Laredoute Offer zero stock update
| 07/03/2023 | 1.0 | Hristiyan | Initial Version |
| 26/05/2023 | 1.1 | Danail Deltchev | Addition of Closed and Protect flags behaviour |
/api/offers/importsAPI Docs: https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#OF01
"import_id": 2035
API Docs: https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#OF02
API Docs: https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#OF03
Any Triggers or Validations that are not specifically mentioned, changed or removed from the above mentioned scope should follow the standard flor as per the Link Here abstraction.
(v1.1) As the purpose of this flow is only for the zero stock we have 2 options:
- End Item is on Pending - no matter what else is happening this is a trigger for sending quantity update with 0. This is the case for the Zero stock flow or for a full offer update too. If a product is picked for an update and End Item is on Pending we should send quantity 0 no matter of the value in Hemi or protection or closed flags
- The trigger is Update Quantity = Pending + Quantity = 0
- Item Closed flag - as everywhere else this should completely stop any updates so such products should not be sent
- Protect Quantity = yes - when it comes to the Zero Stock where we are looking just for the quantity updates this should also skip this product (same as for the normal Stock Update as described here: Laredoute Offer Stock Update )
- Protect the whole item should NOT block stock updates
