Products management
The purpose of this page is to describe how we should structure our general content management (listing and updates), through what statuses it should go and what information is needed
| Version | Created / Updated by | Notes |
| 1.0 | Danail Deltchev | Initial Version |
| 1.1 | Danail Deltchev | Change in product Mappings: New fields for Documents, Videos and Technical Detail where we have a key/value pair are to be of type “ItemSpecifics” not “More Images” |
| Added technical details check for uniqueness | ||
| 1.2 | Danail Deltchev | Changes in: |
• Get Products - due to OPCs not properly presented in Queue response for variants we need to Get them separately) • Create product - based on latest conversations we CAN NOT create/add variants to an already existing VariationGroupId and in case this is happening we need to send as new group • Update product - as we can’t add new variants to an existing one we need to skip them based on status. Also it was communicated to us we can’t push product updates to products not created by us, so this is to be tracked by Get products as well and taken in consideration by Update products | | 1.3 | Danail Deltchev | Changes in: • Update products - style of updating: when/how/what • Images handling - small change to what is allocated between variant and parent |
API docs: https://docs.api.onbuy.com/#products & https://docs.api.onbuy.com/#98f148b9-104d-41c4-b816-2980f6268d4d
The first section describes the flow of sending data and working with OnBuy’s batches. The second is the direct link to the Products management APIs section
A few things to be said initially before going into details
- OnBuy operate on a catalogue base - meaning there is only one record per EAN in their system and different sellers can create listings against that product
- Based on the above they operate on creating products and sending listings against them afterwards. The products can roughly be split into two sections Master and Variant. There are many tags that can be send either in one or the other or duplicated. Below you will see information where we should send different information to the best of my knowledge
- On Buy work with unique codes called OPC (OnBuy Product Code) which is the equivalent of a ChannelItemId
- We will heavily work with Product Status and Listing Status to maintain to the best of our ability knowledge at what stage is the product
- If we are creating a variation product we will receive an OPC for the master (which is a nonexistent record in Hemisphere) and an OPC for every variant (both need to be stored)
- Based on further investigation and conversations we’ve uncovered that specific sets of information can be updated and some can be updated only on a certain level. Distribution goes like this:
- Parent level:
- Brand
- Category
- Name
- Variant:
- MPN (in case the whole product has any variants)
- RRP (in case the whole product has any variants)
- Both:
- Description
- Summary Points
- default_image
- additional_images
- features
- videos
- documents
- product_data
- technical_detail
- Parent level:
Products flow - we want to follow MP best practices and optimise our processes at the same time. For OnBuy we want to do the following:
- Call for EANs - If the EAN is present it should be respectively marked in Hemisphere to continue further communication with OnBuy without the need to create the product (note: if the product already exists we want to mark it as “not created by us” so we don’t send product updates for it later). This step is to be done only if the product is not marked as “created” in Hemisphere
- If the product is not present we should proceed with sending all the information to OnBuy
- Submit product data
- Read initial validation - Error or Queued
- Check Queue
- Read final status - Error or Created
- Read variant OPCs
GET Products:
API Docs: https://docs.api.onbuy.com/#c6ccd9b0-8e0f-4165-b65a-a6a520fe6c9d
API Call: https://api.onbuy.com/v2/products
Purpose: To retrieve by EAN already existing products on OnBuy to decide if product creation step is required OR download the OPCs of variants we’ve created
Fields and Specifics
| Name | Type | Required | Details | WAP Mapping | WAP Notes | |||
| site_id | integer | YES | target site. Default is 2000 |
Type:
integer
Example:
2000 | | | | By country of MP | As briefly discussed can be 2000 to start off as we are not expecting other OnBuy sites soon |
| filter | array | NO | Key | Type | Required | Details | | |
| | | | query | string | NO | specify a keyword search for product information
Type:
string
Example:
bar | N/A | |
| | | | field | string | NO | defines which field the filter[query] should be matched with
Type:
string
Example:
opc
field can be one of the following values: • name • product_code • opc • mpn | EAN | Use “Product_code” for the mapping with OnBuy which is the equivalent of EAN | | | | | category_id | integer | NO | defines which product category in with the search should be performed Type:
integer
Example:
8 | N/A | |
| limit | integer | NO | The number of results to return. Max value 100
Type:
integer
Example:
34 | | | | N/A | We are expecting a single result by Product_code |
| offset | integer | NO | The batch of results to return
Type:
integer
Example:
34 | | | | N/A | |
Actions:
- To fire up this function we are looking for products on
revise_item= “pending“,ChannelItemId= Empty value andproduct_status= “awaiting_creation“ or Empty value. We are to check every such item if it is present on OnBuy.- If it is present we should store it’s OPC in
ChannelItemIdand initem_account_onbuy.OPC, mark the product as not created by us initem_account_onbuy.dont_manage_content= “yes” and set theproduct_statusto “product_created“ - If it is not present we should prepare the item for creation step. The way I see it it should all happen together so if the product is not created on OnBuy it can directly be pushed for creation (stored and bundled for creation on multiple products at once). If decided we need to store in DB after the search operation we might need to add another
product_statusto perfectly capture this
- The second option to check for OPC is if we have a product that is on
revise_item= “normal“,ChannelItemId!= Empty value,product_status= “product)published“ anditem_account_onbuy.OPC= Empty value- If it is present we should store it’s OPC only in
item_account_onbuy.OPC - If not present we should store an error on
revise_item_error= “Variant OPC missing“
POST Product create:
API Docs: https://docs.api.onbuy.com/#4bb6d39a-c7c7-45a1-8a6c-d93edc47bba4
Purpose: Sending product data for creation to OnBuy
Note: Before reading the below:
- In the WAP Notes there will be a list of where a section is expected if single or if Variant listing
- All sections can be on Parent/Master section even if it is a variation but the following: Barcode, Listing details, Variant details
- We want only the relevant images in the relevant section. We still want to associate more images to both Parent/Master and the Variant due to further uncovered information on how this is handled within OnBuy
- It is possible that only Brand_name OR Brand_id is needed - we should test this - in both cases we will need to pull available brands down as part of the taxonomy
- Variations in Hemisphere are recognised by the grouping element VariationGroup on item_account
Fields and Specifics:
| Name | Type | Required | Details | WAP Mapping | WAP Notes | ||||||
| site_id | integer | YES | target site. Use the /v2/sites method to obtain a list of site IDs. |
Type:
integer
Example:
2000 | | | | | | | By country of MP | As briefly discussed can be 2000 to start off as we are not expecting other OnBuy sites soon |
| category_id | integer | YES | Use the /v2/categories method to obtain a list of category IDs.
Type:
integer
Example:
125 | | | | | | | item_account > Primary Category ID | Should always be on the Master section |
| published | boolean | NO | specifies whether the product should be published to the site once it's created. Products not published will need to be completed through the SCP. This can be used to review the product before it is displayed publically. Please be aware that products that are not marked as published are automatically cleared from the system after 72 hours. Use 1 for published and 0 for not published.
Type:
boolean
Example:
1 | | | | | | | 1 | Always Yes. We don’t want to have any manual steps in the process
| product_name | string | YES | the name of the product
Type:
string
Example:
bar | | | | | | | item_account > Title | Should always be on the Master section |
| mpn | string | NO | manufacturer's product reference number
Type:
string
Example:
EXAMPLE-cdce953d-abbe-4626-ac9d-0806a5611ad9 | | | | | | | item > MPN | If variation listing should be in Variant details section in the API |
| product_codes | array | YES | a list of EAN-13 barcode number (strings)
Type:
array
Example:
[] | | | | | | | item > EAN | If variation listing should be in Variant details section in the API |
| summary_points | array | NO | a list of product summary points (strings)
Type:
array
Example:
[] | | | | | | | N/A | |
| description | string | NO | a description of the product
Type:
string
Example:
bar | | | | | | | item_account ? Description | Should always be on the Master section.
Field supports HTML |
| brand_name | string | YES | the name of the brand
Type:
string
Example:
bar | | | | | | | item_account > Item Specifics | Should always be on the Master section |
| brand_id | integer | YES | Use the /v2/brands method to obtain a list of brand_ids. Use 1 for Unbranded products.
