B&Q - Create Product
| 19/10/2022 | 1.0 | Initial Version |
Please note we do not need to select all variants if only one them is set for revision or creation because they goes as separate products on MIRAKL and the only thing which associate them is the Mirakl_ProductGroup_ID.
So we can add variants to a variation group only by specifying the correct Mirakl_ProductGroup_ID.
If we want to remove a product from a variation we need to push the product for update again without the Mirakl_ProductGroup_ID.
API Docs: https://marketplace.kingfisher.com/help/api-doc/seller/mmp.html#P41
Complete flow:
If we receive success after performing P42 (when we send product to MIRAKL & When both "has_error_report" and "has_transformation_error_report" are equal to “false“ ) we can proceed to following:
There will be two cases how to handle channel item ids in MIRAKL depends on the type. The first case is after successful product creation we need to fill the Channel Item ID, which will be the SKU. The second option is to use P31 Get products for a list of product references which will map the SKUs between Hemi and MIRAKL and store the MIRAKL id as Channel Item ID. For B&Q integration we will go for second option.
If we receive an error (any of "has_error_report" and "has_transformation_error_report" are equal to “true“):
Yes |
| No |
Example File:
<?xml version="1.0" encoding="UTF8"?>
<products>
<product>
<attribute>
<code>category</code>
<value>PIM_11123</value>
</attribute>
<attribute>
<code>shop_sku</code>
<value/>
</attribute>
<attribute>
<code>name</code>
<value/>
</attribute>
<attribute>
<code>ean</code>
<value/>
</attribute>
<attribute>
<code>image_main_1</code>
<value/>
</attribute>
<attribute>
<code>Mirakl_ProductGroup_ID</code>
<value/>
</attribute>
<attribute>
<code>image_secondary_1</code>
<value/>
</attribute>
<attribute>
<code>image_secondary_2</code>
<value/>
</attribute>
<attribute>
<code>image_secondary_3</code>
<value/>
</attribute>
<attribute>
<code>image_secondary_4</code>
<value/>
</attribute>
<attribute>
<code>image_secondary_5</code>
<value/>
</attribute>
<attribute>
<code>image_secondary_6</code>
<value/>
</attribute>
<attribute>
<code>image_secondary_7</code>
<value/>
</attribute>
<attribute>
<code>image_secondary_8</code>
<value/>
</attribute>
<attribute>
<code>pdf_product_guide</code>
<value/>
</attribute>
<attribute>
<code>pdf_product_instruction_manual</code>
<value/>
</attribute>
<attribute>
<code>pdf_safety_manual</code>
<value/>
</attribute>
<attribute>
<code>video</code>
<value/>
</attribute>
<attribute>
<code>Unique Selling Point 01</code>
<value>Compact size of only 50cm x 40cm</value>
</attribute>
<attribute>
<code>Unique Selling Point 02</code>
<value>Features soft close mechanism for a seamless close</value>
</attribute>
<attribute>
<code>Unique Selling Point 03</code>
<value>All the materials have been thoroughly tested to ensure a high performance and longevity</value>
</attribute>
<attribute>
<code>Unique Selling Point 04</code>
<value>Simple and modern design</value>
</attribute>
<attribute>
<code>Unique Selling Point 05</code>
<value>The door can be installed to open on the right or left side</value>
</attribute>
<attribute>
<code>Unique Selling Point 06</code>
<value>Includes soft hinges with an easy clip system</value>
</attribute>
<attribute>
<code>Unique Selling Point 07</code>
<value>Made in the UK</value>
</attribute>
<attribute>
<code>Unique Selling Point 08</code>
<value>Features preset hardware and antiderailment wheels</value>
</attribute>
<attribute>
<code>Acquisition brand</code>
<value>Use dropdown list</value>
</attribute>
<attribute>
<code>Core_Pack quantity</code>
<value>50</value>
</attribute>
<attribute>
<code>Core_Pack type</code>
</attribute>
<attribute>
<code>Body Copy</code>
