Download Taxonomy
Note: Every time we send products for creation we have to do internal check if all required attributes are part of the the product as Item Specifics according to their taxonomy which we download and store on the instance. Please note that for the ASOS we will have only 5 categories that we will use! Also, there are no required attributes and values
API Call:/api/hierarchies
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#H11
Example response:TBA
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#PM11
API Call: /api/values_lists
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#VL11
Taxonomy export file
In order to generate the taxonomy file we will need to create a new record in Taxonomy export with: Marketplace = B&Q Status = pending Category for Export = all (or we can specify which exact categories) Email = email to which the file will be send
Please find example file structure how it should look like after exported. We store for each category separate file.
Add label
