1.1 | Bogomil Pavlov | Incorporate Cancellation on not debited orders. |
| 25.04.2025 | 1.2 | Bogomil | Add default reasons |
The refund/cancellation request on MIRAKL is per item line id and we can include each separate item as additional “refund“ or “cancellation“ node. To process the refund/cancellation , we have to specify a reason which need to be added in the Refund UI for Debenhams Marketplace. In order to obtain the reasons, we should use GET RE01 - List reasons call and then just to get the reason, however we add them with sql query directly in the database, to make a refund/cancellation , we should use PUT OR28 - Request a refund or OR30 - Request cancelations on order lines
- GET RE01 - List reasons
API Call:/api/reasons
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#RE01
Please note we need to store only the reasons which are with type = “REFUND“ and type = “CANCELATION“ Also this request is only for reference because we add the reasons with sql query directly in the database.
Example response:
"reasons": [
"code" : "14",
"is_shop_right" : false,
"label" : "No response from the shop",
"type" : "REFUND"
"code" : "15",
"is_shop_right" : true,
"label" : "Out of stock",
"type" : "REFUND"
"code" : "16",
"label" : "Cancelled by the client prior to shipping",
"type" : "REFUND"
"code" : "17",
"label" : "Item returned",
"type" : "REFUND"
"code" : "18",
"label" : "Item not received on delivery",
"type" : "REFUND"
"code" : "19",
"label" : "Agreement found with the seller",
"type" : "REFUND"
"code" : "REFUND_30",
"label" : "Item not received on return",
"type" : "REFUND"
"code" : "REFUND_31",
"label" : "Faulty Item - No return required",
"type" : "REFUND"
"code" : "REFUND_32",
"label" : "Faulty Item",
"type" : "REFUND"
"code" : "REFUND_33",
"label" : "Item unable to be shipped",
"type" : "REFUND"
"code" : "34",
"type" : "CANCELATION"
"code" : "SYSTEM_LATE_SHIPMENT_CANCELATION",
"label" : "Canceled due to late shipment",
"code" : "SYSTEM_CANCELATION_DEBIT_FAILED",
"label" : "Debit failed",
"code" : "SYSTEM_CANCELATION_DEBIT_TIMEOUT",
"label" : "Debit timed out",
Bear in mind we need to display the label into the UI but to send the code.
Because in our UI we cannot distinguish the refund from the cancellation we need to add in the label what type is the reason is for the refund or for cancellation.
E.G. [REFUND] - {label} or [CANCELATION] - {label}
<v1.2> We want to set a logic and have a default CANCELATION and REFUND reasons if there is no reason specified in the refund. At the moment if there is no reason we receive error “[INTERNAL]Could find refund reason code by label '’. We want to add additional checkbox field in Order Refund Reasons > Default which will be used to specify default reasons for the debenhams and the logic should support default reasons per reason type. In order to be able to filter reasons by type we want to add another new field Order Refund Reasons > Type which indicates if the reasons is: “Cancellation” or “Refund” or “All”. **Having the type we can have two default reasons one for CANCELATION and one for REFUND type. Based on our MIRAKL abstraction and the check we are doing before each refund (checking the can_refund and can_cancel flags we should be correct default reason type).
If for some reason we have more than one default reason per type we pick the first available and we do not want to return an error.
“[INTERNAL]Could not find refund reason code by label '’ should be returned only if there is no reason in the refund and there is no default reason set. </v1.2>
- PUT OR28 - Request a refund
API Call: /api/orders/refund
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#OR28
*Note:** Each payment row (type=refund) will need to be send as a separate request. If even one of the refunds failed it will fail the whole feed. Thus we have agreed to push them per payment row. Which means we will have one request with all of the refund row nodes.
Example call: (one item in order)
"order_tax_mode": "TAX_EXCLUDED",
"refunds": [
"amount": 1.5,
"currency_iso_code": "USD",
"order_line_id": "Order_00010-A-1",
"quantity": 0,
"reason_code": "15",
"shipping_amount": 2,
"shipping_taxes": [
"amount": "1",
"code": "tax1"
"amount": "1",
"code": "tax2"
"taxes": [
"amount": "1",
"code": "tax1"
"amount": "1",
"code": "tax2"
"refunds": [
"amount": 1.5,
"quantity": 0,
"shipping_taxes": [
"amount": "1",
"code": "tax1"
"amount": "1",
"code": "tax2"
"taxes": [
"amount": "1",
"code": "tax1"
"amount": "1",
"code": "tax2"
"amount": 1.5,
"order_line_id": "Order_00010-A-2",
"quantity": 0,
"shipping_taxes": [
"amount": "1",
"code": "tax1"
"amount": "1",
"code": "tax2"
"taxes": [
"amount": "1",
"code": "tax1"
"amount": "1",
"code": "tax2"
MIRAKL allows us to refund:
- Partially items;
- Shipping
- Orders
order_tax_mode |
Please note: If the taxes are not specified, the prices with mode TAX_EXCLUDED and with mode TAX_INCLUDED will return the same amounts. |
Possible values:
• TAX_EXCLUDED: the price fields (price, unit price, shipping price and order total prices) do not include taxes (taxes come on top of the price amount).
