The Range - Deactivate Product
The purpose of this page is to describe in details how deactivation products in The Range marketplace works.
If we send 0 stock to a product it will remain unpurchaseable, but The Range recommend to deactivate the product from the marketplace. Basically, to deactivate a product we should use the API for create/update product and the major difference is we need to include into the payload the value active:1. The deactivation on The Range means the product will be still visible but not saleable on the website though.
TBD: Is it enough to send the SKU and Active:1 or we must send the complete payload?
Product status - Product Published; Listing Status - Active ; End Item = Pending
Product status -Product Published ; Listing Status - Inactive; End Item = Not Needed
If error:
Product status - Product Published; Listing Status - Active ; End Item = Error **and the error will be stored into End Item Еrror field.
API Call: https://supplier.rstore.com/rest/product_feed.api?supplier_id=12345
API Docs: https://marketplacetherange.zendesk.com/hc/en-gb/articles/360018370397-API-Product-Feed
Example Call:
"product_arr" : [{
"vendor_sku" : "ABC 123",
"related_product" : "M1234567", # Optional - Kube will generate its own unique product code if
not provided
"title" : "Test Shoe",
"brand" : "The Range",
''gtin'' : ''12345678901'' , #Optional
"price_arr": [{
"price" : "49.50", # No currency symbol expected
"currency" : "GBP", # Not supporting other currencies at the moment
"effective_from" : "2019-05-10" # May be the current active price - can also provide
future price changes
"product_category" : "Shoes",
"description" : "A Shoe Test", # We allow for HTML to be captured here - excluding script/embed
/iframe tags
"feature_arr" : [ # May be empty - not to be confused with attributes, certain Amazon fields such as TargetAudience and SubjectContent belong here
"Includes Sole",
"Prevents falling over",
"Waterproof"
"child_hazard" : 0, # Optional whether this product is hazardous to children
"age_restriction" : "16", # Optional minimum age
"image_url_arr" : [ # All media to be linked to this SKU
"https://www.therange.co.uk/example1.jpg",
"https://www.therange.co.uk/example2.jpg",
"https://www.therange.co.uk/example3.jpg"
"youtube_url_arr" : [ # All video media to be linked to this SKU
"https://www.youtube.com/watch?v=Zhr1uk_O-so",
51
"fulfilment_class" : "Small", # May be one of our supported size classes (Small/Regular/Fragile
/Medium/Large/Extra Large), only required if not using Free Delivery
"product_attribute" : { # All attributes listed below are optional, only colour becomes
mandatory if colour_name is present
"colour" : "#8B4513", # Only required if colour is a distinct attribute of the SKU - we
should be able to map the HEX to our colour group.
"colour_name" : "Saddle Brown", # Optional descriptive name of the colour
"colour_group" : "Brown", # Optional Colour group the primary colour belongs to eg. Red
/Blue/Yellow/Orange etc.
"length" : "1m",
"width" : "5mm",
"height" : "10cm",
"weight" : "9kg",
# Other common attributes batteries required/included, legal disclaimer, warning -
list to be finalised
"other_attribute" : { # Optional list of any other unusual attributes of interest, may
be a dynamic list of key/value pairs.
"ATTR_NAME" : "ATTR_VALUE"
"launch_date" : "2019-05-30", # Optional date when the SKU will automatically be activated
(given that it has completed the onboarding process)
"active" : 1, # Optional - only to be used once the product is already Live, allows it to be
deactivated/discontinued (still visible but not saleable on the website though), or later be re-activated
"visible" : 1 # Optional - only to be used once the product is already Live, allows it to be
hidden from the website
All fields are the same as create product fields, except “Active“ field. Please, bear in mind the mapping for the fields can be found here: The Range - Create Product - In progress .
active |
Optional - only to be used once the product is already Live, allows it to be deactivated/discontinued (still visible but not saleable on the website though), or later be re-activated | Optional | TBD | If we would want to deactivate a product, which is Live on The Range, we should push here “1“. TBD |
{"result":[{"label": "product_feed", "sku_list":"ABC 123"}]}
Error Cases: TBD