<value>Available in a range of designs and styles, the Atomia collection is a modular storage furniture solution that can fit from floor to ceiling in any space no matter how awkward.</value>
</attribute>
<attribute>
<code>Selling Copy</code>
<value>The Atomia cabinets are available in White, Oak effect, and Grey Oak effect. These are perfect for creating anything from a wardrobe to a bedside cabinet.</value>
</attribute>
<attribute>
<code>Key_Feature</code>
<value>3.5 Litre Bowl</value>
</attribute>
<attribute>
<code>Guarantee</code>
</attribute>
<attribute>
<code>reach_verified</code>
<value/>
</attribute>
<attribute>
<code>contains_wood</code>
<value/>
</attribute>
<attribute>
<code>fsc_pecl_certified</code>
<value/>
</attribute>
<attribute>
<code>Core_Product type</code>
</attribute>
<attribute>
<code>Bath_panel_type</code>
</attribute>
<attribute>
<code>Type_Range</code>
<value>Ardesio</value>
</attribute>
<attribute>
<code>Coverage</code>
<value>Please provide numeric values only, m² will be applied automatically as the default Unit of Measure. For example, 10m².</value>
</attribute>
<attribute>
<code>Product_height</code>
<value>Please provide numeric values only, mm will be applied automatically as the default Unit of Measure. For example, 60mm.</value>
</attribute>
<attribute>
<code>Product_thickness</code>
<value>Please provide numeric values only, mm will be applied automatically as the default Unit of Measure. For example, 5mm.</value>
</attribute>
<attribute>
<code>Product_width</code>
<value>Please provide numeric values only, mm will be applied automatically as the default Unit of Measure. For example, 20mm.</value>
</attribute>
<attribute>
<code>Vdesc_Colour</code>
<value>Turquoise</value>
</attribute>
<attribute>
<code>Vdesc_Colour group</code>
</attribute>
<attribute>
<code>Vdesc_Effect</code>
</attribute>
<attribute>
<code>Vdesc_Finish</code>
</attribute>
<attribute>
<code>Tech_Material</code>
</attribute>
<attribute>
<code>Vdesc_Product shape</code>
</attribute>
<attribute>
<code>Vdesc_Style</code>
</attribute>
<attribute>
<code>Tech_Fittings & fixings included</code>
</attribute>
<attribute>
<code>Tech_Handed</code>
</attribute>
<attribute>
<code>Product_weight</code>
<value>Please provide numeric values only, g will be applied automatically as the default Unit of Measure. For example, 500g.</value>
</attribute>
<attribute>
<code>Compatibility</code>
<value>Lightwave L2 link plus.</value>
</attribute>
<attribute>
<code>Instructions_for_fitting</code>
<value>Place the product in the desired position to be secured. With the fixings provided, attach the product to the wall.</value>
</attribute>
</product>
</products>
category |
B&Q PIM category code | REQUIRED | Product Account > Primary Category ID | |
shop_sku |
Seller unique product identifier / product code | REQUIRED | Product > SKU | |
name |
Product description | REQUIRED | Product Account > Title | |
ean |
Unique product barcode | REQUIRED | Product Account > Marketplace EAN |
Product > EAN | If we do not have EAN filled, we should display an error ( EAN is required and we could not proceed to product creation without EAN)
Product Account > Marketplace EAN is with priority |
| image_main_1 | Primary product image - see product publishing guide for imagery guidelines | REQUIRED | Product > Main Image
Product Account B&Q> Main Image | Product Account B&Q is with priority |
| Root Attributes Above | | | | |
| image_secondary_1 | Additional product image - see product publishing guide for imagery guidelines | RECOMMENDED | Product > More Picture URL Image
Product Account B&Q > More Images | B&Q specificsProduct Account B&Q is with priority |
| image_secondary_2 | Additional product image - see product publishing guide for imagery guidelines | RECOMMENDED | Product > More Picture URL Image
| image_secondary_3 | Additional product image - see product publishing guide for imagery guidelines | RECOMMENDED | Product > More Picture URL Image
