Yoox Create Products
| 14/12/2022 | 1.0 | Hristiyan Georgiev | First Publish |
| 01/02/2023 | 1.1 | Bogomil Pavlov | Additional Details updated |
| 08/02/2023 | 1.2 | Bogomil Pavlov | Update the description mapping and secondary image logic |
Please note we do not need to select all variants if only one them is set for revision or creation because they goes as separate products on MIRAKL and the only thing which associate them is the VARIANT_GROUP_CODE
So we can add variants to a variation group only by specifying the correct VARIANT_GROUP_CODE
If we want to remove a product from a variation we need to push the product for update again without the VARIANT_GROUP_CODE
API Docs: https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#P41
Complete flow:
If we receive success after performing P42 (when we send product to MIRAKL & When both "has_error_report" and "has_transformation_error_report" are equal to “false“ ) we can proceed to following:
- There will be two cases how to handle channel item ids in MIRAKL depends on the type. The first case is after successful product creation we need to fill the Channel Item ID, which will be the SKU.
- The second option is to use P31 Get products for a list of product references which will map the SKUs between Hemi and MIRAKL and store the MIRAKL id as Channel Item ID. For Yoox integration we will go for the first option so we won’t need to make P31
If we receive an error (any of "has_error_report" and "has_transformation_error_report" are equal to “true“):
Yes |
| No |
Example File:
T25255-FOOTWEAR-Trainers-example.xml
<products>
<product>
<attribute>
<code>CATEGORY</code>
<value>T25255-FOOTWEAR-Trainers</value>
</attribute>
<attribute>
<code>SHOP_SKU</code>
<value/>
</attribute>
<attribute>
<code>TITLE</code>
<value/>
</attribute>
<attribute>
<code>MF</code>
<value>DA0983-100</value>
</attribute>
<attribute>
<code>MODELCOLOR</code>
<value>922</value>
</attribute>
<attribute>
<code>EAN</code>
<value/>
</attribute>
<attribute>
<code>VARIANT_GROUP_CODE</code>
<value/>
</attribute>
<attribute>
<code>GENDER</code>
<value>Unisex</value>
</attribute>
<attribute>
<code>MADEIN</code>
<value>Italy</value>
</attribute>
<attribute>
<code>BRAND</code>
<value>ARMANI</value>
</attribute>
<attribute>
<code>FILTER_COLOR</code>
<value>YELLOW</value>
</attribute>
<attribute>
<code>MAT1</code>
<value>Cotton</value>
</attribute>
<attribute>
<code>MAT1PERC</code>
<value>60</value>
</attribute>
<attribute>
<code>MAT2</code>
<value>Polyster</value>
</attribute>
<attribute>
<code>MAT2PERC</code>
<value>20</value>
</attribute>
<attribute>
<code>MAT3</code>
<value>Silk</value>
</attribute>
<attribute>
<code>MAT3PERC</code>
<value>10</value>
</attribute>
<attribute>
<code>MAT4</code>
<value>Viscose</value>
</attribute>
<attribute>
<code>MAT4PERC</code>
<value>5</value>
</attribute>
<attribute>
<code>MAT5</code>
<value>Leather</value>
</attribute>
<attribute>
<code>MAT5PERC</code>
<value>5</value>
</attribute>
<attribute>
<code>ITEM_DESCRIPTION_ENG</code>
<value/>
</attribute>
<attribute>
<code>ITEM_DESCRIPTION_ITA</code>
<value/>
</attribute>
<attribute>
<code>FIRST_IMAGE</code>
<value/>
</attribute>
<attribute>
<code>SECOND_IMAGE</code>
<value/>
</attribute>
<attribute>
<code>THIRD_IMAGE</code>
<value/>
</attribute>
<attribute>
<code>FOURTH_IMAGE</code>
<value/>
</attribute>
<attribute>
<code>FIFTH_IMAGE</code>
<value/>
</attribute>
<attribute>
<code>SIXTH_IMAGE</code>
<value/>
</attribute>
<attribute>
<code>MODEL_TITLE</code>
<value>Air Max</value>
</attribute>
<attribute>
<code>ITEM_DESCRIPTION_FR</code>
<value/>
</attribute>
<attribute>
<code>ITEM_DESCRIPTION_ES</code>
<value/>
</attribute>
<attribute>
<code>ITEM_DESCRIPTION_DE</code>
<value/>
</attribute>
<attribute>
<code>ITEM_DESCRIPTION_GR</code>
<value/>
</attribute>
<attribute>
<code>HCAT_492</code>
<value/>
</attribute>
<attribute>
<code>CAT_108</code>
<value/>
</attribute>
<attribute>
<code>CAT_6</code>
<value/>
</attribute>
<attribute>
<code>CAT_507</code>
<value/>
</attribute>
<attribute>
<code>CAT_506</code>
<value/>
</attribute>
<attribute>
<code>CAT_479</code>
<value/>
</attribute>
<attribute>
<code>CAT_92</code>
<value/>
</attribute>
<attribute>
<code>CAT_98</code>
<value/>
</attribute>
<attribute>
<code>CAT_477</code>
<value/>
</attribute>
<attribute>
<code>CAT_473</code>
<value/>
