ASOS - Delete Offer
| 03/10/2022 | 1.0 | Bogomil Pavlov | MP feed type updated |
| 01.02.23 | 1.1 | Bogomil Pavlov | Split the flow to two separate feeds with and without prices |
"update_delete": "delete"
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#OF01
Mapping is the same as ASOS- Offer Stock Update
Аfter successful product creation should have Channel Item ID, which for MIRAKL integration is the SKU!
Product status = Product Published ; Listing Status = Active; End Listing = Yes
If error, we will have:
Product status = Product Published ; Listing Status = Active; End Listing = Error
"import_id": 2035
API Docs:https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#OF02
