Secret Sales Authentication & Database structure & Limits
| v1.0 | 04/05/2023 | Hristiyan Georgiev | First publish |
| v1.1 | 23/05/2023 | Hristiyan Georgiev | Added supported channels |
(v1.1) Supported channels :
United Kingdom - en_GB
The Netherlands - nl_NL
Belgium - nl_BE and fr_BE
Authentication:
- Log into your Mirakl shop; ( Please contact Bogomil Pavlov or Hristiyan Georgiev )
End point: https://secretsales-prod.mirakl.net/api/
Limits
GET OR11 - List orders
CALL FREQUENCIES
Recommended:
Maximum:
