Marketplaces / Laredoute MIRAKL Technical Scope / Laredoute Product & Offer management / Laredoute Offer Price Update
07/03/2023 1.0 Hristiyan First Publish
25.09.2024 1.1 Bogomil Include VAT
API Docs: https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#OF01
product-id Unique product identifier for a given product-id-type - Required at offer creation - Maximum 40 characters Yes Product Account > Marketplace EAN
OR Product >EAN | Product Account > Marketplace EAN is with priority | | product-id-type | | | | Yes | hardcoded as “EAN“ | | | price | | | The selling price in the currency. It is up to the operator to define with the seller whether the selling price includes or excludes taxes. Decimal number; a period is used to separate cents | Yes | Product Account > Price OR Product Account> RRP | we send Product Account > RRP If RRP is populated and is bigger than Price | | min-quantity-alert | | | | | N/A | | | state | | | The state code of the offer The accepted values are defined from the Mirakl back office | Required | Product > Condition | Mapping to our conditions: 11- New > 1000; | | discount-price | | | | No | Product Account > Price | If RRP > Price
  2. If there are no dates imported in Hemi we use the default dates (Now) and (Now + 2y) If RRP <= Price 3.We include the discount fields with empty values | | discount-start-date | | | | No | Product Account LaRedoute > Discount Start Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcoded current date (“NOW“) Date format - 2017-02-20T10:45:53+01 If RRP <= Price We include the discount fields with empty values | | discount-end-date | | | | No | Product Account LaRedoute > Discount End Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcode current date + 2 year (“NOW“ +2y) Date format - 2017-02-20T10:45:53+01 If RRP <= Price We include the discount fields with empty values | | <v1.1>offer-additional-fields | | | | | | | | | offer-additional-field | | | | | | | | | code | | “vat” | | Hardcoded as VAT | | | | value | | Yes | Product Account > VAT OR Account > VAT | Product Account > VAT is with priority Available values: 20, 10, 5.5, 2.1 We need to make sure we are using only VAT% of the possible values </v1.1> |
<offer_import_tracking>
</offer_import_tracking>
API Docs: https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#OF02
import Import identifier Yes
Error case: If "has_error_report": true this means there is an error and we need to reach each of the reports in order to check for which item and what is the error.
API Docs:https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#OF03
Protect Price (Stop all price updates) If Protect Price = Yes and Update Price= Pending - We skip the product
Protect the whole item - (Stop all product updates apart from Quantity) If Protect the whole item = Yes and Update Price= Pending - We skip the whole variation
