Marketplaces / Showroom Prive Technical Scope / Showroom Prive Product & Offer management / Showroom Prive Offer Price Update
1.0 First Publish
API Docs:{{TBA}}
product-id Unique product identifier for a given product-id-type - Required at offer creation - Maximum 40 characters Yes Product >EAN
product-id-type Yes hardcoded as “ean“ If we have ean populated we hardcoded the type as “ean“
price The selling price in the currency.
It is up to the operator to define with the seller whether the selling price includes or excludes taxes. Decimal number; a period is used to separate cents | Yes | Product Account > Price OR Product Account> RRP | we send Product Account > RRP If RRP is populated and is bigger than Price | | min-quantity-alert | | | N/A | | | state | The state code of the offer The accepted values are defined from the Mirakl back office | Required | see notes | Mapping to our conditions: 11- New > 1000; 1-Excellent > 1500; 2-Very Good >4000; 3-Good >5000; 4-Sufficient >6000; 5-Refurbished_like_new > 2750 6-Refurnished_very_good >2500 7-Refurbished_good > 2000 8-Refurbished_acceptable > New state(condition) to be created in Hemi (8000) | | discount-price | | No | Product Account > Price | If we have RRP > Price | | discount-start-date | | No | {{TBA}} | If we do not specify any dates in the relevant fields we hardcoded current date (“NOW“) | | discount-end-date | | No | {{TBA}} | If we do not specify any dates in the relevant fields we hardcode current date + 2 year (“NOW“ +2y) |
<offer_import_tracking>
</offer_import_tracking>
API Docs: {{TBA}}
import Import identifier Yes
Error case: If "has_error_report": true this means there is an error and we need to reach each of the reports in order to check for which item and what is the error.
API Docs:{{TBA}}
