Marketplaces / Yoox Technical Scope / Yoox Product & Offer management / Yoox Offer Price Update
19.10.22 1.0 First Publish
01.02.23 1.1 Bogomil Pavlov Split the flow to two separate feeds with and without prices.
API Docs:https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#OF01
product-id Unique product identifier for a given product-id-type - Required at offer creation - Maximum 40 characters Yes Product >EAN
product-id-type Yes hardcoded as “ean“ If we have ean populated we hardcoded the type as “ean“
price The selling price in the currency.
It is up to the operator to define with the seller whether the selling price includes or excludes taxes. Decimal number; a period is used to separate cents | Yes | Product Account > Price OR Product Account> RRP | we send Product Account > RRP If RRP is populated and is bigger than Price | | min-quantity-alert | | | | | N/A | | | state | | | The state code of the offer The accepted values are defined from the Mirakl back office | Required | see notes | Mapping to our conditions: 11- New > 1000; | | discount-price | | | | No | Product Account > Price | If RRP > Price
  2. If there are no dates imported in Hemi we use the default dates (Now) and (Now + 2y) If RRP <= Price 3.We include the discount fields with empty values | | discount-start-date | | | | No | Product Account Yoox> Discount Start Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcoded current date (“NOW“) Date format - 2017-02-20T10:45:53+01 If RRP <= Price We include the discount fields with empty values | | discount-end-date | | | | No | Product Account Yoox> Discount End Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcode current date + 2 year (“NOW“ +2y) Date format - 2017-02-20T10:45:53+01 If RRP <= Price We include the discount fields with empty values | | all-prices | | | | | | | | | pricing | | | | | | | | | channel-code | | Yes | Account Yoox > Channel | | | | | price | | Yes | Product Account > Start Price OR Product Account> RRP | we send Product Account > RRP If RRP is populated and is bigger than Price | | | | discount-price | | No | Product Account > Price | If RRP > Price
  3. If there are discount dates imported in Hemi we use them
  4. If there are no dates imported in Hemi we use the default dates (Now) and (Now + 2y) If RRP <= Price 3.We include the discount fields with empty values | | | | discount-start-date | | No | Product Account Yoox> Discount Start Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcoded current date (“NOW“) Date format - 2017-02-20T10:45:53+01 If RRP <= Price We include the discount fields with empty values | | | | discount-end-date> | | No | Product Account Yoox> Discount End Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcode current date + 2 year (“NOW“ +2y) Date format - 2017-02-20T10:45:53+01 If RRP <= Price We include the discount fields with empty values |
<offer_import_tracking>
</offer_import_tracking>
import Import identifier Yes
Error case: If "has_error_report": true this means there is an error and we need to reach each of the reports in order to check for which item and what is the error.
