Yoox Offer Full update
| 15.01.23 | 1.0 | First Publish | |
| 01.02.23 | 1.1 | Bogomil Pavlov | Split the flow to two separate feeds with and without prices |
API Docs: https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#OF01
sku |
product-id |
| product-id-type | | | | Yes | hardcoded as “EAN“ | Must be UPPERCASE |
| internal-description | | | The description of the offer as shown in the back office view - Optional - Maximum 2000 characters | No | N/A | |
Character string limited to 100 characters | No | Product Account Yoox > Price Additional Info | |
| min-quantity-alert | | | | | N/A | |
The accepted values are defined from the Mirakl back office | Required | Product > Condition | Mapping to our conditions:
11- New > 1000; |
yyyy-MM-dd
or
yyyy-MM-ddThh:mm:ss+00
| No | N/A | |
yyyy-MM-dd
or
| No | N/A | |
| discount-price | | | | No | Product Account > Price | If RRP > Price
If RRP <= Price
discount-start-date| | | | No | Product Account Yoox> Discount Start Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcoded current date (“NOW“) Date format -2017-02-20T10:45:53+01If RRP <= Price We include the discount fields with empty values | |discount-end-date| | | | No | Product Account Yoox > Discount End Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcode current date + 2 year (“NOW“ +2y) Date format -2017-02-20T10:45:53+01If RRP <= Price We include the discount fields with empty values | |update-delete| | | Used only in "Normal" import mode. Update mode is used if blank. "", "update", "delete" | No | N/A | | |all-prices| | | | | | | | | |channel-code| | Yes | Account Yoox > Channel | | | | |price| | Yes | Product Account > Start Price OR Product Account> RRP | we send Product Account > RRP If RRP is populated and is bigger than Price | | | |discount-price| | No | Product Account > Price | If RRP > Price - If there are discount dates imported in Hemi we use them
If RRP < Price
3.We do not include the discount fields. |
discount-start-date| | No | Product Account Yoox> Discount Start Date | If we do not specify any dates in the relevant fields we hardcoded current date (“NOW“) Date format -2017-02-20T10:45:53+01| | | |discount-end-date>| | No | Product Account Yoox> Discount End Date | If we do not specify any dates in the relevant fields we hardcode current date + 2 year (“NOW“ +2y) Date format -2017-02-20T10:45:53+01|
pricing |
sku |
product-id |
11- New > 1000;
1-Excellent > 1500;
2-Very Good >4000;
3-Good >5000;
4-Sufficient >6000;
5-Refurbished_like_new > 2750
6-Refurnished_very_good >2500
7-Refurbished_good > 2000
yyyy-MM-dd
or
| No | N/A | |
yyyy-MM-dd
or
| No | N/A | |
<offer_import_tracking>
</offer_import_tracking>
API Docs: {{TBA}}