</attribute>
<attribute>
<code>CAT_518</code>
<value/>
</attribute>
<attribute>
<code>CAT_519</code>
<value/>
</attribute>
<attribute>
<code>CAT_395</code>
<value/>
</attribute>
<attribute>
<code>CAT_101</code>
<value/>
</attribute>
<attribute>
<code>CAT_502</code>
<value/>
</attribute>
<attribute>
<code>CAT_404</code>
<value/>
</attribute>
<attribute>
<code>CAT_466</code>
<value/>
</attribute>
<attribute>
<code>CAT_700</code>
<value/>
</attribute>
<attribute>
<code>CAT_124</code>
<value/>
</attribute>
<attribute>
<code>CAT_530</code>
<value/>
</attribute>
<attribute>
<code>CAT_40</code>
<value/>
</attribute>
<attribute>
<code>SIZE_403</code>
<value/>
</attribute>
<attribute>
<code>SIZE_406</code>
<value/>
</attribute>
<attribute>
<code>SIZE_407</code>
<value/>
</attribute>
<attribute>
<code>SIZE_408</code>
<value/>
</attribute>
<attribute>
<code>SIZE_411</code>
<value/>
</attribute>
<attribute>
<code>SIZE_412</code>
<value/>
</attribute>
<attribute>
<code>CAT_727</code>
<value/>
</attribute>
<attribute>
<code>SIZE_968</code>
<value/>
</attribute>
<attribute>
<code>SIZE_1075</code>
<value/>
</attribute>
<attribute>
<code>SIZE_1085</code>
<value/>
</attribute>
<attribute>
<code>SIZE_1137</code>
<value/>
</attribute>
<attribute>
<code>SIZE_1138</code>
<value/>
</attribute>
<attribute>
<code>SIZE_1140</code>
<value/>
</attribute>
<attribute>
<code>SIZE_1142</code>
<value/>
</attribute>
<attribute>
<code>SIZE_1179</code>
<value/>
</attribute>
<attribute>
<code>SIZE_1180</code>
<value/>
</attribute>
<attribute>
<code>SIZE_1222</code>
<value/>
</attribute>
<attribute>
<code>PREOWNED_CONDITION</code>
<value>Brand New</value>
</attribute>
<attribute>
<code>MIS_6</code>
<value/>
</attribute>
<attribute>
<code>MIS_7</code>
<value/>
</attribute>
<attribute>
<code>MIS_10</code>
<value/>
</attribute>
<attribute>
<code>MIS_34</code>
<value/>
</attribute>
<attribute>
<code>MIS_117</code>
<value/>
</attribute>
</product>
</products>
CATEGORY |
Product Category | Yes | Product Account > Primary Category ID | |
SHOP_SKU |
Product SKU | Yes | Product > SKU | |
TITLE |
Product Title | Yes | Product Account > Title | |
MF |
The model fabric code provided by the Brand | No | Product Account > Item Specifics | |
MODELCOLOR |
The color code provided by the brand | No | Product Account > Item Specifics | |
EAN |
Unique Identifier for a model, fabric, color & Size | No | Product Account > Marketplace EAN |
Product > EAN | Product Account > Marketplace EAN is with priority |
| VARIANT_GROUP_CODE | Code to group all variants of a product | Yes | Product Account > Variation Group | |
| GENDER | Gender | Yes | Product Account > Item Specifics | |
| MADEIN | Country where the product is made | No | Product Account > Item Specifics | |
| BRAND | Brand of the product | Yes | Product Account> Item specifics
Product > Brand | Product Account > Item Specifics is with priority |
| FILTER_COLOR | The color visible to the final customer on PDP and used for filters | Yes | Product Account > Item Specifics | Yoox Specifics. |
| MAT1 | The material that is present in highest percentage | Yes | Product Account > Item Specifics | Yoox Specifics. |
| MAT1PERC | % of the material | No | Product Account > Item Specifics | Yoox Specifics. |
| MAT2 | Material composition-2 | No | Product Account > Item Specifics | Yoox Specifics. |
| MAT2PERC | % of the material | No | Product Account > Item Specifics | Yoox Specifics. |
| MAT3 | Material composition-3 | No | Product Account > Item Specifics | Yoox Specifics. |
| MAT3PERC | % of the material | No | Product Account > Item Specifics | Yoox Specifics. |
| MAT4 | Material composition-4 | No | Product Account > Item Specifics | Yoox Specifics. |
| MAT4PERC | % of the material | No | Product Account > Item Specifics | Yoox Specifics. |
| MAT5 | Material composition-5 | No | Product Account > Item Specifics | Yoox Specifics. |
| MAT5PERC | % of the material | No | Product Account > Item Specifics | Yoox Specifics. |
| ITEM_DESCRIPTION_ENG | Product description in English | No | Product Account > Description | The description need to be mapped based on the channel language as follows:
Benelux BE Central Europe CEUEastern Europe EEU Holland NL Scandinavia-Eire DK Southern Europe SEU |
| ITEM_DESCRIPTION_ITA | Product description in Italian | No | Product Account > Description | The description need to be mapped based on the channel language as follows:
