Inno Offer zero stock update
| 1.0 | 09/12/2022 | Hristiyan Georgiev | Initial Version |
/api/offers/importsAPI Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#OF01
"import_id": 2035
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#OF02
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#OF03
Protect Quantity - This call should go through and send 0 qty. Regardless of the protect quantity flag.
Protect Price - We should not be sending price regardless if this flag is raised.
Protect the whole item - This call should go through and send 0 qty. Regardless of the protect the whole item flag.
Closed - This call should go through and send 0 qty. Regardless of the closed flag.
