Marketplaces / Lazada / Lazada logistics
Lazada logistics
Lazada Global Shipping (LGS) is the end-to-end logistics solution for Crossborder sellers/brands from the sortation center to the end-customer.  Therefore, you do no need to worry about last-mile deliveries.  Also, LGS is also DDP (duty-inclusive) and thus you just need to include GST/VAT "as written on the right side of the rate card" if your SKU exceeds tax threshold.
Once seller receive an order, they need to update the order status from "Pending" to "Ready to Ship" within 48 hrs (excluding public holidays of seller country & weekends).
The parcels (with invoice and products inside and shipping label attached on the box) must arrive at the sortation center within 7 calendar days from the date the order showed up as a "pending order".   Sellers can print out invoice and shipping label from Seller Center.
CB_HK LGS Solution Pack (1).pdf
