Laredoute Create Products
| 06/03/2023 | v1.0 | Hristiyan | First Publish |
| 15/03/2023 | v1.1 | Hristiyan | Mapping changes |
| 10.05.2023 | v1.2 | Bogomil Pavlov | If Variation Group is empty we use the SKU |
Please note we do not need to select all variants if only one them is set for revision or creation because they goes as separate products on MIRAKL and the only thing which associate them is the ProductID
So we can add variants to a variation group only by specifying the correct ProductID
If we want to remove a product from a variation we need to push the product for update again without the ProductID
API Docs: https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#P41
Complete flow:
If we receive success after performing P42 (when we send product to MIRAKL & When both "error_report" and "transformation_error_report" are equal to “false“ ) we can proceed to following:
There will be two cases how to handle channel item ids in MIRAKL depends on the type :
- The first case is after successful product creation we need to fill the Channel Item ID, which will be the SKU.
- The second option is to use P31 Get products for a list of product references which will map the SKUs between Hemi and MIRAKL and store the MIRAKL id as Channel Item ID.
For Laredoute integration we will go for option 1
If we receive an error (any of "error_report" and "transformation_error_report" are equal to “true“):
Yes |
| No |
Example File:
<products>
<product>
<attribute>
<code>Product_Publication_ID</code>
<value/>
</attribute>
<attribute>
<code>Category</code>
<value>S1344</value>
</attribute>
<attribute>
<code>ShopSKU</code>
<value/>
</attribute>
<attribute>
<code>ProductTitle[fr_FR]</code>
<value/>
</attribute>
<attribute>
<code>EAN</code>
<value/>
</attribute>
<attribute>
<code>Brand</code>
<value/>
</attribute>
<attribute>
<code>ProductID</code>
<value/>
</attribute>
<attribute>
<code>ConceptNumber</code>
<value/>
</attribute>
<attribute>
<code>ClapID</code>
<value/>
</attribute>
<attribute>
<code>Product_Alt_Cod</code>
<value/>
</attribute>
<attribute>
<code>Description[fr_FR]</code>
<value/>
</attribute>
<attribute>
<code>ProductTitle[en_EN]</code>
<value/>
</attribute>
<attribute>
<code>Description[en_EN]</code>
<value/>
</attribute>
<attribute>
<code>Video</code>
<value/>
</attribute>
<attribute>
<code>Doc_installation_instructions</code>
<value/>
</attribute>
<attribute>
<code>Doc_reparability_index</code>
<value/>
</attribute>
<attribute>
<code>Master_Product_Main_Image</code>
<value/>
</attribute>
<attribute>
<code>Master_Product_Alternative_Image1</code>
<value/>
</attribute>
<attribute>
<code>Master_Product_Alternative_Image2</code>
<value/>
</attribute>
<attribute>
<code>Master_Product_Alternative_Image3</code>
<value/>
</attribute>
<attribute>
<code>Master_Product_Alternative_Image4</code>
<value/>
</attribute>
<attribute>
<code>Master_Product_Alternative_Image5</code>
<value/>
</attribute>
<attribute>
<code>Master_Product_Alternative_Image6</code>
<value/>
</attribute>
<attribute>
<code>Master_Product_Alternative_Image7</code>
<value/>
</attribute>
<attribute>
<code>Master_Product_Alternative_Image8</code>
<value/>
</attribute>
<attribute>
<code>Master_Product_Alternative_Image9</code>
<value/>
</attribute>
<attribute>
<code>Master_Product_Alternative_Image10</code>
<value/>
</attribute>
<attribute>
<code>Image1</code>
<value/>
</attribute>
<attribute>
<code>Image2</code>
<value/>
</attribute>
<attribute>
<code>Image3</code>
<value/>
</attribute>
<attribute>
<code>Image4</code>
<value/>
</attribute>
<attribute>
<code>Image5</code>
<value/>
</attribute>
<attribute>
<code>Image6</code>
<value/>
</attribute>
<attribute>
<code>Image7</code>
<value/>
</attribute>
<attribute>
<code>Image8</code>
<value/>
</attribute>
<attribute>
<code>Image9</code>
<value/>
</attribute>
<attribute>
<code>Image10</code>
<value/>
</attribute>
<attribute>
