VeePee Stock Update
| 13.02.23 | 1.0 | Bogomil Pavlov | First Publish |
| 07.03.23 | 1.1 | Bogomil Pavlov | Remove the header parameter |
| 28.03.23 | 1.2 | Bogomil Pavlov | Added better error response |
| 28.03.23 | 1.3 | Bogomil Pavlov | Added a case when we have full update and quantity update at the same time |
| 03.04.23 | 1.4 | Bogomil Pavlov | Response Reader Mapping added |
| 06.04.2023 | 1.5 | Bogomil Pavlov | VeePee Status details added |
The purpose of this document is to describe in details how we will send stock updates
Stock is shared for all different channels on the VeePee account.
API Call: {{BaseURL}}/stock
API Docs: https://pinkstaging.pink-connect.com/swagger#operation/uploadStock
We use the Incremetal Quantity set always as true as query parameter.
(Default: true. When set to false, all products that don't come in the file will be set to 0 stock.)
You can generate a csv file (comma delimiter) and upload it via API. The file must have these headers:
- gtin: The gtin of the product when it was created
- stock: The amount of available stock for that product (Required)
| Field | Required | Hemi Field | Hemi Note |
| gtin | Yes | Product Account > Marketplace EAN |
OR Product > EAN | Product Account > Marketplace EAN is with priority | | sku | Yes | Product > SKU | | | stock | Yes | Product Account> Quantity | |
We pick the offer for update as per abstraction - Stock Update general requirements
"INC_STOCK_20230215103536.csv"
After each successfully send feed for creation we need to store the filename which is returned from VeePee in the response and need to store it in Marketplace Feeds table. All products that are included in the feed need to be marked as Product Account > Update Quantity - Sent
| VeePee Field | Hemi Field | Comment |
| FileName | Marketplace Feed > External ID | This field is used to get the response of the import. |
| Marketplace Feed > Type | Hardcoded as “Listing Stock Update“ | |
Get the import status for a product import
API Call: {{BaseURL}}/status/{filename}
API Docs: https://pinkstaging.pink-connect.com/swagger#operation/getFileStatus
UPDATED: the change was successfully imported (we treat this as success)
SKIPPED: there was no change compared to the last feed (we treat this as success)
NOT FOUND: the reference does not exist in Pink Connect (we treat this as error)
ERROR: the data was not imported due to an error (we treat this as error)
Example pending response:
"status": "PENDING",
"result": "ok",
"errorList": [
"string"
Example success response:
"status": "FINISHED",
"result": "ok",
"stats": "OFFER [ ERROR :0, UPDATED :2]",
"errorList": []
Example error response #1:
"result": "ok",
"stats": "OFFER [ ERROR :2, UPDATED :0, SKIPPED :0, NOT_FOUND :0]",
"errorList": [
"line: 2 gtin: 123123123123213213213321 reason: Gtin: 123123123123213213213321 => Invalid stock value: \"a\" ",
"line: 1 gtin: 1234567891013 reason: Gtin: 1234567891013 => Invalid stock value: \"b\" "
In order to store the errors on each item we need to map the GTIN on each line from the response against Product > EAN or Product Account > MP EAN (MP EAN is with priority) and store the error message which in this case is “Invalid stock value“ on the correct product account.
Example error response #2
"result": "ok",
"stats": "OFFER [ SKIPPED :0, UPDATED :0, NOT_FOUND :0, ERROR :0]",
"errorList": []
We can receive an error without lines as well which we want to treat as full feed error and mark all products (feed objects) as error
Example error response #3
"result": "ok",
"stats": "OFFER [ SKIPPED :0, UPDATED :0, NOT_FOUND :0, ERROR :1]",
"errorList": ["Format structure unknown"]
We can receive an error without lines as well which we want to treat as full feed error and mark all products (feed objects) as error with the relevant error message
Based on the response we need to map each product and we will have to update the products either with error or success as well as the Marketplace Feed > Status and Marketplace Feed > External Status. If the product stock update successfully and we do not receive and error in the errorList from the response we want to update: Product Account > Update Quantity - Not Needed
If we receive and error and the product stock is not update: Product Account > Update Quantity - Error Product Account > Update Quantity Error - store the relevant error message
Please note we do not want to Update the Product Account > Update Quantity field when we are doing full product update. We want to push the stock with the Full Product Update once and then with Product Account > Update Quantity if = 'pending'. This is required in order to be able to use the Protect Quantity in all flows.
Any Triggers or Validations that are not specifically mentioned, changed or removed from the above mentioned scope should follow the standard flor as per the Stock Update general requirements abstraction.
Protect Quantity (Stop all quantity updates) If Protect Quantity = Yes and Update Quantity = Pending - We skip the product
Closed -will stop all the updates to the MPs.
