Debenhams Authentication & Database structure & Limits
| 12/07/2023 | 1.0 | Hristiyan | First publish |
Authentication:
- Log into your Mirakl shop; ( Please contact Bogomil Pavlov or Hristiyan Georgiev )
End point: https://debenhamsuk-prod.mirakl.net/api/
Limits
GET OR11 - List orders
CALL FREQUENCIES
Recommended:
Maximum:
