OMSPro Create Reverse Return
| 30.05.2025 | 1.0 | Milen Markov | First Publish |
The purpose of this document is to give good explanation on how we can send a reverse return to OMSpro.
The idea of this call is if we receive a return cancellation from Trendyol (when a buyer initially creates a return request but then cancels it), we need to push this return cancellation to OMSPro as well.
API Test Endpoint: PUT https://puma-test.openoms.net:8084/HEMI/ReverseReturnOrder
API Live Endpoint: PUT [https://pumame.omspro.com:8080/HEMI/ReverseReturnOrder](https://pumame.omspro.com:8080/HEMI/ReverseReturnOrder)
We want to introduce a new field in Channel OMS called Send Claim Cancellation - boolean field with default value “No”. We should send such cancellations only if field is selected as “Yes”
Then we are to trigger such an update to OMSPro when we have an Order Claim > Claim Status = Rejected and Order Claim > Rejected by = Buyer from the marketplace
We also want to track the connector status that it has been sent so we want to also include in the check that Claim Connector > Connector Status = Created . This way we will ensure that we send only the created claims 🙂 (For reference on Claim Connector table please see v1.6 explanation here)
We also want to check if Status field is “normal” or “pending”. Both should be a trigger for sending the Reverse Return if all other requirements are met.
As we want to track the sending if success or not we will need to track this somewhere - we suggest to create a general “Connector” table under the claim which is to be used for multiple connectors as and if needed - table should have a connector ID (to show which connector is communicating with this claim) and a status for the connection (standard MCP Status field with pending, sent, error, normal statuses.
IF this approach is taken then we should select for sending all claims that are “Cancelled” (as mentioned above) that don’t have a record or have a record on “pending” status
Example Request:
"order_no": "TEST5436437",
"ref_no1": "8709",
"invoice_no": "1014026421",
"reason_code": "R00",
"reason_name": "R00-Marketplace Reverse Return",
"return_comments": "",
"return_date": "2025-05-30 08:12:09",
"return_type": "",
"application_id": "Trendyol",
"created_by": "HEMI"
Request Mapping:
| OMSPro field | Hemi Field | Required | Notes | |
order_no |
Orders > Marketplace Order ID |
Yes | ||
ref_no1 |
Order Claim > ID |
Yes | ||
invoice_no |
Orders > ID |
Yes | ||
reason_code |
Yes | Hardcoded as “R00” | ||
reason_name |
Yes | Hardcoded as “R00-Marketplace Reverse Return” | ||
return_comments |
Order Claim > Marketplace Reason |
No | ||
return_date |
Order Claim > Marketplace Date |
Yes | ||
| Needs to be in format “YYYY-MM-DD HH:MM:SS” | ||||
return_type |
N/A | No | ||
application_id |
Channel OMS > Application ID |
No | NEW FIELD |
String to be picked and sent from the relevant set channel |
| created_by | | N/A | No | Hardcoded as “HEMI” |
"success": true,
"message": "",
"error_code": 0,
"data": {
"application_id": "HEMI",
"b_address_1": "Trendyol Address",
"b_city": "Abu Dhabi",
"b_country": "AE",
"b_email_address": "trendyolbuyer@trendyol.com",
"b_first_name": "TrendyolUser",
"b_last_name": "Customer",
"b_phone": "4198274319284",
"b_state": "",
"b_zip_code": "",
"capture_amount": 696,
"capture_status": "CAPTURE_SUCCESS",
"cod_fee": 0,
"country_id": "AE",
"created_by": "HEMI",
