Marketplaces / ASOS - Technical Scope / ASOS Product Management / ASOS - Offer Price Update
03/10/2022 1.1 Bogomil Pavlov MP feed type updated
15/11/2022 1.2 Bogomil Pavlov Mapping added
01.02.23 1.3 Bogomil Pavlov Split the flow to two separate feeds with and without prices.
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#OF01
Mirakl Field Mirakl Notes Integration Required Hemi Field Comment
product-id Unique product identifier for a given product-id-type - Required at offer creation - Maximum 40 characters Yes Product Account >Marketplace EAN
OR Product >EAN | | | product-id-type | | | | Yes | hardcoded as “ean“ | If we have ean populated we hardcoded the type as “ean“   Note: We always need to have EAN when we check call for listing create | | description | | | Offer description - Recommended - Maximum 2000 characters | No | Product Account > Description | | | internal-description | | | The description of the offer as shown in the back office view - Optional - Maximum 2000 characters | Optional | N/A | | | price | | | The selling price in the currency. It is up to the operator to define with the seller whether the selling price includes or excludes taxes. Decimal number; a period is used to separate cents | Yes | Product Account > Start Price OR Product Account> RRP | we send Product Account > RRP If RRP is populated and is bigger than Price | | price-additional-info | | | Information regarding the price of the offer. Check with your operator if this information appears on the front. Character string limited to 100 characters | No | Product Account ASOS > Price Additional Info | | | state | | | The state code of the offer The accepted values are defined from the Mirakl back office | Required | see notes | Mapping to our conditions: 11- New > 1000; 1-Excellent > 1500; 2-Very Good >4000; 3-Good >5000; 4-Sufficient >6000; 5-Refurbished_like_new > 2750 6-Refurnished_very_good >2500 7-Refurbished_good > 2000 8-Refurbished_acceptable > New state(condition) to be created in Hemi (8000) | | available-start-date | | | The first day the offer becomes available. The offer has no start date if blank.
yyyy-MM-dd or
yyyy-MM-ddThh:mm:ss+00   | No | N/A | | | available-end-date | | | The last day the offer is available. The offer has no end date if blank.
yyyy-MM-dd or
yyyy-MM-ddThh:mm:ss+00 | No | N/A | | | logistic-class | | | The code for the logistic class. This logistic class overwrites the default logistic class defined for the product or Marketplace category assigned to the offer. | No | Account ASOS > Logistic class Product Account ASOS > Logistic class | Our default Logistic Class is selected on account level and if we have selected on Product Account we pick it with priority | | update-delete | | | Used only in "Normal" import mode. Update mode is used if blank. "", "update", "delete" | No | N/A | | | all-prices | | | | | | | | | pricing | | | No | | | | | | channel-code | | No | Account ASOS > Channel Code | We will use on GB channel for ASOS By default to be only the option GB | | | | price | | No | Product Account > Price OR Product Account > RRP | we send Product Account > RRP If RRP is populated and is bigger than Price | | | | discount-price | | No | Product Account > Price | If RRP > Price
  2. If there are no dates imported in Hemi we use the default dates (Now) and (Now + 2y) If RRP <= Price 3.We include the discount fields with empty values | | | | discount-start-date | The first day the discount becomes available (if blank, the discount has no start date and is immediately active) - Optional - Valid date Date format: 2022-09-01 | No | Product Account ASOS> Discount Start Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcoded current date (“NOW“) Date format - 2017-02-20T10:45:53+01 If RRP <= Price We include the discount fields with empty values | | | | discount-end-date | The last day the discount is available (if blank, the discount has no end date) - Optional - Valid date | No | Product Account ASOS > Discount End Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcode current date + 2 year (“NOW“ +2y) Date format - 2017-02-20T10:45:53+01 If RRP <= Price We include the discount fields with empty values |
Аfter successful product creation should have Channel Item ID, which for MIRAKL integration is the SKU!
Product status = Product Published; Listing Status = Active; Update price - Pending
If update was successful, we will have following statuses:
Product status -Product Published ; Listing Status -Active ; Update Price - Not Needed
If we receive an error, we will have:
Product status -Product Published ; Listing Status -Active ; Update Price - Error
  "import_id": 2035
Marketplace Feed > Type Hardcoded as “Offer Stock Price Update“
import Import identifier Yes
Error case: If "has_error_report": true this means there is an error and we need to reach each of the reports in order to check for which item and what is the error.
