NordStrom Offer zero stock update
/api/offers/importsAPI Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#OF01
"import_id": 2035
Any Triggers or Validations that are not specifically mentioned, changed or removed from the above mentioned scope should follow the standard flor as per the Link Here abstraction.
