Get Feature Inventory PHASE 2
| v1.0 | 05.03.2025 | Bogomil Pavlov | First publish |
Returns a list of features available for Multi-Channel Fulfillment orders in the marketplace you specify, and whether the seller for which you made the call is enrolled for each feature.
API Call : GET /fba/outbound/2020-07-01/features/inventory/{featureName}
Query Parameters:
marketplaceId
Sample Request:
GET [https://sellingpartnerapi-na.amazon.com](https://sellingpartnerapi-na.amazon.com/fba/outbound/2020-07-01/features?marketplaceId=ATVPDKIKX0DER)/fba/outbound/2020-07-01/features/inventory/TEST_FEATURE
Sample Response:
"payload": {
"features": [
"marketplaceId": "ATVPDKIKX0DER",
"featureName": "TEST_FEATURE",
"nextToken": null,
"featureSkus": [
"sellerSku": "sellerSku1",
"fnSku": "fnSku",
"asin": "asin",
"skuCount": 23,
"overlappingSkus": [
"sellerSku2",
"sellerSku3",
"sellerSku4"
"sellerSku": "sellerSku2",
"fnSku": "sadf",
"asin": "ssss",
"skuCount": 1,
"sellerSku1",
"sellerSku3",
"sellerSku4"
Response Mapping:
| Amazon Field | Hemi Field | Comment | |