Type:
integer
Example:
16 | | | | | | | item_account > Item Specifics | Should be validated through the Brands of OnBuy. If matched send proper ID if not send 1
| videos | array | NO | Key | Type | Required | Details | | | | This section can either be in the Master or Variant part of the API call depending if the product is Single or Variation listing | |
| | | | label | string | NO | short label of the video entry
Type:
string
Example:
foo | | | | item_account_onbuy > {{New Field}} Videos | Field like ItemSpecifics
If variation listing should be checked for uniqueness on all variant participants. If all are the same push on Master level. If even one is different every single one should be on Variant level |
| | | | url | string | NO | location of the video stream
Type:
string
Example:
https://example.com/path-to-resource/ | | | | | |
| documents | array | NO | Key | Type | Required | Details | | | | This section can either be in the Master or Variant part of the API call depending if the product is Single or Variation listing | |
| | | | label | string | NO | short label of the document
Type:
string
Example:
foo | | | | item_account_onbuy > {{New Field}} Documents | Field like ItemSpecifics
| | | | url | string | NO | location of this product document
Type:
string
Example:
| default_image | string | NO | url to the primary product image
Type:
string
Example:
foo | | | | | | | item_account_onbuy > Main Image
OR item > Listing Image
OR item > Main Image | If item_account_onbuy has main images filled in we should use all images only from there . If not move to item based on the mapping order.
We should always apply the following logic: if images on all products are the same put one default on the Master and the same on the Variants. If they are different chose the first for the Master and each Variant should have its own Main Image as default_image
In the rare case there is a Listing Image it doesn’t need checks for uniqueness. Pick it as default for the Master. The Variants still get their respective Main Image as default_image |
| additional_images | array | NO | string values of additional image urls
Type:
array
Example:
[] | | | | | | | item_account_onbuy > more images
OR item > more images | In case there are more images and they are the same across the whole variation listing we should send the same set of images for both the Parent/Master and each variant as part of the additiona_images section.
If there is even one difference on Parent/Master level we should send a selection of only the different main_images as additional_images where for each Variant we are to send its own more_images as additional_images |
| rrp | decimal | NO | Recommended Retail Price
Type:
decimal
Example:
14.83 | | | | | | | item_account > RRP | If single on the Master section. If variation listing in the Variant section |
| product_data | array | NO | Key | Type | Required | Details | | | | N/A | |
| | | | label | string | NO | key of this paricular key/value pair
Type:
string
Example:
bar | | | | N/A | |
| | | | value | string | NO | value of this paricular key/value pair
Type:
string
Example:
foo | | | | N/A | |
| | | | group | string | NO | name of a group which describes these attributes
Type:
string
Example:
foo | | | | N/A | |
| listings | array | NO | Key | Type | Required | Details | | | | This section can either be in the Master or Variant part of the API call depending if the product is Single or Variation listing | |
| | | | new | array | NO | Key | Type | Required | Details | | |
| | | | | | | sku | string | NO | product SKU
Type:
string
Example:
EXP-143-33S | item > SKU | |
| | | | | | | group_sku | string | NO | an identifier used to group listings together
Type:
string
Example:
bar | item_account > VariationGroup | |
| | | | | | | price | decimal | NO | price of this item
Type:
decimal
Example:
14.83 | item_account > StartPrice | |
| | | | | | | stock | integer | NO | number of items in stock
Type:
integer
Example:
8 | item_account > Quantity | |
| | | | | | | handling_time | integer | NO | number of days within which the item will be dispatched
Type:
integer
Example:
125 | item_account > DispatchTimeMax
OR item_account > Shipping Template > DispatchTimeMax
OR Account > Default Shipping Template > DispatchTimeMax | |
| | | | | | | return_time | integer | NO | number of days within which the item can be returned
Type:
integer
Example:
7 | N/A | |
| | | | | | | free_returns | string | NO | specify whether to accept free returns; "yes" or "no"
Type:
string
Example:
foo | N/A | |
| | | | | | | warranty | integer | NO | number of months within which the warranty is valid
Type:
integer
Example:
252 | N/A | |
| | | | | | | delivery_template_id | integer | NO | overrides the default delivery template, for possible values @see #
Type:
integer
Example:
7 | item_account chosen OR Default Shipping Template > Shipping Method > Shipping service | |
| | | | | | | condition_notes | array | NO | list of strings describing more information about the condition of this item
Type:
array
Example:
[] | item_account > Condition Description | |
| features | array | NO | Key | Type | Required | Details | | | | | |
| | | | option_id | integer | NO | Use the /v2/categories/{{category_id}}/features method to obtain a list of valid features for the specified category.
