Decathlon - Create Product - In progress
The purpose of this page is to detailed describe the flow of creating a product on Decathlon.
API Call: POST /{partner_name}/products/add/
API Docs: https://omcdev.playstg.net/api-swagger-docs/
Partner name - TBD
Example Call:
"id": "string",
"name": "string",
"vat": "string",
"is_discontinued": true,
"cost_price": "string",
"selling_price": "string",
"shipping_price": "string"
id |
string |
maxLength: 18
minLength: 1 | Yes | Product > SKU | |
| name | maxLength: 500
minLength: 1 | Yes | Product > Title | |
| vat | string($decimal) | Yes | Product Account > VAT | |
| is_discontinued | boolean | No | TBD | As we are going to only create products “false“ value should be hardcoded?? To be confirmed |
| cost_price | string($decimal | Yes | Product Account > Original Price | |
| selling_price | string($decimal | Yes | Product Account > Price
or
Product Account > RRP | We will send Product Account > RRP If RRP is populated and is bigger than Price |
| shipping_price | string($decimal | Yes | Product Account > Shipping Amount | |
Example response:
"status": "success",
"message": "Successfully added new product"
Error response:
"status": "error",
"message": "Could not create product"
TBDs:
1.what if we send 2 products for creation and one of them failed? How we can understand which product failed, as we do not receive the ID (our SKU) into the error response?
do we need to push qty? If so, what will be the API
Can we create a product with multiple variants?
If this call is going to be used for Price update, are we able to modify/change the title of the product for example?
