B&Q - Taxonomy
API Call:/api/hierarchies
API Docs: https://marketplace.kingfisher.com/help/api-doc/seller/mmp.html#H11
"hierarchies": [
"code": "PIM_10541",
"label": "In-Line Fans",
"label_translations": [
"locale": "en",
"value": "In-Line Fans"
"level": 4,
"parent_code": "PG_1067"
"code": "PIM_10542",
"label": "Shower Fan Kits without Lights",
"locale": "en",
"value": "Shower Fan Kits without Lights"
"level": 4,
"parent_code": "PG_1067""
API Docs: https://marketplace.kingfisher.com/help/api-doc/seller/mmp.html#PM11
API Call: /api/values_lists
API Docs: https://marketplace.kingfisher.com/help/api-doc/seller/mmp.html#VL11
Taxonomy export file
In order to generate the taxonomy file we will need to create a new record in Taxonomy export with: Marketplace = B&Q Status = pending Category for Export = all (or we can specify which exact categories) Email = email to which the file will be send
Please find ore details on the file structure how it should look like after exported here - Taxonomy General requirements .