• TAX_INCLUDED: the price fields include the tax amounts.
• If not specified, the default order tax mode of the platform is used | No | N/A | We want to use the default order tax mode of the platform, so we should not send any tax mode. |
| refunds | | | | Yes | | |
| | amount | | | Yes | Refund Row > Amount | Refund rows with type “item“ |
| | currency_iso_code | | | No | Order > Order currency | |
| | order_line_id | | | Yes | Order Item >Item Order Line ID | |
| | quantity | | | No | Order Item > Quantity | Based on the Refund Row > Amount we need to calculate the quantity!
• If we are doing partial line refund we specify the quantity as 0.
• If we are doing full line refund (the full quantity)
we specify the actual quantity we have for the item e.g. 1, 2, 3 etc.
Note: For each full like we are having quantity = 1
For each partial like we will have quantity = 0 |
| | reason_code | | Refund's reason code | Yes | Order Payment > Reason | We need to use the reason code. |
| | shipping_amount | | The shipping charges part amount to be refunded | Yes | Refund Row > Amount | Refund rows with type “shipping “ |
| | shipping_taxes | | | | | |
| | | | amount | | | We need to calculate this based on the shipping cost added for the refund
We need to get the % of the shipping cost = % of the Shipping cost VAT
Refund rows with type “shipping“
Please note if there is no shipping cost we do not want to include this in the payload |
| | | | code | | ****“TAXDEFAULT“ | Hardcoded as “TAXDEFAULT“
| | | taxes | | | | |
| | | | amount | | | We need to calculate this based on the item price added for the refund
We need to get the % of the item price = % of the Item VAT
| | | | code | | “TAXDEFAULT“ | Hardcoded as “TAXDEFAULT“ |
"cancelations": [
"amount": 2,
"cancelation_id": "1116",
"eco_contributions": [],
"order_line_id": "Order_00013-A-1",
"purchase_information": {
"purchase_commission_on_price": 1.00,
"purchase_commission_on_shipping": 1.50,
"purchase_price": 1.00,
"purchase_shipping_price": 1.50
"quantity": 0,
"reason_code": "34",
"shipping_amount": 3,
"shipping_taxes": [
"amount": 1,
"code": "tax1",
"purchase_tax": {
"purchase_amount": 0.50,
"purchase_rate": 7.5000
"rate": 17.5000
"amount": 1,
"code": "tax2",
"purchase_tax": {
"taxes": [
"amount": 1,
"code": "tax1",
"purchase_tax": {
"rate": 17.5000
"amount": 1,
"code": "tax2",
"purchase_tax": {
Response Mapping:
cancelations |
amount |
N/A | ||||
cancellation_id |
Order Payment Details > Transaction ID | Because each order item is pushed in a separate transaction we will receive more than one refund_id thus we will have to concatenate them with “-“ | |||
currency_iso_code |
N/A | ||||
eco_contributions |
N/A | ||||
order_line_id |
N/A | This will be used for the mapping | |||
purchase_information |
N/A | ||||
quantity |
N/A | ||||
reason_code |
N/A | ||||
shipping_amount |
N/A | ||||
shipping_taxes |
N/A | ||||
taxes |
N/A | ||||
order_tax_mode |
N/A |
- PUT OR30 - Request cancelations on order lines
API Call: /api/orders/cancel
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#OR30
"cancelations": [
"amount": 2,
"quantity": 0,
"reason_code": 34,
"shipping_amount": 0,
"shipping_taxes": [
"amount": "1",
"code": "tax1"
"amount": "1",
"code": "tax2"
"taxes": [
"amount": 1,
"code": "tax1"
"amount": 1,
"code": "tax2"
"cancelations": [
"amount": 2,
"quantity": 0,
"reason_code": 34,
"shipping_taxes": [
"amount": "1",
"code": "tax1"
"amount": "1",
"code": "tax2"
"taxes": [
"amount": 1,
"code": "tax1"
"amount": 1,
"code": "tax2"
"amount": 2,
"order_line_id": "Order_00013-A-2",
"quantity": 0,
"reason_code": 34,
"shipping_taxes": [
"amount": "1",
"code": "tax1"
"amount": "1",
"code": "tax2"
"taxes": [
"amount": 1,
"code": "tax1"
"amount": 1,
"code": "tax2"
- Partially items;
- Shipping
- Orders
