B&Q - Order Acknowledgement
| 19/10/2022 | 1.0 | Initial Version |
Order > Status = “Pending“
Order > Is Acknowledge = “Sent”
Product In Order > Status = "Shipping"Order > Status = “Ready for Shipping“
API Docs: https://marketplace.kingfisher.com/help/api-doc/seller/mmp.html#OR21
"order_lines": [
"accepted": true,
"id": "Order_00012-B-1"
"accepted": true,
"id": "Order_00012-B-2"
Mapping
order_lines |
accepted |
| ‘TRUE' or 'FALSE’ | Yes | If Order Item > Rejected Order Item = 0 we send TRUE |
If Order Item > Rejected Order Item = 1 we send FALSE |
| | id | string | Yes | The value stored in Product In Order > Order Item Line |
Please note we DO accept only order items which are with Order Item > Rejected Order Item = 0 or the status of the order item is is NOT “CANCELED“ or “REFUNDED”. This way we have both cases cover we download an order on status “Awaiting Acceptance“ with cancelled order item and if we try to accept it we will receive an error so we need to make sure that only order items with the correct status are accepted. Then if we have order which we do not want to accept all order item our internal teams can set Order Item > Rejected Order Item = 1 and we need to reject the item.
