Debenhams Offer Stock Update
| 03/08/2023 | 1.0 | Hristiyan Georgiev | First Publish |
| 10/08/2023 | 1.1 | Bogomil Pavlov | EAN with cappital case |
| Mirakl Field | Mirakl Notes | Required | Hemi Field | Hemi Note | |
sku |
The offer’s unique identifier in the shop - Required - Maximum 40 characters, no "/" character | Yes | Product >SKU | ||
product-id |
Product > EAN | | |
| product-id-type | | Yes | (v1.1)“EAN” | (v1.1)Hardcoded as “EAN“ | |
Integer greater than or equal to 0 | Yes | Product Account > Quantity | | |
| min-quantity-alert | | | N/A | | |
The accepted values are defined from the Mirakl back office | Required | see notes | Mapping to our conditions:
11- New > 1000;
If other condition is selected we want to return an error | |
"import_id": 2035
Protect Quantity (Stop all quantity updates) If Protect Quantity = Yes and Update Quantity = Pending - We skip the product
Closed -will stop all the updates to the MPs.