| image_secondary_4 | Additional product image - see product publishing guide for imagery guidelines | RECOMMENDED | Product > More Picture URL Image
| image_secondary_5 | Additional product image - see product publishing guide for imagery guidelines | RECOMMENDED | Product > More Picture URL Image
| image_secondary_6 | Additional product image - see product publishing guide for imagery guidelines | RECOMMENDED | Product > More Picture URL Image
| image_secondary_7 | Additional product image - see product publishing guide for imagery guidelines | RECOMMENDED | Product > More Picture URL Image
| image_secondary_8 | Additional product image - see product publishing guide for imagery guidelines | RECOMMENDED | Product > More Picture URL Image
| pdf_product_guide | Product guide if available to support customer purchase | RECOMMENDED | Product Account> Item specifics | B&Q specifics |
| pdf_product_instruction_manual | Product instruction manual where required | RECOMMENDED | Product Account> Item specifics | B&Q specifics |
| pdf_safety_manual | Product safety manual where required | RECOMMENDED | Product Account> Item specifics | B&Q specifics |
| video | Product video - see product publishing guide for guidelines | RECOMMENDED | Product > Video URL | B&Q specifics |
| Unique Selling Point 01 | A product specific feature or unique selling point. Brief descriptive text, called out via a bullet point. Describe any special features the product has. | RECOMMENDED | Product Account> Item specifics | B&Q specifics |
| Unique Selling Point 02 | A product specific feature or unique selling point. Brief descriptive text, called out via a bullet point. Describe any special features the product has. | RECOMMENDED | Product Account> Item specifics | B&Q specifics |
| Unique Selling Point 03 | A product specific feature or unique selling point. Brief descriptive text, called out via a bullet point. Describe any special features the product has. | RECOMMENDED | Product Account> Item specifics | B&Q specifics |
| Unique Selling Point 04 | A product specific feature or unique selling point. Brief descriptive text, called out via a bullet point. Describe any special features the product has. | RECOMMENDED | Product Account> Item specifics | B&Q specifics |
| Unique Selling Point 05 | A product specific feature or unique selling point. Brief descriptive text, called out via a bullet point. Describe any special features the product has. | RECOMMENDED | Product Account> Item specifics | B&Q specifics |
| Unique Selling Point 06 | A product specific feature or unique selling point. Brief descriptive text, called out via a bullet point. Describe any special features the product has. | RECOMMENDED | Product Account> Item specifics | B&Q specifics |
| Unique Selling Point 07 | A product specific feature or unique selling point. Brief descriptive text, called out via a bullet point. Describe any special features the product has. | RECOMMENDED | Product Account> Item specifics | B&Q specifics |
| Unique Selling Point 08 | A product specific feature or unique selling point. Brief descriptive text, called out via a bullet point. Describe any special features the product has. | RECOMMENDED | Product Account> Item specifics | B&Q specifics |
| Acquisition brand | Defines the customer facing brand name of the product. | REQUIRED | Product Account> Item specifics
Product > Brand | B&Q specificsProduct Account > Item Specifics is with priority |
| Core_Pack quantity | Defines the number of products supplied when purchasing a single stock keeping unit (SKU). | REQUIRED | Product Account> Item specifics | B&Q specifics |
| Core_Pack type | Defines how the product is supplied.
Each – Single item
Pack – More than one identical items sold under one SKU.
Set – Multiple different items sold under one SKU.
