Debenhams Create Products
| 03/08/2023 | 1.0 | Hristiyan Georgiev | First Publish |
| 13/09/2023 | 1.1 | Hristiyan | Added logic for Parent Product ID |
| 13/09/2023 | 1.2 | Hristiyan | Added additional logic for returns swatch and details and care |
Please note we do not need to select all variants if only one them is set for revision or creation because they goes as separate products on MIRAKL and the only thing which associate them is the parent_product_id
So we can add variants to a variation group only by specifying the correct parent_product_id
If we want to remove a product from a variation we need to push the product for update again without the parent_product_id
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#P41
Complete flow:
If we receive success after performing P42 (when we send product to MIRAKL & When both "error_report" and "transformation_error_report" are equal to “false“ ) we can proceed to following:
There will be two cases how to handle channel item ids in MIRAKL depends on the type. The first case is after successful product creation we need to fill the Channel Item ID, which will be the SKU. The second option is to use P31 Get products for a list of product references which will map the SKUs between Hemi and MIRAKL and store the MIRAKL id as Channel Item ID.
For Debenhams integration we will go for **option1
If we receive an error (any of "error_report" and "transformation_error_report" are equal to “true“):
Yes |
| No |
Example File:
men-clothing-mens_hoodies_and_sweatshirts-example.xml
<products>
<product>
<attribute>
<code>product_category</code>
<value>men-clothing-mens_hoodies_and_sweatshirts</value>
</attribute>
<attribute>
<code>parent_product_id</code>
<value/>
</attribute>
<attribute>
<code>product_id</code>
<value/>
</attribute>
<attribute>
<code>ean</code>
<value/>
</attribute>
<attribute>
<code>collection</code>
<value/>
</attribute>
<attribute>
<code>product_title</code>
<value/>
</attribute>
<attribute>
<code>long_description</code>
<value/>
</attribute>
<attribute>
<code>details_and_care</code>
<value/>
</attribute>
<attribute>
<code>colour</code>
<value/>
</attribute>
<attribute>
<code>colourfacet</code>
<value/>
</attribute>
<attribute>
<code>fabrication_type</code>
<value/>
</attribute>
<attribute>
<code>gender</code>
<value/>
</attribute>
<attribute>
<code>main_image</code>
<value/>
</attribute>
<attribute>
<code>image_(additional_1)</code>
<value/>
</attribute>
<attribute>
<code>image_(additional_2)</code>
<value/>
</attribute>
<attribute>
<code>image_(additional_3)</code>
<value/>
</attribute>
<attribute>
<code>image_(additional_4)</code>
<value/>
</attribute>
<attribute>
<code>image_(additional_5)</code>
<value/>
</attribute>
<attribute>
<code>swatch</code>
<value/>
</attribute>
<attribute>
<code>returns</code>
<value/>
</attribute>
<attribute>
<code>ethics</code>
<value/>
</attribute>
<attribute>
<code>sustainability_detail</code>
<value/>
</attribute>
<attribute>
<code>design_clothingacc</code>
<value/>
</attribute>
<attribute>
<code>detail_clothingacc</code>
<value/>
</attribute>
<attribute>
<code>fabrication_clothingacc</code>
<value/>
</attribute>
<attribute>
<code>multipack</code>
<value/>
</attribute>
<attribute>
<code>occasion_mensclothingacc</code>
<value/>
</attribute>
<attribute>
<code>range_mensclothingacc</code>
<value/>
</attribute>
<attribute>
<code>activity</code>
<value/>
</attribute>
<attribute>
<code>design_type</code>
<value/>
</attribute>
<attribute>
<code>category2_hoodiessweatshirts</code>
<value>Hoodies & Sweatshirts</value>
</attribute>
<attribute>
<code>fit_tops</code>
<value/>
</attribute>
<attribute>
<code>length_tops</code>
<value/>
</attribute>
<attribute>
<code>neckline_hoodiessweatshirts</code>
<value/>
</attribute>
<attribute>
<code>shape_hoodiessweatshirts</code>
<value/>
</attribute>
<attribute>
<code>size_mens</code>
<value/>
</attribute>
<attribute>
<code>sleeve_length</code>
<value/>
</attribute>
<attribute>
<code>style_hoodiessweatshirts</code>
<value/>
</attribute>
<attribute>
