B&Q - Offer zero stock update
| 19/10/2022 | 1.0 | Initial Version | |
| 01.02.23 | 1.1 | Bogomil Pavlov | Split the flow to two separate feeds with and without prices. |
/api/offers/importsAPI Docs: https://marketplace.kingfisher.com/help/api-doc/seller/mmp.html#OF01
Mapping is the same as B&Q - Offer Stock Update
"import_id": 2035
API Docs: https://marketplace.kingfisher.com/help/api-doc/seller/mmp.html#OF02
