Marketplaces / Decathlon Technical Scope / Decathlon - Taxonomy
In order to download the taxonomy we need to:
  • GET H11 - List Catalog categories
API Call: /api/hierarchies
Docs: https://decathlonbelgium-preprod.mirakl.net/help/api-doc/seller/mmp.html#H11
  "hierarchies": [
      "code": "5911111",
      "label": "Suncare",
      "label_translations": [
          "locale": "en",
          "value": "Suncare"
          "locale": "fr",
          "value": "Protection solaire"
      "level": 2,
      "parent_code": "59"
      "code": "5911112",
      "label": "Toiletries",
          "locale": "en",
          "value": "Toiletries"
          "locale": "fr",
          "value": "Articles de toilette"
      "level": 2,
      "parent_code": "59"
      "code": "5911113",
      "label": "Womens Hair Removal",
          "locale": "en",
          "value": "Womens Hair Removal"
          "locale": "fr",
          "value": "Épilation Femmes"
      "level": 2,
      "parent_code": "59"
Into the response, we have all the available categories.
  • GET PM11 - Get the product attribute configuration
Docs: https://decathlonbelgium-preprod.mirakl.net/help/api-doc/seller/mmp.html#PM11
  "attributes": [
      "channels": [
          "code": "WEBSITE_EN"
      "code": "washingInstructions3",
      "default_value": null,
      "description": "How do you wash the product",
      "description_translations": [
          "locale": "en",
          "value": "How do you wash the product"
      "example": null,
      "hierarchy_code": "3012",
      "label": "Washing Instructions",
          "locale": "en",
          "value": "Washing Instructions"
      "requirement_level": "OPTIONAL",
      "roles": [],
      "transformations": "CAMEL_CASE",
      "type": "TEXT",
      "type_parameter": null,
      "validations": "MIN_LENGTH|10",
      "variant": false
      "channels": [
          "code": "WEBSITE_FR"
      "code": "toolsIncluded3",
      "description": "Are tools included for the assembly of this product",
          "locale": "en",
          "value": "Are tools included for the assembly of this product"
      "example": null,
      "hierarchy_code": "5610102",
      "label": "Tools Included",
          "locale": "en",
          "value": "Tools Included"
      "roles": [],
      "type": "LIST",
      "type_parameter": "Boolean",
      "variant": false
Into the response, we have all the available attributes for each category.
  • GET VL11 - Get information about operator's value lists
API Call: /api/values_lists
Docs: https://decathlonbelgium-preprod.mirakl.net/help/api-doc/seller/mmp.html#VL11
  "values_lists": [
      "code": "Jewellery",
      "label": "Bijoux",
          "locale": "en",
          "value": "Jewellery"
          "locale": "fr",
          "value": "Bijoux"
      "values": [
          "code": "Accessories",
          "label": "Accessoires",
              "locale": "en",
              "value": "Accessories"
              "locale": "fr",
              "value": "Accessoires"
          "code": "Bracelets",
          "label": "Bracelets",
              "locale": "en",
              "value": "Bracelets"
              "locale": "fr",
          "code": "Necklaces",
          "label": "Colliers",
              "locale": "en",
              "value": "Necklaces"
              "locale": "fr",
              "value": "Colliers"
          "code": "Rings",
          "label": "Anneaux",
              "locale": "en",
              "value": "Rings"
              "locale": "fr",
              "value": "Anneaux"
Note: Once we save the taxonomy, if we would like to update it, we need to delete the old taxonomy and simply to follow the steps above again, in order to get the new one.
