Showroom Prive Create Offer
| 1.0 | First Published |
The purpose of this page is to describe in details the process of creating offer to already existing product on MIRAKL.
To create offer we should use following API calls - POST OF01 (Import a file to add offers), GET OF02 (Get information and statistics about an offer import), GET OF03 (Get the error report file for an offer import)
Please note that in order to pick the product for offer creation we will need to have Channel Item Id and all relevant internal flags (described in additional information)
Create offer cron should pick products only with statuses:
Product status = Product created and Listing Status = Inactive and List/Update the whole item =Pending
When the offer is successfully sent for creation we will set:
Product status = Product created and Listing Status = Inactive and List/Update the whole item =Sent
When the offer is created, we set statuses:
Product status - Product Published and Listing Status - Active and List/Update the whole item =Not Needed
If there is an error during offer creation, we will set following statuses:
Product status = Product created and Listing Status = Inactive and List/Update the whole item =Error
and we need to store the relevant error in Update Item Error field
API Docs: {{TBA}}
Example file:
{{TBA}}
sku |
product-id |
| product-id-type | | Yes | hardcoded as “EAN“ | Must be UPPERCASE |
| description | Offer description - Recommended - Maximum 2000 characters | No | Product Account > Description | |
| internal-description | The description of the offer as shown in the back office view - Optional - Maximum 2000 characters | No | N/A | |
| price | The selling price in the currency.
| price-additional-info | Information regarding the price of the offer.
The accepted values are defined from the Mirakl back office | Required | Product > Condition | Mapping to our conditions:
11- New > 1000;
1-Excellent > 1500;
2-Very Good >4000;
3-Good >5000;
4-Sufficient >6000;
5-Refurbished_like_new > 2750
6-Refurnished_very_good >2500
7-Refurbished_good > 2000
| available-start-date | The first day the offer becomes available. The offer has no start date if blank.
yyyy-MM-dd
or
yyyy-MM-ddThh:mm:ss+00
| No | N/A | |
| available-end-date | The last day the offer is available. The offer has no end date if blank.
yyyy-MM-dd
or
| No | N/A | |
| discount-price | | No | Product Account > Price | If RRP > Price
If RRP <= Price
discount-start-date| | No | Product Account Yoox> Discount Start Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcoded current date (“NOW“) Date format -2017-02-20T10:45:53+01If RRP <= Price We include the discount fields with empty values | |discount-end-date| | No | Product Account Yoox > Discount End Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcode current date + 2 year (“NOW“ +2y) Date format -2017-02-20T10:45:53+01If RRP <= Price We include the discount fields with empty values | |update-delete| Used only in "Normal" import mode. Update mode is used if blank. "", "update", "delete" | No | N/A | |
<offer_import_tracking>
</offer_import_tracking>
| Marketplace Feed > Type | Hardcoded as “Offer Create“ | |
API Docs: {{TBA}}
"date_created": "2019-04-01T15:16:31Z",
"has_error_report": false,
"import_id": 2035,
"lines_in_error": 0,
"lines_in_pending": 0,
"lines_in_success": 1,
"lines_read": 1,
"mode": "NORMAL",
"offer_deleted": 0,
"offer_inserted": 1,
"offer_updated": 0,
"status": "COMPLETE"
Success case (once the offer is created successfully)
API Docs: {{TBA}}
