Secret Sales Taxonomy
| 1.0 | 04/05/2023 | Hristiyan Georgiev | First publish |
API Call:/api/hierarchies
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#H11
"hierarchies": [
"code": "accessories",
"label": "Accessories",
"label_translations": [
"locale": "en",
"value": "Accessories"
"locale": "en_GB",
"level": 1,
"parent_code": ""
"code": "accesbags",
"label": "Bags",
"locale": "en",
"value": "Bags"
"locale": "en_GB",
"value": "Bags"
"level": 2,
"parent_code": "accessories"
"code": "bagsbackpacks",
"label": "Backpacks",
"locale": "en",
"value": "Backpacks"
"locale": "en_GB",
"level": 3,
"parent_code": "accesbags"
Response file :
The link between categories and attributes is the code = hierarchy_code
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#PM11
"attributes" : [ {
"code" : "category",
"default_value" : null,
"description" : "Category",
"description_translations" : [ {
"locale" : "en",
"value" : "Category"
"example" : null,
"hierarchy_code" : "",
"label" : "Category",
"label_translations" : [ {
"locale" : "en",
"required" : true,
"requirement_level" : "REQUIRED",
"roles" : [ {
"parameters" : [ ],
"type" : "CATEGORY"
"type" : "TEXT",
"type_parameter" : null,
"type_parameters" : null,
"values" : null,
"values_list" : null,
"variant" : false
"code" : "shop_sku",
"description" : "Shop SKU",
"locale" : "en",
"value" : "Shop SKU"
"example" : null,
"label" : "Shop SKU",
"locale" : "en",
"required" : true,
"roles" : [ {
"parameters" : [ ],
"type" : "SHOP_SKU"
"type" : "TEXT",
"values" : null,
"variant" : false
Response file :
The link between attributes and values is type_parameter = code
API Call: /api/values_lists
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#VL11
"values_lists" : [ {
"code" : "Activity",
"label" : "Activity",
"locale" : "en",
"value" : "Activity"
"locale" : "en_GB",
"values" : [ {
"code" : "gym_training",
"label" : "Gym & Training",
"locale" : "en",
"value" : "Gym & Training"
"locale" : "en_GB",
"code" : "lifestyle",
"label" : "Lifestyle",
"locale" : "en",
"value" : "Lifestyle"
"locale" : "en_GB",
"code" : "yoga",
"label" : "Yoga",
"locale" : "en",
"value" : "Yoga"
"locale" : "en_GB",
"value" : "Yoga"
Response file :
Taxonomy export file
In order to generate the taxonomy file we will need to create a new record in Taxonomy export with: Marketplace = Secret Sales Status = pending Category for Export = all (or we can specify which exact categories) Email = email to which the file will be send
Please find ore details on the file structure how it should look like after exported here - Taxonomy General requirements .
