Fruugo Refund Orders
| v1.0 | 15/01/2024 | Hristiyan | First publish |
Fruugo allows us to either cancel or return an order and this can be done on line level. So in this document we will describe both cases and when/what should be used. Partial refunds are only allowed on the whole line and we cannot refund partial amount of the item(s) cost.
Both requests will again use Web Hooks so it is all the same as all other calls.
Order Cancel
API Docs : https://developer.fruugo.com/#tag/orders-v3/operation/cancelOrders API Call : POST https://order-api.fruugo.com/v3/orders/cancel
Example request :
"orders": [
"type": "cancel",
"orderId": "string",
"itemQuantities": [
"productId": "string",
"skuId": "string",
"quantity": 1
"messageToCustomer": "string",
"messageToFruugo": "string",
"cancellationReason": "out_of_stock"
Request mapping :
| Fruugo Field | Required | Hemi Field | Comments | ||
orders |
type |
N/A | Hardcoded as “cancel" |
orderId |
Yes | Orders > Marketplace Order ID |
itemQuantities |
The node can be repeated multiple times in one request to confirm multiple items at a time. If node is sent as blank, all items on the order will be cancelled. | ||||
productId |
No | N/A | |||
skuId |
No | Order Refund Rows > SKU |
quantity |
No | N/A | Needs to be calculated. Based on the price in the Order Refund Row > Amount we should identify the quantity we are refunding. |
messageToCustomer |
No | N/A | |||
messageToFruugo |
No | N/A | |||
cancellationReason |
Yes | Order Payment > Reason |
This is for type Refund. |
Valid values are:
• out_of_stock
• product_discontinued
• invalid_delivery_address
• customer_cancellation
• legislation_restriction
• other
These should be added as enums in the Order Refund Reasons table with label [CANCELATION]. |
Since partial and full cancellations are allowed with the same call, we need to create internal logic :
- If we are sending a full cancellation, we will only use the fields marked as Required in the above table (only
orderIdandcancellationReason) . - If we are sending partial cancellation we need to send the items that are being cancelled and include them in the payload.
Example responses :
202 Request has been accepted for processing, and update will be performed asynchronously.
This is the successful request. We should then expect a response from Fruugo via the web-hook endpoint that we have provided.
400 Bad Request
Example response :
"type": "field",
"field": "productId",
"message": "must not be null"
"type": "field",
"field": "skuIds",
"message": "size must be between 1 and 200"
This bad request should not happen but incase it happens we should store all errors in Order Errors with type Order Acknowledge.
429 Request has been rejected due to exceeding rate limit. Retry after delay specified in "Retry-After" response header.
Incase we receive this we should just retry the request after the specified “Retry-After” in the header.
Callback payload sample :
"value": {
"type": "CancelResponseList",
"merchantId": 444,
"correlationId": "c3145570-0731-45db-9c9a-33f97d588400",
"payload": "Payload: {'transactionType':'cancel','responses':[{'success':false,'errorMessage':'BD_ILLEGAL_FULFILMENT_STATUS_TRANSITION - cancelPurchaseOrder failed, order status is NOT_REPLACED','orderId':'9164260001000444','shipmentId':null,'itemStatuses':null}]}"
We want to be looking for the success status in the response :
- If we have
success: true we act as per the Refunds send general logic . We don’t seem to be receiving transaction id or anything similar so we will have to leave the transaction id as blank. - If we have
success: false, we want to store theerrorMessageinOrder Errorswith typeOrder Refundfor the relevantorderId.
Order Return
API Docs : https://developer.fruugo.com/#tag/orders-v3/operation/cancelOrders API Call : https://order-api.fruugo.com/v3/orders/return
Example request :
"orders": [
"type": "return",
"itemQuantities": [
"skuId": "string",
"quantity": 1
"returnReason": "unsatisfied_with_item"
The mapping is the same as the Order Cancel with the only difference being the returnReason instead of cancellationReason .
The possible return reasons are :
- unsatisfied_with_item
- item_did_not_match_description
- damaged_item
- wrong_item
- other
These should be added as enums in the Order Refund Reasons table with label [RETURN]
"value": {
"merchantId": 444,
"payload": "{'transactionType':'return','responses':[{'success':true,'errorMessage':'','orderId':'1','shipmentId':null,'itemStatuses':[{ 'productId': 'STOCK005' 'skuId': 'STOCK-IS-1000-WITHV20' 'quantity': 1 'status': 'RETURNED'}] }]}"
- If we have
All other triggers and validations are as per the Refunds send general logic