Pair – 2 matching items under one SKU or 1 item that is commonly referred as 2(i.e. door handles, shoes, gloves). | REQUIRED | Product Account> Item specifics | B&Q specifics |
| Body Copy | Product information - A paragraph of free text that introduces the product, where it might be used or what it is used for. | REQUIRED | Product Account > Description | B&Q specifics |
| Selling Copy | Features & Benefits - A paragraph of free text that sits above the individual feature bullets. Contains range and specific product messaging that positions a product to customers. | RECOMMENDED | Product Account> Item specifics | B&Q specifics |
| Key_Feature | Defines call out feature that comes as part of the product for search purposes, used in Marketplace product title only. | RECOMMENDED | Product Account> Item specifics | B&Q specifics |
| Guarantee | States the duration of time the product is covered by a formal assurance (guarantee) that certain conditions will be fulfilled, especially that a product will be repaired or replaced if not of a specified quality. If you provide no additional guarantee above the legal minimum, 'Statutory' must be selected. | REQUIRED | Product Account> Item specifics | B&Q specifics |
| reach_verified | Is the product Registration, Evaluation, Authorisation & restriction of Chemicals compliant? | REQUIRED | Product Account> Item specifics | B&Q specifics |
| contains_wood | Does product contain wood? (yes/no options) | REQUIRED | Product Account> Item specifics | B&Q specifics |
| fsc_pecl_certified | Is the product Forest Stewardship Council or Programme for the Endorsement of Forest Certification certified? | REQUIRED | Product Account> Item specifics | B&Q specifics |
| Mirakl_ProductGroup_ID | MultiSKU Product Group ID | RECOMMENDED | Product Account > Variation Group | B&Q specifics |
| Core_Product type | Defines the basic identifier of the product, which when used on its own will clearly define the product without any further description. | REQUIRED | Product Account> Item specifics | B&Q specifics |
<product_import_tracking>
</product_import_tracking>
API Docs: https://marketplace.kingfisher.com/help/api-doc/seller/mmp.html#P42
Example response:
<import_id>2005</import_id>
<has_transformation_error_report>false</has_transformation_error_report>
<shop_id>2000</shop_id>
Depends on the response of:
"has_error_report" and "has_transformation_error_report" we will need to call each of the error reports if we receive "true".
When both "has_error_report" and "has_transformation_error_report" are equal to “false“ is the success case (Import status = Completed) and we could proceed to creating and offer to this product.
If we receive success (When both "has_error_report" and "has_transformation_error_report" are equal to “false“ ) we can proceed to following:
We need to perform this call if we receive has_error_report = true, into the response from P42;
API Docs: https://marketplace.kingfisher.com/help/api-doc/seller/mmp.html#P44
We will consider Warning=Success in the B&Q integration (it is kind of standard on every MIRAKL) (To be checked and confirmed for the B&Q)
Sample file
This call returns if the import is successful and how may warnings and errors we have in the file. We need to call this if we receive has_transformation_error_report = true
API Docs: https://marketplace.kingfisher.com/help/api-doc/seller/mmp.html#P47
Sample file - To be added
GET P31 - Get products for a list of product references API Call: /api/productsAPI Docs: https://marketplace.kingfisher.com/help/api-doc/seller/mmp.html#P31 Sample Request: API call: GET https://marketplace.kingfisher.com/api/products?product_references=EAN|1234567890123 We will be using the EAN in order to obtain the product Ids. Please note we can specify many product_references in single request like: https://marketplace.kingfisher.com/api/products?product_references=EAN|1234567890123,EAN|123456789012,EAN|1234567890123,EAN|1234567895123 etc. Samples Response:
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?> <body> <total_count>1</total_count> <products> <product> <category_code>5110114</category_code> <category_label>Coffee Machines</category_label> <product_id>9312432012041</product_id> <product_id_type>EAN</product_id_type> <product_sku>MKP100000000037254</product_sku> <product_title>Breville Cafe Roma Stainless Espresso/Cappuccino Machine-ESP8C</product_title> </product> </products> </body>From the response we get the product_id and store it as Product Account > Channel Item ID.