Type:
integer
Example:
16 | | | | item_account > Item Specifics | If MP taxonomy is present in DB make validations to push through. Otherwise send as is
All same Attributes to go on Master level. Different Attributes to go on Variant levels (always only from IS, VS is another story) |
| | | | name | string | NO | optionally specify a 'name' parameter to override the existing name.
Type:
string
Example:
foo | | | | item_account > Item Specifics | If MP taxonomy is present in DB make validations to push through. Otherwise send as is
| | | | hex | string | NO | optionally specify a hexadecimal colour value
Type:
string
Example:
bar | | | | N/A | |
| technical_detail | array | NO | Key | Type | Required | Details | | | | | |
| | | | detail_id | integer | NO | Use the /v2/categories/{{category_id}}/technical-details method to obtain a list of valid detail ids for the specified category
Type:
integer
Example:
34 | | | | item_account_onbuy > {{New Field}} Technical Details | Field of type ItemSpecifics
All same Technical Details to go on Master level. Different Technical Details to go on Variant levels |
| | | | value | string | NO | the value of this key/value pair
Type:
string
Example:
foo | | | | | |
| | | | unit | string | NO | optionally override the default unit display
Type:
string
Example:
bar | | | | N/A | |
| variant_1 | array | NO | Key | Type | Required | Details | | | | | |
| | | | name | string | NO | custom name of the first type of variation
Type:
string
Example:
bar | | | | item_account > Variation Specifics | This field only specifies the Name of the variation. If it will vary by colour, by size, by material, by memory, by number of buttons, doesn’t matter |
| variant_2 | array | NO | Key | Type | Required | Details | | | | | |
| | | | name | string | NO | custom name of the second type of variation
Type:
string
Example:
foo | | | | item_account > Variation Specifics | This field only specifies the Name of the variation. If it will vary by colour, by size, by material, by memory, by number of buttons, doesn’t matter |
| variants | array | NO | Key | Type | Required | Details | | | | In this section goes all the information discussed as Master or Variant (please see example) | |
| | | | variant_1 | array | YES | product variant category #1
Type:
array
Example:
[] | | | | item_account > Variation Specifics | This will be the single value for the specific Item we are adding (Example: Red) |
| | | | variant_2 | array | YES | product variant category #2
Type:
array
Example:
[] | | | | item_account > Variation Specifics | This will be the single value for the specific Item we are adding (Example: XL) |
| | | | listings | array | YES | 'listing object' data, keyed on condition (string). (See 'listings' parameter above)
Type:
array
Example:
[] | | | | | Please see section Listings above for the available fields |
Note: Please have in mind that for the “Listing” section we should be able to also provide “condition” based on the “Listing Management” information. For the mapping options for that field please refer to the mentioned document. This is happening due to discrepancy in OnBuy’s documentation but they confirmed the Listings should behave the same in both APIs
Example JSON:
"site_id": 2000,
"category_id": "6112",
"brand_name": "Superga",
"product_name": "Superga - 2750-COTU-CLASSIC",
"description": "Superga - 2750-COTU-CLASSIC-eu-46",
"default_image": "https://app.onepatch.co.uk/assets/listingimages/full_24848_36707stock_product_image_98013_1118588329.jpg",
"additional_images": [
"https://app.onepatch.co.uk/assets/listingimages/full_24849_85615stock_product_image_98013_1118588329.jpg",
"https://app.onepatch.co.uk/assets/listingimages/full_24850_36101stock_product_image_98013_1118588329.jpg",
"https://app.onepatch.co.uk/assets/listingimages/full_24851_41457stock_product_image_98013_1118588329.jpg",
"https://app.onepatch.co.uk/assets/listingimages/full_24852_58914stock_product_image_98013_1118588329.jpg",
"https://app.onepatch.co.uk/assets/listingimages/full_24853_82840stock_product_image_98013_1118588329.jpg",
"https://app.onepatch.co.uk/assets/listingimages/full_24854_14702stock_product_image_98013_1118588329.jpg",
"https://app.onepatch.co.uk/assets/listingimages/full_24855_49201stock_product_image_98013_1118588329.jpg",
"https://app.onepatch.co.uk/assets/listingimages/full_24856_49259stock_product_image_98013_1118588329.jpg",
