ASOS - Zero Stock Update
| 03/10/2022 | 1.0 | Bogomil Pavlov | MP feed type updated |
| 01.02.23 | 1.1 | Bogomil Pavlov | Split the flow to two separate feeds with and without prices. |
Аfter successful product creation should have Channel Item ID, which for MIRAKL integration is the SKU!
Mapping is the same as ASOS- Offer Stock Update
Product status=Product Published ; Listing Status= Active; End Item= Yes
Product status=Product Published ; Listing Status= Inactive; End Item= No
Product status=Product Published ; Listing Status= Active; End Item= Error
"import_id": 2035
| Marketplace Feed > Type | Hardcoded as “Offer End Item“ | |