<code>Image11</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image01</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image02</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image03</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image04</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image05</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image06</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image07</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image08</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image09</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image10</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image11</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image12</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image13</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image14</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image15</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image16</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image17</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image18</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image19</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image20</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image21</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image22</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image23</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image24</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image25</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image26</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image27</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image28</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image29</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image30</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image31</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image32</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image33</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image34</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image35</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image36</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image37</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image38</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image39</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image40</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image41</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image42</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image43</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image44</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image45</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image46</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image47</code>
<value/>
</attribute>
<attribute>
<code>Animation_Image48</code>
<value/>
</attribute>
<attribute>
<code>360_Image01</code>
<value/>
</attribute>
<attribute>
<code>360_Image02</code>
<value/>
</attribute>
<attribute>
<code>360_Image03</code>
<value/>
</attribute>
<attribute>
<code>360_Image04</code>
<value/>
</attribute>
<attribute>
<code>360_Image05</code>
<value/>
</attribute>
<attribute>
<code>360_Image06</code>
<value/>
</attribute>
<attribute>
<code>360_Image07</code>
<value/>
</attribute>
<attribute>
<code>360_Image08</code>
<value/>
</attribute>
<attribute>
<code>360_Image09</code>
<value/>
</attribute>
<attribute>
<code>360_Image10</code>
<value/>
</attribute>
<attribute>
<code>360_Image11</code>
<value/>
</attribute>
<attribute>
<code>360_Image12</code>
<value/>
</attribute>
<attribute>
<code>360_Image13</code>
<value/>
</attribute>
<attribute>
<code>360_Image14</code>
<value/>
</attribute>
<attribute>
<code>360_Image15</code>
<value/>
</attribute>
<attribute>
<code>360_Image16</code>
<value/>
</attribute>
<attribute>
<code>360_Image17</code>
<value/>
</attribute>
<attribute>
<code>360_Image18</code>
<value/>
</attribute>
<attribute>
<code>360_Image19</code>
<value/>
</attribute>
<attribute>
<code>360_Image20</code>
<value/>
</attribute>
<attribute>
<code>360_Image21</code>
<value/>
</attribute>
<attribute>
<code>360_Image22</code>
<value/>
</attribute>
<attribute>
<code>360_Image23</code>
<value/>
</attribute>
<attribute>
<code>360_Image24</code>
<value/>
</attribute>
<attribute>
<code>360_Image25</code>
<value/>
</attribute>
<attribute>
<code>360_Image26</code>
<value/>
</attribute>
<attribute>
<code>Trigger_Synchro_Semarchy_TimeStamp</code>
<value/>
</attribute>
<attribute>
<code>Image_Dimensions</code>
<value/>
</attribute>
<attribute>