"created_date": "2025-05-30T15:15:27.953",
"currency_id": "AED",
"custom_duty_fee": 0,
"customer_name": "Trendyol Customer",
"customer_type": "Registered",
"delivery_date": "2025-05-29T07:12:09",
"email": "Trendyoluser@Trendyol.com",
"import_vat_fee": 0,
"line_discount_amount": 0,
"order_amount": 696,
"order_date": "2025-05-29T07:12:09",
"order_quantity": 4,
"order_status": "SHIPPED",
"payment_amount": 696,
"payment_date": "2025-05-29T07:12:09",
"payment_method": "Trendyol",
"payment_status": "CAPTURE_SUCCESS",
"reason_code": "R99",
"reason_name": "R99-Marketplace Return",
"ref_no": "1014026421",
"ref_no1": "8711",
"refund_status": "CANCELLED",
"return_amount": 169,
"return_date": "2025-05-30T15:15:27.953",
"return_order_comments": [
"_id": "0DDAD1A6-F800-439D-83A6-C746F961AD9A",
"comment": "Return Order is created!",
"id": "0DDAD1A6-F800-439D-83A6-C746F961AD9A",
"rma_no": "TEST5436437R3",
"user_name": "HEMI"
"_id": "E84E07A1-2601-4628-BC2E-C04C08B6225E",
"comment": "Return Order TEST5436437R3 is created by HEMI",
"created_date": "2025-05-30T15:37:08.433",
"id": "E84E07A1-2601-4628-BC2E-C04C08B6225E",
"user_name": "HEMI"
"return_order_details": [
"_id": "7CC4BF0F-4773-4A02-AB71-248C4644FDCF",
"a_quantity": 0,
"accepted_quantity": 0,
"b_quantity": 0,
"c_quantity": 0,
"cancel_quantity": 0,
"description": "Future Rider Play On Mens Low Top Trainer Shoes",
"description_2": "جاكيت رياضي Iconic T7 للنساء",
"id": "7CC4BF0F-4773-4A02-AB71-248C4644FDCF",
"mark_down": 0,
"order_line_no": "406369705475222222",
"order_quantity": 2,
"original_price": "349.00",
"price": 169,
"product_color": "Puma Black",
"product_id": "4063697054752",
"product_ref1": "",
"product_ref2": "530078_01",
"product_ref3": "",
"product_size": "S",
"product_uom": "",
"quantity": 1,
"rejected_quantity": 0,
"return_line_no": "406369705475222222",
"return_line_status": "REVERSED",
"shipping_fee": 0,
"sub_total": 169
"return_order_payments": [
"id": "",
"payment_type": "",
"return_order_status_details": [
"_id": "3DFFF029-CC89-45BB-8AAA-6752FC6E3776",
"date": "2025-05-30T15:15:27.953",
"from_status": "",
"id": "3DFFF029-CC89-45BB-8AAA-6752FC6E3776",
"return_line_no": "",
"to_status": "RETURNED"
"_id": "BD9B4F1E-AE7C-42F6-9038-987C0A1A6BF7",
"date": "2025-05-30T15:37:08.433",
"from_status": "RETURNED",
"id": "BD9B4F1E-AE7C-42F6-9038-987C0A1A6BF7",
"to_status": "REVERSED"
"return_quantity": 1,
"return_status": "REVERSED",
"return_tracking_no": "RETURNTEST5436437",
"s_address_1": "Trendyol Address",
"s_city": "Abu Dhabi",
"s_country": "AE",
"s_email_address": "Trendyoluser@Trendyol.com",
"s_first_name": "Trendyol",
"s_last_name": "Customer",
"s_phone": "4198274319284",
"s_state": "",
"s_zip_code": "",
"sales_channel_id": "Trendyol",
"sales_channel_name": "Trendyol",
"sap_export": false,
"seq_no": 30254,
"shipped_date": "2025-05-30T12:52:22.230",
"shipping_carrier": "Trendyol",
"shipping_fee": 0,
"shipping_method": "Standard",
"shipping_status": "SHIPPED",
"shipping_tracking_no": "17051",
"site_id": "UAE",
"total_shipping_fee": 0,
"updated_date": "2025-05-30T15:37:08.433"
If Success - mark connector claim as “normal” and Connector Status = “Cancelled”
Sample error response:
"success": false,
"message": "RMA Not found",
"error_code": -1,
"data": null
If Error - mark connector claim as “error”. Also from the error response we want to store the message and create a record in Order Error with Type = “Connector”
