Laredoute Offer delete
| 07/02/2023 | 1.0 | Hristiyan | First Publish |
"update_delete": "delete"
API Docs: https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#OF01
If error, we will have:
<offer_import_tracking>
</offer_import_tracking>
API Docs: https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#OF02
API Docs: https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#OF03