<code>Image_Energy_Label</code>
<value/>
</attribute>
<attribute>
<code>A0002</code>
<value/>
</attribute>
<attribute>
<code>A7415</code>
<value/>
</attribute>
<attribute>
<code>A2618</code>
<value/>
</attribute>
<attribute>
<code>A3115</code>
<value/>
</attribute>
<attribute>
<code>A1114</code>
<value/>
</attribute>
<attribute>
<code>A2596</code>
<value/>
</attribute>
<attribute>
<code>A3537</code>
<value/>
</attribute>
<attribute>
<code>A2599</code>
<value/>
</attribute>
<attribute>
<code>A3575</code>
<value/>
</attribute>
<attribute>
<code>A0001</code>
<value/>
</attribute>
<attribute>
<code>A2602</code>
<value/>
</attribute>
<attribute>
<code>A0485</code>
<value/>
</attribute>
<attribute>
<code>A3236</code>
<value/>
</attribute>
<attribute>
<code>A3195</code>
<value/>
</attribute>
<attribute>
<code>A2598</code>
<value/>
</attribute>
<attribute>
<code>A7435</code>
<value/>
</attribute>
<attribute>
<code>A3235</code>
<value/>
</attribute>
<attribute>
<code>A2617</code>
<value/>
</attribute>
<attribute>
<code>A2603</code>
<value/>
</attribute>
<attribute>
<code>A2604</code>
<value/>
</attribute>
<attribute>
<code>A2597</code>
<value/>
</attribute>
<attribute>
<code>A3775</code>
<value/>
</attribute>
<attribute>
<code>A3275</code>
<value/>
</attribute>
<attribute>
<code>A3135</code>
<value/>
</attribute>
<attribute>
<code>A2635</code>
<value/>
</attribute>
<attribute>
<code>A2600</code>
<value/>
</attribute>
<attribute>
<code>A2995</code>
<value/>
</attribute>
<attribute>
<code>A3576</code>
<value/>
</attribute>
<attribute>
<code>A2975</code>
<value/>
</attribute>
<attribute>
<code>A3295</code>
<value/>
</attribute>
<attribute>
<code>A2605</code>
<value/>
</attribute>
<attribute>
<code>A3895</code>
<value/>
</attribute>
<attribute>
<code>A8142</code>
<value/>
</attribute>
<attribute>
<code>A8195</code>
<value/>
</attribute>
<attribute>
<code>A8136</code>
<value/>
</attribute>
<attribute>
<code>A8155</code>
<value/>
</attribute>
<attribute>
<code>A8175</code>
<value/>
</attribute>
<attribute>
<code>A8137</code>
<value/>
</attribute>
<attribute>
<code>A8139</code>
<value/>
</attribute>
<attribute>
<code>A8138</code>
<value/>
</attribute>
<attribute>
<code>A8179</code>
<value/>
</attribute>
<attribute>
<code>A8140</code>
<value/>
</attribute>
<attribute>
<code>A8196</code>
<value/>
</attribute>
<attribute>
<code>A8141</code>
<value/>
</attribute>
<attribute>
<code>A8180</code>
<value/>
</attribute>
<attribute>
<code>A8181</code>
<value/>
</attribute>
<attribute>
<code>A8177</code>
<value/>
</attribute>
</product>
</products>
Note: For LaRedoute some attributes are shown in the taxonomy but are only for internal use. We dont want to validate them against the taxonomy if required.
ConceptNumber
ClapID
Product_Alt_Cod
ProductTitle[en_EN]
Description[en_EN]
Video
Animation_Image01
Animation_Image02
Animation_Image03
Animation_Image04
Animation_Image05
Animation_Image06
Animation_Image07
Animation_Image08
Animation_Image09
Animation_Image10
Animation_Image11
Animation_Image12
Animation_Image13
Animation_Image14
Animation_Image15
Animation_Image16
Animation_Image17
Animation_Image18
Animation_Image19
Animation_Image20
Animation_Image21
Animation_Image22
Animation_Image23
Animation_Image24
Animation_Image25
Animation_Image26
Animation_Image27
Animation_Image28
Animation_Image29
Animation_Image30
Animation_Image31
Animation_Image32
Animation_Image33
Animation_Image34
Animation_Image35
Animation_Image36
Animation_Image37
Animation_Image38
Animation_Image39
Animation_Image40
Animation_Image41
Animation_Image42
Animation_Image43
Animation_Image44
Animation_Image45
Animation_Image46
Animation_Image47
Animation_Image48
360_Image01
360_Image02
360_Image03
360_Image04
360_Image05
360_Image06
360_Image07
360_Image08
360_Image09
360_Image10
360_Image11
360_Image12
360_Image13
360_Image14
360_Image15
360_Image16
360_Image17
360_Image18
360_Image19
360_Image20
360_Image21
360_Image22
360_Image23
360_Image24
360_Image25
360_Image26
Image_Dimensions
The Images Mirakl considers images as attributes. La Redoute taxonomy has different kinds of images described below. Some image attributes available in the taxonomy are only for internal purpose and must not be pushed by vendors. Others like main image are mandatory or highly recommended (Master_Product_Main_Image or Image_2).
