Showroom Prive Offer Full update
| 1.0 | First Publish |
API Docs: {{TBA}}
sku |
product-id |
| product-id-type | | | | Yes | hardcoded as “EAN“ | Must be UPPERCASE |
| internal-description | | | The description of the offer as shown in the back office view - Optional - Maximum 2000 characters | No | N/A | |
| min-quantity-alert | | | | | N/A | |
The accepted values are defined from the Mirakl back office | Required | Product > Condition | Mapping to our conditions:
11- New > 1000;
1-Excellent > 1500;
2-Very Good >4000;
3-Good >5000;
4-Sufficient >6000;
5-Refurbished_like_new > 2750
6-Refurnished_very_good >2500
7-Refurbished_good > 2000
yyyy-MM-dd
or
yyyy-MM-ddThh:mm:ss+00
| No | N/A | |
yyyy-MM-dd
or
| No | N/A | |
| discount-price | | | | No | Product Account > Price | If RRP > Price
If RRP <= Price
discount-start-date| | | | No | | If RRP > Price and If we do not specify any dates in the relevant fields we hardcoded current date (“NOW“) Date format -2017-02-20T10:45:53+01If RRP <= Price We include the discount fields with empty values | |discount-end-date| | | | No | | If RRP > Price and If we do not specify any dates in the relevant fields we hardcode current date + 2 year (“NOW“ +2y) Date format -2017-02-20T10:45:53+01If RRP <= Price We include the discount fields with empty values | |update-delete| | | Used only in "Normal" import mode. Update mode is used if blank. "", "update", "delete" | No | N/A | |
pricing |
sku |
product-id |
11- New > 1000;
1-Excellent > 1500;
2-Very Good >4000;
3-Good >5000;
4-Sufficient >6000;
yyyy-MM-dd
or
| No | N/A | |
yyyy-MM-dd
or
| No | N/A | |
<offer_import_tracking>
</offer_import_tracking>
API Docs: {{TBA}}
API Docs: {{TBA}}
