Secret Sales Ship Orders
| 1.0 | 04/05/2023 | Hristiyan Georgiev | First Publish |
At the moment when sending shipping updates to Secret Sales, we are using the courier from Order Shipments > Carrier We want to introduce Courier mapping. Thus we need to create a slave table under Courier called “Secret Sales Courier Mapping”. In this table we need to have a dropdown field with all the carriers.
| field name | notes |
| Secret Sales Courier | This should be a drop-down menu with the carriers which we get with the GET SH21 - List all carriers. We need to send the carrier_code related to the carrier as well. |
Have all this structure the mapping will works based on: If Order Shipment > Carrier match Courier > Name we send the selected courier from Secret Sales Courier Mapping > Secret Sales Courier
We also would like to introduce a default case in Account Secret Sales called “Default Carrier” where again the same list with carriers (GET SH21 - List all carriers.) to be displayed and to be able to select on specific carrier.
This way the logic will be first we are checking if there is any mapping set in Secret Sales Courier Mapping and if we match any of the couriers. If not We are checking if there is default carrier set in Account Secret Sales If not we should send carrier as “Other“ with carrier name (Order Shipment > Carrier) and tracking num (Order Shipment> Tracking Number)
Please note it would be good if we can have button to update the carriers in Secret Sales Courier Mapping table.
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#SH21
Example response:
"carriers": [
"code": "FED",
"label": "Fed Ex",
"tracking_url": "http://www.fedex.com/Tracking?action=track&tracknumbers={trackingId}"
"code": "UPS",
"label": "UPS",
"tracking_url": "https://wwwapps.ups.com/WebTracking/track?track=yes&trackNums={trackingId}"
"code": "DHL",
"label": "DHL",
"tracking_url": "http://www.dhl.co.uk/en/express/tracking.html?AWB={trackingId}&brand=DHL"
"code": "DPD",
"label": "DPD",
"tracking_url": "http://www.dpd.co.uk/apps/tracking/?parcel={trackingId}"
"code": "TNT",
"label": "TNT",
"tracking_url": "http://www.tnt.com/webtracker/tracking.do?navigation=1&searchType=CON&respLang=en&genericSiteIdent=.&cons={trackingId}"
Parameters:
| order_id | String | |
| Order identifier | Yes |
Example Call:
"carrier_code": "UPS",
"carrier_name": "UPS",
"tracking_number": 5555
carrier_code |
String | |||
carrier_name |
String | |||
carrier_url |
String | |||
tracking_number |
String | |||
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#OR24
Parameters:
Again to update our orders > tool status as “Shipped” and update all the shipping information.