- Master_Product_Main_Image (OPTIONAL) : It is the image displayed in product list page. If not filled, the main image of an article will be picked from the product.
- Master_Product_Alternative_Image_1, Master Product Alternative Image 2, etc. (OPTIONAL) : Not displayed on front website. Should not be used.
- Main_image (MANDATORY) : Main article image.
- Image_2, Image_3, etc. (OPTIONAL) : Secondary article images (highly recommended).
- Animation_Image01, Animation_Image02, etc. (OPTIONAL) : Internal use only.
- 360_Image01, 360_Image02, etc. (OPTIONAL) : Internal use only.
- Image_Dimensions (OPTIONAL) : Internal use only.
Category |
Product category | Yes | Product Account > Primary Category ID | |
ShopSKU |
Shop article Sku | Yes | Product > SKU | |
ProductTitle[fr_FR] |
Product title | Yes | Product Account > Title | |
EAN |
Product EAN | Yes | Product Account > Marketplace EAN |
Product > EAN | If we do not have EAN filled, we should display an error ( EAN is required and we could not proceed to product creation without EAN)
Product Account > Marketplace EAN is with priority |
| Brand | Brand of the product | Yes | Product Account> Item specifics
Product > Brand | Product Account > Item Specifics is with priority |
| ProductID | Link between Variants of a same product | Yes | (v1.2)Product Account > Variation Group
Product > SKU | (v1.2)As this field is mandatory we want to have a logic and if the Product Account > Variation Group is not populated and we are listing single product to get the Product > SKU |
| Description[fr_FR] | Product description French | Yes | Product Account > Description | |
| Doc_installation_instructions | | No | Product Account> Item specifics | |
| Doc_reparability_index | | No | Product Account> Item specifics | |
| Master_Product_Main_Image | | No | Product > Listing Image | |
| Image1 | Main product image | Yes | Product > Main Image or Product Account LaRedoute > Main Image | |
| Image2 | More product images | No | Product > More Picture URLs or Product Account LaRedoute > More Images | |
| Image3 | More product images | No | Product > More Picture URLs or Product Account LaRedoute > More Images | |
| Image4 | More product images | No | Product > More Picture URLs or Product Account LaRedoute > More Images | |
| Image5 | More product images | No | Product > More Picture URLs or Product Account LaRedoute > More Images | |
| Image6 | More product images | No | Product > More Picture URLs or Product Account LaRedoute > More Images | |
| Image_Energy_Label | | | Product Account> Item specifics | |
<product_import_tracking>
</product_import_tracking>
API Docs: https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#P42
Example response:
<import_id>2005</import_id>
<new_product_report>false</new_product_report>
<has_transformation_error_report>false</has_transformation_error_report>
<shop_id>2000</shop_id>
Depends on the response of:
"error_report" and "transformation_error_report" we will need to call each of the error reports if we receive "true".
When both "error_report" and "transformation_error_report" are equal to “false“ is the success case (Import status = Completed) and we could proceed to creating and offer to this product.
If we receive success (When both "error_report" and "transformation_error_report" are equal to “false“ ) we can proceed to following:
We need to perform this call if we receive error_report = true, into the response from P42;
API Docs: https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#P44
Sample file
This call returns if the import is successful and how may warnings and errors we have in the file. We need to call this if we receive transformation_error_report= true
API Docs: https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#P47
Sample file -
Closed -will stop all the creation of the products to the MPs.
