B&Q - Offer Stock Update
| 19/10/2022 | 1.0 | Initial Version | |
| 23/01/2023 | 1.1 | Bogomil Pavlov | Change the Logic for discounted nodes |
| 01.02.23 | 1.2 | Bogomil Pavlov | Split the flow to two separate feeds with and without prices. |
API Docs: https://marketplace.kingfisher.com/help/api-doc/seller/mmp.html#OF01
sku |
product-id |
Product > EAN | |
| product-id-type | | Yes | hardcoded as “ean“ | |
The accepted values are defined from the Mirakl back office | Required | see notes | Mapping to our conditions:
11- New > 1000;
1-Excellent > 1500;
2-Very Good >4000;
3-Good >5000;
4-Sufficient >6000;
5-Refurbished_like_new > 2750
6-Refurnished_very_good >2500
7-Refurbished_good > 2000
"import_id": 2035
API Docs: https://marketplace.kingfisher.com/help/api-doc/seller/mmp.html#OF02
