Noon Get Cancellations
| v1.0 | 01/09/2023 | Hristiyan | First publish |
| v1.1 | 18/09/2023 | Hristiyan | Added logic on what to do once we process the files |
| v1.2 | 19/09/2023 | Hristiyan | Added logic for not changing the order status to cancelled. |
| v1.3 | 07/03/2024 | Milen | Changed the field mapping logic in ‘Get Cancellations’ |
| v1.4 | 01/07/2025 | Hristiyan | Mapping changes |
The cancellations will be sent as a credit note in a .csv file format in a specific folder on an sFTP. For this we want to use the FTP Credentials table where we input the details and for the get cancellations we want to control this via an FTP path labelled ‘Get Cancellations’
The file name format is : vat_creditnote_XXXXX_YYYMMDD.csv
Delimiter is comma (,)
vat_creditnote_13059_20221203.csv
Noon only supports single quantity line item based entries. Therefore even if a multi-quantity order was refunded, Noon will put each item as a separate item number with the same credit note but with a unique item number. Thus we need to group by creditnote_nr when creating the refund and add all products associated with the creditnote_nr.
<v1.3> We need to use item_nr and search for it in Order Item Line > Marketplace Order Item ID field. If we have a match, we are to create a refund for the selected product/quantity. We still need to group by creditnote_nr when creating the refunds if there are more than 1 different item_nr within the same order (source_document) </v1.3>
Mapping : Please note N/A means we exclude it and not map to anything
<v1.4> Please note that since we are now creating the file, there are some headers which are removed from the mapping below and some that are with changed names, all changed are tagged, the removed ones are just removed from the table below. </v1.4>
| Noon csv header name | Notes | Hemi Mapping | Comment |
partner_sku |
Order Refund Row > SKU |
sku |
N/A | ||
item_nr |
<v1.3>Order Item Line > Marketplace Order Item ID</v1.3> |
id_partner |
N/A | ||
marketplace |
N/A | ||
<v1.4> order_nr </v1.4> |
This is the marketplace order id | N/A |
creditnote_nr |
This will be the refund ID | Order Payment>Transaction ID |
Note! This will be for Order Payment with type Refund . We also need to check if we have more than one row in the file with the same creditnote_nr and then create a combined refund for all records associated with this creditnote_nr |
<v1.4> returned_date </v1.4> |
Order Payment > Payment Date |
The format of the date is in DD/MM/YYYY format. We need to convert it to unix and since there is no time in the provided date, we want to always import the time of 00:00:00. | |
country_code |
N/A | ||
<v1.4> seller_price </v1.4> |
Order Refund Row > Amount |
Please note this should create the Order Payment in Hemi with:
Order Payment > Type = Refund
Order Payment > Status = Completed
Order Payment > Process by MP = NoOrder Payment > Refund Type = Full Refund, Partial Refund (depends on the line items)
Also there will be no updates on credit notes so if we receive the same records in two separate credit notes, we should do nothing and skip it the second time we receive it.
All other fields, triggers and validation are as per our standard abstraction. Refunds send general logic
<v1.2> Due to client’s requirements we should NOT change the Orders > Status to ‘Cancelled’ but we should keep it as ‘Shipped’ instead. This should be valid both for partial or full cancellations so basically in no case we should change the status.</v1.2>
<v1.1> After successfully processing the csv file, we want to move it into a Processed folder if we managed to process all orders in the file. If one or all orders in the file have failed to be imported successfully, we want to import whatever we can, but move the whole file into an Error folder. </v1.1>
