Marketplaces / Zalando Direct connection / Zalando Authentication
Purpose of this document is to provide information on the Zalando authentication requirements
API Docs: https://developers.merchants.zalando.com/docs/auth.html
API Call: POST /auth/token
Note: as per the docs “scope”: “access_token_only“ is needed but as per a change that is in effect from 21st of July 2021 this is no longer required as this is now the standard way of authorising
Authorisation is done via basic authorisation using Client ID and Client secret that are specific per Application in our technical Zdirect portal. Each Application is allocated to only one supplier (Fashion partner) in Zalando
Content-type: application/x-www-form-urlencoded
grant_type: client_credentials
The request, if successful, returns an Access token that is used later in every other call