Italy IT |
| ITEM_DESCRIPTION_FR | Product description in French | No | Product Account > Description | The description need to be mapped based on the channel language as follows:
France FR |
| ITEM_DESCRIPTION_ES | Product description in Spanish | No | Product Account > Description | The description need to be mapped based on the channel language as follows:
Spain ES |
| ITEM_DESCRIPTION_DE | Product description in German | No | Product Account > Description | The description need to be mapped based on the channel language as follows:
Germany DE |
| ITEM_DESCRIPTION_GR | Product description in Greek | No | Product Account > Description | The description need to be mapped based on the channel language as follows:
Greece GR |
| MODEL_TITLE | The model as defined from the brand | No | Product Account Yoox > Model TItle | Yoox Specifics. |
| FIRST_IMAGE | Primary image of the product | Yes | Product > Main Image
Product Account Yoox > Main Image | Product Account Yoox is with priority
New field. |
| SECOND_IMAGE | Secondary image of the product | Yes | Product > More Picture URLs
Product Account Yoox > More Images | Yoox Specifics.
Product Account Yoox is with priority. New field.
Please note in this case we would like to add a validation that the secondary image is required and More Images are required. |
| THIRD_IMAGE | Additional product image | No | Product > More Picture URLs
New field.. |
| FOURTH_IMAGE | Additional product image | No | Product > More Picture URLs
New field. |
| FIFTH_IMAGE | Additional product image | No | Product > More Picture URLs
New field. |
| SIXTH_IMAGE | Additional product image | No | Product > More Picture URLs
New field. |
| HCAT_492 | Is the product made of fur?
made of fur (no shearling)? | Yes | Product Account Yoox > Made of Fur? | Yoox Specifics. New field.
We want to add checkbox of 2 options:
Yes and No.
We need to map Yes to “made of fur” and No to “not made of fur”.
Default selected option should be No |
<product_import_tracking>
</product_import_tracking>
API Docs: https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#P42
Example response:
<import_id>2005</import_id>
<has_transformation_error_report>false</has_transformation_error_report>
<shop_id>2000</shop_id>
Depends on the response of:
"has_error_report" and "has_transformation_error_report" we will need to call each of the error reports if we receive "true".
When both "has_error_report" and "has_transformation_error_report" are equal to “false“ is the success case (Import status = Completed) and we could proceed to creating and offer to this product.
If we receive success (When both "has_error_report" and "has_transformation_error_report" are equal to “false“ ) we can proceed to following:
We need to perform this call if we receive has_error_report = true, into the response from P42;
API Docs: https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#P44
Sample file
This call returns if the import is successful and how may warnings and errors we have in the file. We need to call this if we receive has_transformation_error_report = true
API Docs: https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#P47
Sample file -
GET P31 - Get products for a list of product references
API Call: /api/productsAPI Docs: https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#P31
Sample Request: API call: GET https://richemontit3-dev.mirakl.net/api/products?product_references=EAN|123456789
We will be using the EAN in order to obtain the product Ids.
Please note we can specify many product_references in single request like : https://richemontit3-dev.mirakl.net/api/products?product_references=EAN|123456789,EAN|1234567890123,EAN|1234567895123 etc.
Samples Response:
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?> <body> <total_count>1</total_count> <products> <product> <category_code>5110114</category_code> <category_label>Coffee Machines</category_label> <product_id>9312432012041</product_id> <product_id_type>EAN</product_id_type> <product_sku>MKP100000000037254</product_sku> <product_title>Breville Cafe Roma Stainless Espresso/Cappuccino Machine-ESP8C</product_title> </product> </products> </body>From the response we get the product_id and store it as Product Account > Channel Item ID.