<code>wash</code>
<value/>
</attribute>
</product>
</products>
product_category |
Product Category | Yes | Product Account > Primary Category ID | |
parent_product_id |
Parent Product ID | Yes | <v1.1>Product Account > Variation Group |
Product > SKU | As this field is mandatory we want to have a logic and if the Product Account > Variation Group is not populated and we are listing single product to get the Product > SKU</v1.1> |
| product_id | Product ID | Yes | Product > SKU | |
| ean | Product EAN | Yes | Product > EAN | |
| collection | Brand - if your brand is not available contact Marketplace Team to set up | Yes | Product Account > Item Specifics
Product > Brand | Product Account > Item Specifics is with priority. |
| product_title | Product Title | Yes | Product Account > Title | |
| long_description | Long Description | Yes | Product Account > Description | |
| details_and_care | Details and Care | Yes | <v1.2>Product Account > Item Specifics
Product Account Debenhams > Details and Care | Product Account > Item Specifics is with priority.</v1.2> |
| colour | Colour | Yes | Product Account > Item Specifics | |
| colourfacet | Colour Facet | Yes | Product Account > Item Specifics | |
| fabrication_type | Fabrication Type | No | Product Account > Item Specifics | |
| gender | Gender | Yes | Product Account > Item Specifics | |
| main_image | Main Image - size is 1500 pixels high x 1000 pixels wide | Yes | Product > Main Image or Product Account Debenhams > Main Image | Product Account Debenhams > Main Image is with priority |
| image_(additional_1) | Additional Image1 | No | Product > More Picture URLs or Product Account Debenhams > More Images | Product Account Debenhams > More Images is with priority |
| image_(additional_2) | Additional Image2 | No | Product > More Picture URLs or Product Account Debenhams > More Images | Product Account Debenhams > More Images is with priority |
| image_(additional_3) | Additional Image3 | No | Product > More Picture URLs or Product Account Debenhams > More Images | Product Account Debenhams > More Images is with priority |
| image_(additional_4) | Additional Image4 | No | Product > More Picture URLs or Product Account Debenhams > More Images | Product Account Debenhams > More Images is with priority |
| image_(additional_5) | Additional Image5 | No | Product > More Picture URLs or Product Account Debenhams > More Images | Product Account Debenhams > More Images is with priority |
| swatch | Swatch - size 120 x 120 pixels (this is like a thumbnail photo) | Yes | <v1.2>Product Account > Item Specifics
Product Account Debenhams > Swatch Image | Product Account > Item Specifics is with priority</v1.2> |
| returns | Returns | Yes | <v1.2>Product Account > Item Specifics
Product Account Debenhams > Returns | Product Account > Item Specifics is with priority </v1.2> |
<product_import_tracking>
</product_import_tracking>
API Docs: https://marketplace.kingfisher.com/help/api-doc/seller/mmp.html#P42
Example response:
<import_id>2005</import_id>
<transformation_error_report>false</transformation_error_report>
<shop_id>2000</shop_id>
Depends on the response of:
"error_report" and "transformation_error_report" we will need to call each of the error reports if we receive "true".
When both "error_report" and "transformation_error_report" are equal to “false“ is the success case (Import status = Completed) and we could proceed to creating and offer to this product.
If we receive success (When both "error_report" and "transformation_error_report" are equal to “false“ ) we can proceed to following:
We need to perform this call if we receive error_report = true, into the response from P42;
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#P44
Sample file
This call returns if the import is successful and how may warnings and errors we have in the file. We need to call this if we receive transformation_error_report = true
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#P47
Closed -will stop all the creation of the products to the MPs.
