Inno Offer delete
| 1.0 | 09/12/2022 | Hristiyan Georgiev | First Publish |
"update_delete": "delete"
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#OF01
If error, we will have:
<offer_import_tracking>
</offer_import_tracking>
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#OF02
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#OF03