"https://app.onepatch.co.uk/assets/listingimages/full_24857_91717stock_product_image_98013_1118588329.jpg",
"https://app.onepatch.co.uk/assets/listingimages/full_24858_64532stock_product_image_98013_1118588329.jpg"
"published": 1,
"variant_1": {
"name": "Colour"
"variant_2": {
"name": "Shoe Size"
"variants": [
"variant_1": {
"name": "Burgundy"
"variant_2": {
"name": "Size 6"
"listings": {
"new": {
"sku": "2750-COTU-CLASSIC_S000010-A01_BRIGHT-BLUE EU 46",
"price": "53.1",
"stock": 1
"product_codes": [
"5080449921406"
"default_image": "https:\/\/tencate1952.co.uk\/wp-content\/uploads\/2018\/08\/3601-green-print-3.jpg",
"features": [
"option_id": 125,
"name": "Burgundy"
"option_id": 111520
"variant_1": {
"name": "Olive Green"
"variant_2": {
"name": "Size 9"
"listings": {
"new": {
"sku": "1rdlrge",
"price": "19.00",
"stock": 3
"product_codes": [
"5042383257201"
"features": [
"option_id": 93,
"option_id": 111526
Actions:
- Once we’ve determined this product is not available on OnBuy we need to pick it up, bundle it with all others like it and send them for creation. This should either happen by the firs function gathering a list of all products that need to be sent or bi the newly set
product_statusthat will be also onrevise_item= “pending” so we can send the products. - Once we’ve sent the products we should either receive back success or Error
- On Success we should store the Queue IDs to follow through and see the end result
- On Error we should push it back to
revise_item= “error” and store the relevant error (Note: if we use newproduct_statusnext time products go to “pending” they will skip the EAN check which can be both good and bad, TBD)
- If we’ve had success we should start checking the progress of the Queue IDs and reflect back in Hemisphere once they are processed
- On Success set the item_account to
revise_item= “normal“,product_status= “product_published“,listing_status= “active“, the OPC in theChannelItemId - On Error set the item_account to
revise_item= “error“ and store the relevant error
Notes:
- Due to the queue we can’t put all update fields to “normal” once the product is processed as there could’ve been quite a lot of changes while the product was created
- If we are creating the product once completed we are setting everything (
product_statusandlisting_status) to end values as we are sending all the info and the product should be up and selling. In the case of a EAN already being present on OnBuy we will need an additional step to send and create just a listing (Please see “Listings management” section in the OnBuy Scope) - We can send a variation group for creation only once. If at a later stage there is an attempt of sending additional variants with the same VariationGroupId any such are to be automatically set on
revise_item= “error“ with the message: “Additional variants can be added to the already created options. Please change VariationGroupId and send as additional group“
PUT Update Products
API Docs: https://docs.api.onbuy.com/#a3e00100-19e1-402e-a2ad-df0c95efdc78
Purpose: To update product records with information. Call is exactly the same as the POST Products call for creation with the difference that as this is a Batch update it needs to be wrapped in a “Products” section.
Recommendation as coming from OnBuy is to send an update for every OPC. Meaning a separate update for every variant we have and for the master.
We are to send for each OPC only the information that it holds based on the split as explained above in the Creation step and with the additional restrictions posed by OnBuy when updating (point 6 in the beginning of the document)
Notes:
- OPC needs to be provided for every update call
- After additional communication with OnBuy we’ve found we can’t add additional variants to a listing. This means we should be sending Product updates only for products that are on
product_status= “product_published“. Any such (from the same VariationGroupId) that are not created should be skipped and is for the Create call to set them on Error - Also variation names and values can’t be changed once created through the API - can be skipped in the update information
- Additionally for any such items that we don’t own the content management (based on
item_account_onbuy.dont_manage_content= “yes“) we are to set onrevise_item= “error“ with the message: “We don’t manage the content for this product. Only listing updates can be processed“