cancellations |
amount |
Refund Row > Amount | Refund rows with type “item“ | |||
currency_iso_code |
Order > Order currency | ||||
order_line_id |
Product In Order >Item Order Line ID | ||||
quantity |
Product In Order > Quantity | Based on the Refund Row > Amount we need to calculate the quantity! |
we specify the actual quantity we have for the item e.g. 1, 2, 3 etc. |
| | reason_code | | | Order Payment > Reason | We need to use the reason code. |
| | shipping_amount | | | Refund Row > Amount | Refund rows with type “shipping “ |
"cancelations": [
"amount": 2,
"quantity": 0,
"shipping_taxes": [
"amount": 1,
"code": "tax1",
"purchase_tax": {
"rate": 17.5000
"amount": 1,
"code": "tax2",
"purchase_tax": {
"taxes": [
"amount": 1,
"code": "tax1",
"purchase_tax": {
"rate": 17.5000
"amount": 1,
"code": "tax2",
"purchase_tax": {
Response Mapping:
| Integration Field | Integration Notes | Integration required | Hemi Mapping | Hemi Notes | |||
cancelations |
amount |
N/A | ||||||
cancellation_id |
Order Payment Details > Transaction ID | Because each order item is pushed in a separate transaction we will receive more than one refund_id thus we will have to concatenate them with “-“ | |||||
currency_iso_code |
N/A | ||||||
eco_contributions |
N/A | ||||||
order_line_id |
N/A | This will be used for the mapping | |||||
quantity |
N/A | ||||||
reason_code |
N/A | ||||||
shipping_amount |
N/A | ||||||
shipping_amount_breakdown |
N/A | ||||||
parts |
amount |
N/A | ||||||
commissionable |
N/A | ||||||
debitable_from_customer |
N/A | ||||||
payable_to_shop |
N/A | ||||||
shipping_taxes |
N/A | ||||||
taxes |
N/A | ||||||
order_tax_mode |
N/A |
<v1.1>
API Call: /api/orders/{order_id}/cancel
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#OR29
We have to specify in the URL our Orders > Marketplace Order Id
Cancel an order not yet debited from the customer. All accepted but NOT shipped orders are treated as “Not Yet Debited” which means that if a cancellation has to happen, we need to use the OR29 call instead of OR30. Please note only full order cancellations for non debited orders are allowed and we would like to add internal validation and return internal error if not full cancellation is done.
Example call:
PUT https://mirakl.marketplace.laredoute.com/api/orders/12341231-A/cancel
Example Response: 204: No Content
- If we have
can_cancel=trueandcustomer_debited_date=nullandcan_refund=falseWe need to use the OR29 to cancel the order - If we have
can_cancel=trueandcustomer_debited_date=date(in a2023-12-04T12:26:07.043Zformat) andcan_refund=falsewe need to use the OR30 to cancel - If we have for some reason
can_refund=trueandcan_cancel=truewe need to use the OR30 to cancel (this is not an expected behavior anyways, if for some reason it happens for whatever reason we want to have it covered) - If we have
can_cancel=falseandcustomer_debited_date=nullandcan_refund=trueWe need to use the OR28 to refund the order (this is not an expected behavior anyways, if for some reason it happens for whatever reason we want to have it covered) -
If we have
can_cancel=falseandcustomer_debited_date=date(in a2023-12-04T12:26:07.043Zformat) andcan_refund=trueWe need to use the OR28 to refund the order</v1.1>
Specifics:
- If all transaction are successfully and we receive the
refund_idor thecancellation_id,we need to mark the Order Payment > Status = "Completed" and Refund Row > Status = "Completed" - If not all transactions are completed but we have one or more completed we mark the Order Payment > Status = “Partially Completed“, Refund Row > Status = “Completed“ for the successful line and Refund Row > Status = “Error“.
- If all transactions failed we mark Order Payment > Status = “Error“, Refund Row > Status = “Error“ and store the error in Order Error table.
