Inno Offer Full update
| 1.0 | 09/12/2022 | Hristiyan Georgiev | First Publish |
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#OF01
Note: The mapping is the same as described mapping into Create Offer page
NB! We need to split the way we are sending the offer full updates. We need to be able to create two full offer update feeds - One with products that have Protect Price - No, and another with products that have Protect Price - Yes. So we need to be sending either a feed with products that all have price node, or feed with products that all do not have price node. The reason for that is because we cannot have a single feed with products that we are NOT sending price for and products that we are sending price for as Mirakl mistakes this call for offer create and returns error that the price field is mandatory.
<offer_import_tracking>
</offer_import_tracking>
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#OF02
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#OF03
Protect Quantity - We can exclude the quantity from the payload when we are doing updates so we do not add the quantity in the payload when have Protect Quantity raised
Protect Price - We can exclude the price from the payload when we are doing updates so we do not update the price when we have Protect Price raised. This will work only under the condition explained earlier in the document.
Protect the whole item - We update the quantity only.
