Showroom Prive Refund Order
| 1.0 | First Publish |
The refund/cancellation request on MIRAKL is per item line id and we can include each separate item as additional “refund“ or “cancellation“ node. To process the refund/cancellation , we have to specify a reason which need to be added in the Refund UI for {{TBA}} Marketplace. In order to obtain the reasons, we should use GET RE01 - List reasons call and then, to make a refund/cancellation , we should use PUT OR28 - Request a refund or OR30 - Request cancelations on order lines
- GET RE01 - List reasons
API Call:/api/reasons
API Docs: {{TBA}}
Please note we need to store only the reasons which are with type = “REFUND“ and type = “CANCELATION“
Example response:
{{TBA}}
Bear in mind we need to display the label into the UI but to send the code.
Because in our UI we cannot distinguish the refund from the cancellation we need to add in the label what type is the reason is for the refund or for cancellation.
E.G. [REFUND] - {label} or [CANCELATION] - {label}
- PUT OR28 - Request a refund
API Call: /api/orders/refund
API Docs: {{TBA}}
*Note:** Each payment row (type=refund) will need to be send as a separate request. If even one of the refunds failed it will fail the whole feed. Thus we have agreed to push them per payment row. Which means we will have one request with all of the refund row nodes.
Example call: (one item in order)
"refunds": [
"amount": 10.00,
"currency_iso_code": "GBP",
"order_line_id": "Order_25082022-6-A-1",
"quantity": 1,
"reason_code": "15",
"shipping_amount": 2.00
"refunds": [
"amount": 10.00,
"quantity": 1,
"shipping_amount": 0
"amount": 10.00,
"order_line_id": "Order_25082022-6-A-2",
"quantity": 1,
MIRAKL allows us to refund:
- Partially items;
- Shipping
- Orders
refunds |
amount |
Refund Row > Amount | Refund rows with type “item“ | |||
currency_iso_code |
Order > Order currency | ||||
order_line_id |
Order Item >Item Order Line ID | ||||
quantity |
Order Item > Quantity | Based on the Refund Row > Amount we need to calculate the quantity! |
• If we are doing partial line refund we specify the quantity as 0.
• If we are doing full line refund (the full quantity)
we specify the actual quantity we have for the item e.g. 1, 2, 3 etc.
Note: For each full like we are having quantity = 1
For each partial like we will have quantity = 0 |
| | reason_code | | | Order Payment > Reason | We need to use the reason code. |
| | excluded_from_shipment | | | N/A | |
| | shipping_amount | | | Refund Row > Amount | Refund rows with type “shipping “ |
"order_tax_mode": "TAX_INCLUDED",
"refunds": [
"amount": 10.00,
"amount_breakdown": {
"parts": [
"amount": 10.00,
"commissionable": true,
"debitable_from_customer": true,
"payable_to_shop": true
"quantity": 1,
"refund_id": "1109",
"shipping_amount": 2.00,
"shipping_amount_breakdown": {
"parts": [
"amount": 2.00,
"shipping_taxes": [],
"taxes": []
Response Mapping:
order_tax_mode |
refunds |
amount |
N/A | |||||
amount_breakdown |
N/A | |||||
currency_iso_code |
N/A | |||||
N/A | |||||
order_line_id |
N/A | This will be used for the mapping | ||||
quantity |
N/A | |||||
reason_code |
N/A | |||||
refund_id |
Order Payment Details > Transaction ID | Because each order item is pushed in a separate transaction we will receive more than one refund_id thus we will have to concatenate them with “-“ | ||||
shipping_amount |
shipping_amount_breakdown |
shipping_taxes |
taxes |
- PUT OR30 - Request cancelations on order lines
API Call: /api/orders/cancel
API Docs: {{TBA}}
"cancelations": [
"amount": 1996,
"quantity": 0,
"reason_code": 34,
"cancelations": [
"amount": 1996,
"quantity": 0,
"reason_code": 34,
"amount": 1996,
"quantity": 0,
"reason_code": 34,
- Partially items;
- Shipping
- Orders
cancellations |
amount |
currency_iso_code |
order_line_id |
Product In Order >Item Order Line ID | ||||
quantity |
Product In Order > Quantity | Based on the Refund Row > Amount we need to calculate the quantity! |
we specify the actual quantity we have for the item e.g. 1, 2, 3 etc. |
"cancelations": [
"amount": 2.00,
"parts": [
"amount": 2.00,
"cancelation_id": "1146",
"quantity": 0,
"reason_code": "34",
"shipping_amount": 0.00,
"parts": [
"amount": 0.00,
"shipping_taxes": [
"taxes": [
Response Mapping:
| Integration Field | Integration Notes | Integration required | Hemi Mapping | Hemi Notes | |||
cancelations |
amount |
N/A | ||||||
amount_breakdown |
N/A | ||||||
parts |
amount |
N/A | ||||||
commissionable |
N/A | ||||||
debitable_from_customer |
N/A | ||||||
payable_to_shop |
N/A | ||||||
cancellation_id |
Order Payment Details > Transaction ID | Because each order item is pushed in a separate transaction we will receive more than one refund_id thus we will have to concatenate them with “-“ | |||||
currency_iso_code |
N/A | ||||||
N/A | ||||||
order_line_id |
N/A | This will be used for the mapping | |||||
quantity |
N/A | ||||||
reason_code |
N/A | ||||||
shipping_amount |
N/A | ||||||
N/A | ||||||
parts |
amount |
N/A | ||||||
commissionable |
N/A | ||||||
N/A | ||||||
payable_to_shop |
N/A | ||||||
shipping_taxes |
N/A | ||||||
taxes |
N/A | ||||||
order_tax_mode |
N/A |
Specifics:
- If all transaction are successfully and we receive the
refund_idor thecancellation_id,we need to mark the Order Payment > Status = "Completed" and Refund Row > Status = "Completed" - If not all transactions are completed but we have one or more completed we mark the Order Payment > Status = “Partially Completed“, Refund Row > Status = “Completed“ for the successful line and Refund Row > Status = “Error“.
- If all transactions failed we mark Order Payment > Status = “Error“, Refund Row > Status = “Error“ and store the error in Order Error table.
